When i load up gameex through kodi...gameex starts up but then 10 seconds later kodi crashes. I tried re installing both programs...but it keeps on happening,
This never used to happen before. Anybody been through a similar issue??
I recommend reading through this thread as there may be a few clues that will remedy your issue.Let us know if you are able to resolve the problem or if it continues after following the author's recommendations.
  • 7 months later...
Ok. I still cant load Gameex through kodi. During install i bubbled in the "install in kodi" box. And when I try to run it ,gameex starts for 10 seconds but then kodi takes focus away from gameex. Any fix on this issue?
Please click on the GameEx How to ask for help link in my signature for instructions on how to locate the gameex.ini and log.txt files and submit them for us to review. Also, please be sure that you are using the latest version of GameEx first.
