Cabinet came with 1.88, I want to update to 1.99 - concerns?
I purchased a VP Cabinet that came with PinballX 1.88. I have had a handful of hard freezes, once within the PinballX wheel menu and then a few more inside of a pinball game. So I am thinking something with PinballX isn't too happy. So I want to try and update and hopefully that will fix things.
How do I update to make sure I don't lose any of my stuff? Do I just run the .exe and let it go or should I prepare first to not lose anything?
Thanks for any help!
Always a good idea to backup just in case, however, running the installer and updating the existing installation is usually OK to do.
If hard freezes happen, make sure to check if they are also happening when launching directly from VPinball.exe
If so, you might wan't to check either CPU/GPU temperatures or memory timings.
Always a good idea to make sure your emulators work correctly outside of any frontend.
