Hi all!!
I have some emulators with box art in normal mode and 3d mode.
Sometimes there are some box art that are in normal and sometimes are in 3d, my question is if it's possible to put 2 paths to the box art path on emulator config, in order to have all my box art.
Thanks in advance!!
I'm not 100% sure if it's possible. Someone with more knowledge can answer that. What I did was copy the regular box art files to the 3D box art files foldee and chose to not move and replace existing files. Then I changed the paths accordingly. It's not ideal, but it worked as a majority of the box art was 3D and it fixed the ones that didn't have box art.
There are several ways to go about it. You could replace all box art files with 3D box art files in the same directory. Pros - simplest. Cons - Where you have gaps it would display a sstandard box art image instead of the 3D Art. The other way is to use the Custom Artwork options in the Advanced Emulator Setup, Name the field 3D Boxart, then point to the path of your 3D box art files. Pros - More to setup within each emulator. Organized and separate. Cons - Only visible when you select the game and see the info.
Thanks for the answers.
My only question was whether they could put both directories, and I see that is not possible.
The problem on our solutions is there is no way to have my box art updated and all displayed same time.... I think it could be a good feature for the next generation of GameEx.
Thanks a lot for your kindly help!!!
