Hello,
i have a strange problem with backglass and my installation
i have a 3 screen setup
46" playfield, 32" Backglass, 18" DMD
right now i have 15 tables working with VP and VP physiks5 and some SAM Tables
i lauch the tables via a script for choosing the right EXE file to lauch the table
Under VP everything works i found the optimal settings for all my screen's and everything is adapted to my need's
Every table has a directb2s file and the script is changed to "b2s.Server" to also use my ledwiz
i installed PinballX, "installed" my games under the gamemanager and everything from the menu is TOP excatly what i was searching for
but if i launch a game i have no backglass.. DMD and playfield is ok and my ledwiz works also (RGB Collors flipper buttons, coin ....)
when i launch it immediately thruop VP again.. Backglass ok
here is a log of a test (the same for 6 other tables i tried)
Sincerly
Shaitan
Log.txt
PinballX.ini
Attach your pinballx.ini. It sounds like your screens in PBX are not set right or your XML file has the backglass disabled.
Z
Just a quick note - Liking your own post doesn't elevate it to anyone's attention, unlike Facebook. It is, however, OK to like yourself if you choose. B)
Sorry, I haven't had a chance to look into this, work is get in the way..........
Can you set your EnableFileMatching to False and try again. I'm not saying that is the issue because I haven't had a chance to parse through your ini line by line.
Also, did you try changing the Backglass Display # in PinballX? For example on my 2 monitor test setup I have Display 1 and Display 5.
Z
