Hello guys,
I just build an Arcademachine and everything is working so far.
There is just one thing that i need to change : everytime i start the machine gameex is asking for updating the Romlist.
Is there a way to deactivate this ?
Thank you!
Did you update the MAME list when you initially set it up? If not, you will need to let it update first.
Of course I did , but it continues asking after that.
I usualy end the programm hitting the off Button of the computer - maybe gameex is not saving the data when doing the force-shutdown?
Click on the GameEx How to ask for help link in my signature for instructions on how to submit your gameex.ini and log.txt files in reply to this post so we can take a look. Thanks!
