I have had this issue on and off for months, I thought I had it beat a couple times but I think both times were a fluke and what I thought I did to fix it was not a solution at all. For some reason it seems like I am the only one with this exact problem. It would sure be great if someone can help me figure it out.
Problem:
If a table launched in PinballX also runs the backglass in exe mode, it will crash usually as soon as the shaker motor tries to run, the tables crash with a B2SSetData error. This is if launched in PINBALLX ONLY
Error: (See also attachment)
Line xxxx:
Index was Out of range. Must be non-Negative and less than the size of the collection. Parameter Name: Index
example error line (from VPT Script): Controller.B2SSetData nr, State
Tables Affected:
Medieval Madness (as soon as the drawbridge tries to come down)
Apollo 13 (crashes during self text/rocket/shaker at startup)
Many, many others. Too many to name.
Workarounds found:
1. If I set the backglass to "Start Normally" - ie NOT in EXE Mode, this problem goes away but performance is terrible as expected.
2. If I use Hyperpin or any other method to launch the table the problem disappears. - Not what I want to do.
All recent versions of VPinball incl physmod have been tested.
Other Info:
This is a dedicated cabinet not being used for any other purpose
Windows 8.1 64Bit
Geforce GTX 460 (2)
PinballX 1.98 being used, issue exists on all versions tried back to 1.95
I currently have all Codecs uninstalled to eliminate that as a variable (I have tried Klite and Shark007 before)
Everything else up to date.
I'd appreciate any wisdom that can be sent my way, thanks in advance.
PinballX.ini
post-28360-0-20883500-1427640706_thumb.j
