Hey guys,
I have a particular problem with the ProSystems emulator for the Atari 7800. I know there was a forum post about this but their method (unless I'm doing it wrong), doesn't work.
Whenever I use the emulator at full screen, the colors becoming all screwed up. However, if I put it into window mode, the colors are fine. I have a duel monitor and I know that my colors get degraded (by looking at the 2nd monitor) when I go fullscreen, which would explain why the colors are funky.
Any tips on this?
Probably not that I am aware of. Just searching about other forums it seems that this emulator is rife with display issues when used in full screen mode. You didn't tell us much about your system (OS, GPU, etc.) which might be helpful if someone else is running the same emulator with a setup similar to yours.
