Hi
I'm using Demul 058 with Gameex and it doe run great but i have couple of questions..
-In the descption of the emulator it says Naomi so i would assume Naomi \ Naomi 2 games ...But in reality the map file used with demul is outdated and does in fact include all atomiswave hikaru and galeco games..
-Is it possible filter just Naomi \ Naomi 2 games with demul 058 ? There is different entry in the setup wizard for atomiswave so i would assume it is possible..Anyone how ?
So what is neccesary for corectly showi games in order filtering the one which are not supposed to be there ?
If you feel the demul map file is outdated, you can always update it yourself. It's simple task. Edit the map file in Notepad, and add the missing ones. The format is "romfile|romname". I'm not home right now, but if you're still having trouble when I return I can post the one I'm using. I've not updated it in a while, but I do believe it is more up to date than the one that comes with GameEx.
Thank if you would be so kind and post that map file that would be amazing :)
