Theme BG Not working
Dal1980
Hi Guys
I know tha theming is a "suck it n see" approach but I have sucked it and I didn't see :D:huh:
I'm trying to get the background colour to change on the main menu screen on gameEx. I've been using the Theme Editor (2.25) to setup some pages.
Not matter what I do I can't shift the standard blue (Default theme backgound) and I've exhausted all background images in the Theme Editor. I don't know where it pull it from but I have got all the images I can squeeze out filled in.
Please see photo of menu attached (couldn't screen grab as it just came out black).
Here's the contents of my theme folder
blank.wav
exitscreensaver.wav
focus.wav
introsound.wav
launch.wav
LOGOS
output.txt
select.wav
start_scroller.txt
_scroller.txt
Here's my Theme.ini contents
[General]
Version=4
Width=1024
Height=768
XResolution=1024
YResolution=768
RightJustifyTitleText=False
ArcadeMode=False
AlphaChannel=False
EnablePopUpDescriptions=False
StaticStartPageList=False
DontZoomStartPageLogos=True
DisplayBackgroundImage=True
AniBak=False
AlphaBlendVideos=False
DialogTextWhite=False
OutlineFonts=True
AnimatedSelector=True
ShowButtons=True
ForeGroundTopMost=False
ShowDateTime=True
DisplayTitleText=True
ShowListNumbers=True
CustomEmulatorLayouts=True
CustomModuleLayouts=False
CustomControlPanel=False
DisplayEmulatorMenus=True
RotatePlus90=False
Font=Roboto
MainFontSize=10
FontStyle=0
TitleFont=Roboto Medium
TitleFontSize=16
TitleFontStyle=1
TextColor=-1
OutlineColor=-16777216
LowerCaseTitleFont=False
ShowSelectionText=True
[TEXT]
[Layout]
List=303,166,689,476
Title=30,121,53,31
Date=30,15,33,19
Time=30,51,35,19
SelectLine1=304,657,84,19
SelectLine2=303,121,84,19
Image=30,166,255,230
Image2=42,411,230,230
Description=614,38,378,113
Scroller=42,656,230,30
Weather=5,725,40,40
Menu=41,700,600,19
ListNum=926,657,60,19
[Weather]
WeatherConditionIcon=False
Enabled=False
=0,0,32,32
[TaskBar]
TopBarMiddle=0,0,1024,46
HelpButtonOver=176,0,47,46
HelpButtonDown=176,0,47,46
MCEButtonOver=24,0,80,46
BackButtonOver=118,0,49,46
BackButtonDown=118,0,49,46
MCEButtonDown=24,0,80,46
TopBarLeft=24,0,206,46
Window=996,0,28,46
MediaControl=848,0,148,46
MediaControlStop=848,0,148,46
[buttons]
ArrowDown=926,708,29,32
ArrowDownPressed=926,708,29,32
ArrowUp=960,708,29,32
ArrowUpPressed=960,708,29,32
On a different note, what's the difference between "Layout" and "Start" on the Object Browser (Layout seems to be the one that Start screen uses which is just backwards as far as I can tell)?
Cheers
Dal
post-30273-0-61119600-1445934371_thumb.j
Link to comment
Share on other sites
Howdy Dal,
It would also probably help if you were to post your gameex.ini file. There are some settings in that file that will affect how your theme works. It can be found in the GameEx\CONFIG folder.
Startbak is normally the file that is used for the start page, but I believe that it not always the case (depending on how you set up your theme and what VIEW you GameEx is currently in).
Link to comment
You need to replace these 3 files in your Theme to get a consistent look (in ...\GameEx\THEMES\<yourtheme>\MEDIA):
BUT, as RedDog is trying to point out, it all depends on what settings you are working from. FYI, the "Layout" section is for positioning all the Modules (such as the game list, the horizontal menu, the image boxes ie the title/snap box etc). In my experience I would create a background that I like, replace the above files with that background, and THEN use the layout function to position everything to suit my background.
Link to comment
Sorry fell asleep :lol: (it was 3:19am!!)
Seems to be working... I had issues with something else the other day and re-installing it helped that so it may have fixed my crazy issue too. Regardless the information here has helped me set the right images now.
Thanks guys
:D
Link to comment
Hey Dal,
I will assume you undesrtand how GameEx Themes work by now. You seem pretty clued up.
Baring that in mind, load the Theme Editor, load your theme, go to Edit> Options> Choose Settings Tab.
Check the box (put a tick in it) "Enable Alpha Channel".
Then File> Save your theme and say hello to transparency.
Reboot GameEx.
Link to comment
Hey Dal,
Reboot GameEx.
Thanks, I missed that option completely :)
Link to comment
