Hi all,
Just setup the beta of Unit3d pinball and would like to add some tables to my PinballX frontend. I have it setup as a "other system" and have all the paths setup correctly to the exe, table folder and working folder.
In the games manager I can use the game select button to see a list of my installed unit3d tables and add them.
it all looks good in the Pinballx front end (artwork displaying etc.) but when I go to launch a table, it runs the unit3d exe and I have to manually browse to and open the table file. Obviously I just need the correct parameters to add to the "other system" setting to get the tables to launch, but I can't find anything in the documentation or forums here.
Thanks in advance for any help.
P.S. I am using the latest version of pinballx.
Thanks for the link. The parameters in that post worked for me fine and having no focus problems as others have reported.
Very happy, cheers.
