Hello im new here and recently bought lifetime membership of this product.
Heres the first problem i am encountering with Winkawaks.
Outside gameex everything running well.
Even inside cmd when i run similar command - its working.
But when i run it from gameex - it only runs winkawaks, but its not loading up any rom.
i am using this command line parameters - WinKawaks.exe [rom] -fullscreen
i am using default map packed within gameex.
Anyone know how to solve this?
GameEx.ini
Did you try changing [rom] to "[rompath]/[romfile]" ? I'm unfamiliar with this emulator but that's typically what I use to pass a rom to an emulator.
Also try enclosing the exe in quotes: "winkawaks.exe"
Per some of the other Winkawaks related posts, the following command line should work:
"WinKawaks.exe" [ROM] -fullscreen
I do not run this either, but if this works it should probably be noted somewhere easy to find.
I too neither run nor indeed have heard of this emulator. However, it does win the prize for one of the most preposterously named emulator ever... Or one of the best, I can't decide... Almost as bad as "Cabsoles"
I've got three things for you to check out.
Command=WinKawaks.exe [ROM] -fullscreen
By all accounts this emulator requires double-quotes around the emulator. So just as Draco noted you'll want to modify your command to match the following:
Second make sure that your ROMs are located here (you've likely already verified this part):
RomPath=\\Fastr4TB\fastaemulation\romheaven\roms\neogeo
And further that your ROM names match the ones in the map file you're using (found here):
MapFile=D:\romheaven\GameEx\MAP FILES\[Arcade] Arcade (WinKawaks).map
Good luck dude, and hopefully that sets you on the right track.
  • 1 month later...
yes quotes made the issue. I was aware of it, but what really freezed me was - u have to close all gameex applications for changes u made to apply, which is not common and usually when i use setup wizard i just press arrow forward and changes are saved, i run gameex and boom all changes are working.
For all of you that use MAME to play neogeo games - that suxx :]] This emulator is running games with enhanced really nice to watch graphics in 16:9 and so its worth some pain to get winkawaks running.
Soon i will show some on my stream, when i will finally solve last problem how to get winkawaks running with obs streaming program together :]
Wish me luck and thx for ur support guys, maybe soon when i will find some time i will make some all in one tutorial for Winkawaks
Peace
