RUnning more then one script/programe before launching Future Pinball / Pinball FX 2 etc
Hey Guys,
Is it possible to launch more then one script before launching Future Pinball etc. Currently I have dmd as the startup script but would also like to have a startup script which rotates my monitors etc with another program I am using. Is this a simple config file hack or can it be done in the settings GUI?
Thanks,
There are some that do this using Autohotkey scripts and/or .bat files using the launch before options for the selected system.
Thanks!, I have just downloaded it and put the .dll in my plugins folder. How do I run the plugin?
There is a "Plugin manager" in the main PBX dir, highlight quicklaunch and use the configure (I think) button lower left.
