Null, Adultery or Draco please excuse me if this is has already been requested but I can't think of how it would be phrased so to search for it I'd have to look through all 34 pages of this thread.
If this feature or something similar is already present in present builds of GameEx then I apologize further as I haven't updated in a while.
That being said, IThink my present build of GameEx loads thumbnails at their original resolution rather than the size they occupy on-screen.
Effectively if I have a really big thumbnail GameEx loads the original resolution of 3000x3000, then downscales it, rather than loading it at the size it occupies onscreen which ~300x300.
You guys I'd highly appreciate it if GameEx could have an option where it loads thumbnails at a lower resolution rather than loading the entire image then downscaling it.
I'm not a programmer so please keep that in mind as there are probably other better software methods to solve the issue which is basically that large thumbnails take a bit to load.
Hi Hamdan - I went ahead and split this from the Feature Requests thread as I think you have something else going on that needs to be addressed.
I recommend downloading and installing the latest update and report back with a copy of your gameex.ini and log.txt (Click here for additional information on how to find these files and others that may be required).
Any other details you can provide such as codecs installed, etc. may also be of help. Thanks!
