Hi all,
I have searched high and low but I'm unable to find the answer. My jukebox is 99% finished, but I cant figure out how to remap the volume, stopmplay,pause keys. I'm using an ipac.
I have tried changing the custominput.ini file to read volumeup = 39 as a test to try and make the emicolon increase volume but that doesnt work. I enabled custom controls in the configuration section. What I also found whas that when I did enable custom key controls, my "enter key" doesnt work, this is mapped to 1P start on the ipac - works fine when custom keys arnt enabled.
Can anyone please offer any asistance?
CALV
ok, sorted volume, just used autohotkey to remap, easy because I just used windows volume control, but how do I do the play/pause/stop?
ok fixed that also, used autohotkey to do a click in the controls - not a problem with no mouse cursor as it is invisible.
Last question (for today!!) How do I get autohotkey to launch with gamex? I used the autosheller thing which works fine but now I have no hotkeys?
Look at "Launch On Startup Dont Wait" Under "Tweaks/Performance" in the config app.
Hi,
I tried that and got an error saying :
process id=-xfe8(4072),Threadid=0xf84(3972)
Hi,
You should get the latest version as there was a bug that made GameEx show that error instead of a friendly one. Anyway post your log, that should shed some light.
Thanks I will do once I get home, I do have the latest version though.
CALV
Hi,
Not a lot in the log:
21:19:06.5 01/06/2006: GameEx: Version 6.27: Starting Log
21:19:06.5 01/06/2006: Operating System Platform: Win32NT
21:19:06.5 01/06/2006: Operating System Name: Windows XP
21:19:06.5 01/06/2006: Operating System Version: 5.1.2600
21:19:06.5 01/06/2006: Checking for versions of .net Framework installed
21:19:06.5 01/06/2006: .net Framework 1.1 Installed
21:19:06.5 01/06/2006: Checking Registration
21:19:06.5 01/06/2006: Running Randomize()
21:19:06.5 01/06/2006: Checking for applications to Launch On Startup
21:19:06.5 01/06/2006: Launching and not waiting: AutoHotkey.exe
and thats it !
Hi,
and thats it !
Its because GameEx can find that file. Specify a full path to it.
And your not running the latest version. 6.28 fixed GameEx not showing a friendly message.
hmm, odd, it did an auto update. I just used the configuration editor and browsed for the autohotkey exe, doesnt matter though I wrote a small vb app to shell hotkey and gameex then shelled that also so it kicks right in on boot. I will however download 6.28 and try your suggestion and post the results incase anyone else comes accross this issue
CALV
CALV
If the path has spaces in it you may need to put it in quotes, that's probably the issue.
Tom.
