Hi
sorry for my english, i'am french
i trie to launch pinball fx2 with pinballx, i have the latest version.
but, is not working, always is portal game activate !!
someone, have a tuto ?
We will be glad to try to help, but need for you to provide copies of your pinballx.ini and log.txt (Click here for additional information on how to find these files and others that may be required). Also, please zip your pinball fx2.xml file and attach in your reply to this post with the other requested files.
My apologies, that should have read pinball fx2.xml file and that would/should reside under your \pinballx\databases\ path.
I looked at your pinballx.ini and need to ask if you are using the Steam version? The install path and data does not lend itself to this information as to which version of Pinball FX2 you have on your PC.
Try making the following changes in the integrated Pinball FX 2 support via the Settings wizard:
[PinballFX2]
WorkingPath=D:\Pinball FX2
Executable=Pinball FX2.exe
Parameters=-applaunch 030615 "[TABLEFILE]"
Process=Pinball FX2.exe
WaitFor=11
Let us know if this resolves the issue or, if not, provide an updated log.txt file after these changes. Thanks.
Nop i have changes in settings wizard, but is not working.
pinball x launch correctly pinball fx 2 but, no table lauch, i stay in main menu.
my log log.txt
thx for help my et again sorry for my english
I have notified the author regarding this issue as it appears related to other threads for similar issues since the changes made for Pinball FX2. You may need to add Pinball FX2 as a separate system instead of using the integrated support.
ok no problem, thx for help
Before wait the fix, i have made a script for lauch the table.
it's work very good, but when a new table out, i need to re make the script :s
You will want to download the latest version of PinballX and install over your current installation. Enable the integrated Pinball FX2 via the Settings application. Select the blank field, then exit Next, open pinballx.ini and, for using the integrated Pinball FX2 support, change the WaitFor= value to -1 if it is not already set. Let us know if this resolves your issue. If not, please post updated copies of your pinballx.ini and log.txt files. Thanks!
hi
i have download the last version of pinballx
i have enable pinball fx2
i have chage wait for to : -1, but the game stay to the screen press start
but nothing work.
i have tried wait for 11 and 15, the game launch , but i stay to the main title(table selection).
PinballX.ini
