Tom I found that when using GameExtender on the secondary monitor that is higher than 1920x1080 it will not display images at fullscreen (stretch to fill the entire screen). So I have a monitor that is 2560x1080 and the images are shrunk to the top left corner however if I set that monitor to 1920x1080 it will display at fullscreen. Can this be fixed for higher resolutions as the image quality is better for displaying marquees on.
For a temp fix I use Display Fusion to launch first to resize the monitor to 1920x1080 then when I exit GameEx have to restore it to it's original size however the quality of the marquees don't look as nice at this resolution on my specific monitor that is designed for marquee's.
Note: If I mentioned this in the past then disregard couldn't remember if I told you about this one before.
