How to merge Gameboy and Gameboy Color .db3 into one .db3?
Hello,
how can i merge the Gameboy and the Gameboy Color .db3 file into one .db3 so i can see Gameboy and Gameboy Color roms at the same time in one emulator slot? I Want to do this also with Neo Geo Pocket and Wonderswan.
1. Will this work?
2. How can i do this?
Best regards
Mogg
You will need the .db3 files for both systems and need to use a DB authoring tool such as SQLLite to combine them into one file. It should work in theory, but YMMV as they say.
Not entirely sure how to tell you to go about naming it or performing the merge of the data as that is something you will have to learn using the application, but I imagine it would have to be named the same as the emulator you are using for both systems which might be helpful information to provide for this type of query. B)
Thank you, i will check out SQLite Compare Utility, seems to be the best choice for this and then name it Gameboy BW&Color. Then select that .db3 in the emulator setup wizard. Hope it works!
i tried it but it is to complex, i will stick with two emulators for the Gameboy and Gameboy Color
