[RESOLVED] Questions & Epsxe / pcsx2
wman
Hi
First of all i have searched and all i have found was old threads regarding custom config which wasn't discussed in the detail.I have got gameex running now i'm trying to set up console emulators within and i'm having some trouble namely Epsxe and Pcsx2 per game configuration..
- I have tried to custom config with ps2lunch and pcsx2bonus neither worked for me the second one gave me error when clicking on exe ? The lunch was just not user friendly to configure and did not worked for me..Aren't here any more alternatives when it comes to per game setting in playstation emulators ? Any suggestions ?
- Than i have tried to config Epsxe with epsxecutor and i have created two profiles wich works within the app but i can't for sake make a shortcut for them as usual on desktop ? I can only export config as reg ? What's the correct procedure ?
- Also i have previously set up Dolphin and Demul all is running fine but when i exit the emulator with ESC there's long delay and after that when going back in Gameex everythin is incredibly slow as if it's cahing files ? I have decent CPU and plenty of ram but HDD is only Sata II ? Is it slow hdd or maybe bad config ? Because when i exit PS2 emu it navigate back and forth really fast just snapy ?
-Apending log
GameEx Support File Data
11:34:35.0 30.4.2015: Opening Configuration File
11:34:35.0 30.4.2015: GameEx: Version 14.06: Starting Log
11:34:35.0 30.4.2015: Windows 7 Professional Service Pack 1 64-bit
11:34:35.0 30.4.2015: Aero NOT running
11:34:35.0 30.4.2015: Initializing Vista/Windows 7 volume control
11:34:35.0 30.4.2015: Getting CPU and RAM info
11:34:35.0 30.4.2015: Intel® Core i5-4670K CPU @ 3.40GHz, 8111MB
11:34:35.0 30.4.2015: 3,4Ghz - 4 Cores or CPU's
11:34:35.0 30.4.2015: Running Randomize()
11:34:35.0 30.4.2015: Loading PlugIns
11:34:35.0 30.4.2015: Checking for applications to Launch On Startup
11:34:35.0 30.4.2015: Setting default net connection limit to 15
11:34:35.0 30.4.2015: Running Misc startup tasks
11:34:35.0 30.4.2015: Setting Menu types
11:34:35.0 30.4.2015: Getting Configuration Values
11:34:35.0 30.4.2015: Using Theme: Default - Media Center V1
11:34:35.0 30.4.2015: Checking for alternate Image Directory for Theme: Default - Media Center V1
11:34:35.0 30.4.2015: Launching HideOS.exe
11:34:35.0 30.4.2015: Initialising Video/MNG DLL's
11:34:35.0 30.4.2015: GameEx will check for media insertion (may affect performance)
11:34:35.0 30.4.2015: Hiding Taskbar
11:34:35.0 30.4.2015: Is Media Center running?
11:34:35.0 30.4.2015: Checking/Creating LCD Registry values
11:34:35.1 30.4.2015: Check Media Center Exit/Start Mode
11:34:35.1 30.4.2015: Media Center Mode 2
11:34:35.1 30.4.2015: Video previews on. Warning: Only recommended on modern systems
11:34:35.1 30.4.2015: Custom Keyboard Input enabled: Getting custom codes
11:34:35.1 30.4.2015: Snap Delay set to: 4
11:34:35.1 30.4.2015: Get other settings
11:34:35.1 30.4.2015: Desktop set to Hide ICONS and set Background to Black
11:34:35.1 30.4.2015: Set: Find emulator artwork on best match basis
11:34:35.1 30.4.2015: Using DirectInput for keyboard input
11:34:35.1 30.4.2015: Start work for Form
11:34:35.1 30.4.2015: Getting Original Screen Size
11:34:35.1 30.4.2015: Opening Database Connection
11:34:35.1 30.4.2015: Initializing Component
11:34:35.1 30.4.2015: MAME Path is: C:\Emulators\Mame32
11:34:35.1 30.4.2015: Cannot Find MAME Path: MAME Disabled
11:34:35.1 30.4.2015: Loading Controls.ini map file
11:34:35.1 30.4.2015: Applying Language/Text
11:34:35.1 30.4.2015: Text/Language: English
11:34:35.1 30.4.2015: Loading Language/Text
11:34:35.1 30.4.2015: Loading Custom Emulators
11:34:35.1 30.4.2015: Loading Emulator 1: [Arcade] Sega Naomi (DEmul)
11:34:35.1 30.4.2015: Loading Emulator 2: [Console] Nintendo GameCube
11:34:35.1 30.4.2015: Loading Emulator 3: [Console] Sony Playstation 2
11:34:35.1 30.4.2015: Checking if Steam enabled
11:34:35.1 30.4.2015: Steam is installed correctly
11:34:35.1 30.4.2015: Found Steam Base Install Folder: c:/program files (x86)/steam
11:34:35.2 30.4.2015: Found Steam Game: Counter-Strike: Global Offensive. AppID=730. Location:C:\Program Files (x86)\Steam\steamapps\common\Counter-Strike Global Offensive
11:34:35.2 30.4.2015: Found Steam games. Steam enabled.
11:34:35.2 30.4.2015: Checking if Origin enabled
11:34:35.2 30.4.2015: Cannot find origin executable
11:34:35.2 30.4.2015: Checking if Uplay enabled
11:34:35.2 30.4.2015: Cannot find UPlay executable
11:34:35.2 30.4.2015: Using 2D Animations
11:34:35.2 30.4.2015: Retrieving resolution setting
11:34:35.2 30.4.2015: Using General Font: Trebuchet MS
11:34:35.2 30.4.2015: Using Title Font: Trebuchet MS
11:34:35.2 30.4.2015: Initialising Direct3D
11:34:35.3 30.4.2015: Applying GameEx is Loading Image
11:34:35.3 30.4.2015: Setting Resolution to 640x480 32 bit color
11:34:35.6 30.4.2015: Creating Surfaces
11:34:35.9 30.4.2015: Creating Primary Surface - Full Screen Mode
11:34:35.9 30.4.2015: Creating Back Buffer
11:34:35.9 30.4.2015: Loading graphic Surfaces
11:34:35.9 30.4.2015: Display is running at: 640x480 32bit color, 30hz
11:34:35.9 30.4.2015: Adapter: ATI Radeon HD 4800 Series
11:34:35.9 30.4.2015: Max texture size: 8192x8192
11:34:35.9 30.4.2015: Available texture memory: 1737MB
11:34:35.9 30.4.2015: Initialising Bass Audio Library
11:34:35.9 30.4.2015: Creating Surfaces Misc and Dialogs
11:34:36.0 30.4.2015: Creating Surfaces Volume
11:34:36.0 30.4.2015: Creating Surfaces Arrows
11:34:36.0 30.4.2015: Creating Surfaces GameEXlogo Text
11:34:36.0 30.4.2015: Creating Surfaces Toolbar
11:34:36.0 30.4.2015: Creating Surfaces Toolbar Controls
11:34:36.0 30.4.2015: Creating Surfaces Backgrounds
11:34:36.0 30.4.2015: Creating Surfaces GameEx Logo
11:34:36.0 30.4.2015: Creating Surface Unselected
11:34:36.0 30.4.2015: Creating Surfaces Home & Exit
11:34:36.0 30.4.2015: Creating Surfaces Snaps
11:34:36.0 30.4.2015: Creating Surfaces Menu and List Bars
11:34:36.1 30.4.2015: Creating Fonts
11:34:36.1 30.4.2015: Creating Game Font
11:34:36.1 30.4.2015: Creating Game Font Faded
11:34:36.2 30.4.2015: Creating Title Font
11:34:36.2 30.4.2015: Restoring Title Font From Cache
11:34:36.2 30.4.2015: Creating Menu Font
11:34:36.2 30.4.2015: Creating Font Black
11:34:36.3 30.4.2015: Creating Font Black Small
11:34:36.3 30.4.2015: Fonts Created Succesfully
11:34:36.3 30.4.2015: 1MB Video Memory Used
11:34:36.4 30.4.2015: MAME CMD options: -nowindow -joy -skip_gameinfo
11:34:36.4 30.4.2015: Initialising DirectInput for Gamepad support
11:34:36.4 30.4.2015: Unable to create a joystick device
11:34:36.4 30.4.2015: Initialising DirectInput for Keyboard support
11:34:36.4 30.4.2015: Loading Start Page
11:34:36.4 30.4.2015: Initializing MCE Remote
11:34:36.4 30.4.2015: Playing intro sound file
11:34:36.5 30.4.2015: Initialization OK! Starting GameEx!
11:34:36.5 30.4.2015: Testing Main Loop Once: Processing Frame
11:34:36.6 30.4.2015: Testing Main Loop Once: Main Loop ran successfully
11:34:39.8 30.4.2015: Validating: Emulator_1: Snap Path: C:\Assets\Arcade\DEmul\Snaps
11:34:39.8 30.4.2015: Validating: Emulator_1: Control Panel Path: C:\Assets\Arcade\DEmul\Controls
11:34:39.8 30.4.2015: Validating: Emulator_1: Database: [Arcade] Sega Naomi
11:34:39.8 30.4.2015: Validating: Emulator_1: Title Snap Path: C:\Assets\Arcade\DEmul\Titles
11:34:39.8 30.4.2015: Validating: Emulator_1: Box Art Path: C:\Assets\Arcade\DEmul\Boxes
11:34:39.8 30.4.2015: Validating: Emulator_1: Cart Art Path: C:\Assets\Arcade\DEmul\Cartridges
11:34:39.8 30.4.2015: Validating: Emulator_1: Manual Path: C:\Assets\Arcade\DEmul\Manuals
11:34:39.8 30.4.2015: Validating: Emulator_2: Snap Path: C:\Assets\Nintendo GameCube\Snaps
11:34:39.8 30.4.2015: Validating: Emulator_2: Control Panel Path: C:\Assets\Nintendo GameCube\Controls
11:34:39.8 30.4.2015: Validating: Emulator_2: Database: [Console] Nintendo GameCube
11:34:39.8 30.4.2015: Validating: Emulator_2: Title Snap Path: C:\Assets\Nintendo GameCube\Titles
11:34:39.8 30.4.2015: Validating: Emulator_2: Box Art Path: C:\Assets\Nintendo GameCube\Boxes
11:34:39.8 30.4.2015: Validating: Emulator_2: Cart Art Path: C:\Assets\Nintendo GameCube\Cartridges
11:34:39.8 30.4.2015: Validating: Emulator_2: Manual Path: C:\Assets\Nintendo GameCube\Manuals
11:34:39.8 30.4.2015: Validating: Emulator_3: Snap Path: C:\Assets\Sony Playstation 2\Snaps
11:34:39.8 30.4.2015: Validating: Emulator_3: Control Panel Path: C:\Assets\Sony Playstation 2\Controls
11:34:39.8 30.4.2015: Validating: Emulator_3: Database: [Console] Sony PlayStation 2
11:34:39.8 30.4.2015: Validating: Emulator_3: Title Snap Path: C:\Assets\Sony Playstation 2\Titles
11:34:39.8 30.4.2015: Validating: Emulator_3: Box Art Path: C:\Assets\Sony Playstation 2\Boxes
11:34:39.8 30.4.2015: Validating: Emulator_3: Cart Art Path: C:\Assets\Sony Playstation 2\Cartridges
11:34:39.8 30.4.2015: Validating: Emulator_3: Manual Path: C:\Assets\Sony Playstation 2\Manuals
11:34:39.8 30.4.2015: Warning: Emulator_3: MAPFile Does Not Exist
11:34:39.9 30.4.2015: Restoring Emulator Database From Cache: 1
11:34:39.9 30.4.2015: Restoring Emulator from Cache: 2
11:34:39.9 30.4.2015: Restoring Emulator Database From Cache: 2
11:34:39.9 30.4.2015: Cache Diff: pcsx2_lunch_launch.bat
[romfile]
- pcsx2-r5875.exe
[rompath]\[romfile]
11:34:39.9 30.4.2015: Not Restoring Emulator from Cache: 3
11:34:40.0 30.4.2015: Not Restoring Emulator Database From Cache: 3
11:34:49.1 30.4.2015: Creating instance of global keyboard hook
11:34:49.3 30.4.2015: Running: cmd.exe /c C: pcsx2-r5875.exe "D:\PS2\Ratchet & Clank.exe"
11:34:49.4 30.4.2015: Shutting down display
11:35:24.3 30.4.2015: Writing Stats
11:35:24.4 30.4.2015: Plugin: Game Exit
11:35:24.4 30.4.2015: Plugin: Process Commands
11:35:24.4 30.4.2015: Refreshing Keyboard
11:35:24.5 30.4.2015: Initialising Audio
11:35:24.5 30.4.2015: Relaunching HideOS
11:35:24.7 30.4.2015: Restoring Window
11:35:24.7 30.4.2015: Reinitializing Graphics System
11:35:25.6 30.4.2015: Reloading Game Info Page
11:35:25.6 30.4.2015: Returning to GameEx
11:35:26.8 30.4.2015: Exiting GameEx!
11:35:26.8 30.4.2015: Disposing all videos
11:35:26.8 30.4.2015: Deleting temporary Karaoke videos
11:35:26.8 30.4.2015: Disposing Image List
11:35:26.8 30.4.2015: Disposing Fonts
11:35:26.8 30.4.2015: Disposing Surfaces
11:35:26.8 30.4.2015: Saving Settings
11:35:26.8 30.4.2015: Shutting down Bass
11:35:26.8 30.4.2015: Closing HideOS.exe
11:35:27.1 30.4.2015: Disposing Plugins
11:35:27.1 30.4.2015: Closing database connection
11:35:27.1 30.4.2015: Checking for applications to Launch On Exit
11:35:27.1 30.4.2015: Media Center was not open when starting GameEx, so not launching
11:35:27.1 30.4.2015: Bye
Link to comment
Share on other sites
Hi wman,
When you have a moment, please so post a copy of your GameEx.ini (or your individual emulator configs for these emulators) in addition to the log you've already posted. The log gives us a bit of information about your PCSX2 Lunch config, but your settings will give us a lot more information. I've never used PS2Lunch, but I've had fantastic luck with PCSX2Bonus. PS2Lunch has some supporters around here though, so they might be able to assist with your PCSX2 woes.
Here are some instructions for setting up ePSXeCutor in GameEx (also check out the posts that follow which describe how to properly create shortcuts for ePSXeCutor).
Link to comment
- Also one more thing instead of opening another thread ?? I would have gladly hear a setup for dolphin per game setting if it's possible ?
Let's keep it one issue per thread, please. This makes it easier on those trying to help with the initial issue and easier for the next user to find a solution. Thanks!
Link to comment
On the whole, PCSXLunch works OK for me. There's different approaches you can take - mine does invovle changing file names, but it's no biggie. However, if I rememeber correctly, you can also batch create .exes if preserving your filenames is necessary. Made a setup guide here if any use:
http://www.gameex.info/forums/topic/13947-pcsx2-setup-with-individual-games-settings/
There is one drawback I'm still to revisit, but it also applies to PCSXBonus as far as I know. It's around PCSX2 updates including updated plugins - think you have to go through your games list updating all the settings. Of course, with a bit of time and coding, sure this could be worked around.
Link to comment
My apology i have no idea that you want too keep the place tidy and clean :) I will create another thread than thanks for letting me know
Link to comment
Thank you for suggestions.. Ihave already tried Lunch with no success managed to run one game only i'm doin something wrong but whole serial renaming thing just puts me off tis just not so easy rename more games ..
Link to comment
I have got it working :) I have followed excelent Nullpointer guide on advanced emultator config and i have made a copy of existing ini than i renamed to pcsx2.ini and selected it from drop down menu...I have than configured in the menu process and assigned pcsx2.exe and voila it worked and it does switch screen..
Thank you all for pataience now you can close the thread as Resolved
Link to comment
