After just recently posting a new issue I am having with HideOS not working after a sleep cycle, I updated to 14.30 and am having even more issues. When switching lists, the video previews and 3D cabinets are now doing wacky things. In some cases, switching lists causes the video to freeze and in others the 3D cabinets show up as black boxes. Sometimes they work, sometimes they don't. Mostly they don't. Going back to an earlier rev fixes this.
I've attached my GameEx.ini.
We will need both your gameex.ini and log.txt files in order to try to address. Also, you will need to answer some questions:
- DId you perform an Update install or download and install over the top of your current installation? If update install, try downloading and installing over the top.
- Did if videos are problematic, do you have any codec packs installed and, if so, what?
Hey Tom. Looks like the issue with freezing video and 3D cabs is fixed in 14.31. Thanks for addressing this quickly. I am still having the HideOS issue and another new one. I'll explain further and attach my log and ini file in my HideOS thread.
