Hi
I have started to build my machine but have wasted hours trying to sort the problem out, without any luck. Please see the attached photo and please ignore the backglass screen, I have a 36" monitor/tv screen that is going to go in there this weekend.
I have a ATi R9 200 graphics card (and have uninstalled raptr) going to a 42" playfield and a 22" backglass. I cannot get the DMD to operate on the second/backglass screen. The DMD goes full screen on my playfield. I then press escape and find the playfield behind it but its in windowed landscape mode. I have tried turning the DMD off but it wont.
Anyone have any ideas on the remedy or is my graphic card the wrong one to use for my project?
post-28957-0-02290900-1430422121_thumb.j
You may want to provide us with your pinballx.ini and log.txt (Click here for additional information on how to find these files and others that may be required). Once we have those we can try to assist you with troubleshooting the issue. Thanks!
Right I have sorted out part of the problem by unticking the full screen mode in the vpmame setup.
