Any way to remove the DMD border when using PinballX to launch Pinball FX2?
Sorry if this is Off-topic. Is there a way to remove the DMD boarder when using pinballX to launch pinball FX2? I have the DMD in the correct position. Everything is up and working great through pinballX.. just that dam boarder around the DMD.
Thanks in advance
Thanks in advance
Not sure. I don't have that problem. You might want to open a new thread and post your pinballx.ini so we can take a look.
Thanks in advance
I use the AutoHotKey script found here:
http://steamcommunity.com/app/226980/discussions/0/540744935484535034/
Just setup PinballX to run that script before starting any of the PBFX2 tables...works great for me...no DMD borders any more.
