How do you set up PC Games to be started inside Gameex. I have some older PC Games I'd like to have run this way. I see it referenced but I can't find an explanation of how to do it.
Any help on this would be greatly appreciated.
Thank-you
Hi,
There are three approaches and I will only give an overview here.
1. Setup each PC game as an "External Application"
2. Setup each PC game individually as an emulator and use the "Treat as PC game" option for the emulator.
3. Setup shortcuts to all the games in a folder and setup as one emulator listing the shortcuts.
Option 3 is documented here. Follow the example I provided (changing the paths to those that match your setup, of course) and you should be good to go.
Hi
Thank-you so much for the explanations. It seems pretty easy to set up. I will try option 3 as soon as I get a chance to work on it more.
Thanks for your help
I'll +1 that suggestion, I've always done it that way and it's neat and tidy.
