  On 4/7/2015 at 8:45 PM, Adultery said:
Well first things first... Your DT Loader plugin is out of date, your log says it's on version 1.1.3 and the current version is 1.1.5. Tom put out a silent GameEx update that fixes some issues with both Xpadder and Virtual Drive Loader, so you'll want to update those and test again. The chances are that will remove the issues with these since the bug turned out to be a pretty nasty one.
The easiest way to get them is to download the Plugin Updater: http://www.gameex.info/forums/files/file/53-draclabs-plugin-downloader
All you need to do in that case is run the EXE, select the plugins from the list, and press the INSTALL PLUGIN button. If you don't want to go that route, you can also re-download GameEx from gameex.com and install it again which will update these plugins for you.
If you don't want to do that, you can get them from here:
Virtual Drive Loader 1.1.5: http://www.gameex.info/forums/files/file/15-virtual-drive-loader
Xpadder Plugin 1.2.5: http://www.gameex.info/forums/files/file/17-xpadder-plugin
Extract the zip to your GameEx install directory and overwrite the current ones.
Then if you still have issues, load the Plugin Manager and click the 'configure' button for Virtual Drive Loader. Put a check in the box next to "Enable Debug Mode" and then run GameEx. Of course if you don't have anything set up to use it I won;t be able to look at emulator specifics, but this will at least provide the initialization info that will help me troubleshoot the issue.
Thank you for your help. :)
You're awesome but your drac labs plugin program also gives me an unhandeled exception error.
heres what I'm getting and I do have every MVC++ .NET and all the other crap you usually need to run stuff so I'm stumped.error.7z
Still getting terrible slowdown after updating my Plugins to what you linked me to.
Heres the log for VDL dtloader.7z
I'm thinking you're having more issues than just my plugins if nothing is working.. You sure you have .NET framework 2.0 installed?
I'm on framework 4... Didn't know I needed 2.0 I thought they were AIO installs that had the previous version in it. I tried installing 2 and it said it was already a part of my OS.
post-5286-0-69996500-1428447347_thumb.pn
I can't be having more issues because I had ZERO up until I updated my GameEx. Literally nothing else has/had been touched and my GameEx was working fine right before I updated it and was broke immediately after I updated.
Okay, just making sure. :)
I'll look at the new log file, but what would help more is what your crash handler says for the unhandled exception.
My thought is maybe it's a permission issue.
As for VDL, I can optimize it a great deal, so I'll do that and put out a new version that should keep it from building variables in functions it's not needed for.
I'm still concerned about all these exceptions though.. What's your full path to gameex.exe?
I really appreciate it man. I'm really dumb when it comes to debugging and stuff of that nature. I have no idea what/where the crash handler is. I took snaps of the error I was getting in post 51. Hope that helped. :( If I run the plugin program as admin it does work. Not sure about the plugins themselves still. The plugin manager is under admin rights to begin with and stuff like the function logger, game info plugin give an error. There used to be more that wouldn't work like the mame commander wouldn't but it loads fine now.
My Full path to GameEx is C:\GameEx\GameEx.exe
If you could get me the same snap you did for plugin manager but when you load a plugin configuration instead with the details showing (or just copy and paste the details into a post) in the debugger thing that says it's unhandled I can see what the issue is.
omg I forgot I could copy the text xD For Function Logger it says the path is not of a legal form and the details are
  Reveal hidden contents
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentException: The path is not of a legal form.
at System.IO.Path.NormalizePathFast(String path, Boolean fullCheck)
at System.IO.Path.NormalizePath(String path, Boolean fullCheck)
at System.IO.Path.GetDirectoryName(String path)
at Configuration.Button_Log_Browse_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.5485 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
PluginManager
Assembly Version: 1.0.3266.29832
Win32 Version: 1.0.3266.29832
CodeBase: file:///C:/GameEx/PluginManager.exe
Win32 Version: 2.0.50727.5483 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
CursorHider
Assembly Version: 1.0.3416.17500
Win32 Version: 1.0.3416.17500
CodeBase: file:///C:/GameEx/PLUGINS/CursorHider.dll
Microsoft.VisualBasic
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.5483 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
DT Loader
Assembly Version: 1.0.5559.16945
Win32 Version: 1.0.5559.16945
CodeBase: file:///C:/GameEx/PLUGINS/DT%20Loader.dll
System.Xml
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Data
CodeBase: file:///C:/Windows/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
Exocortex.DSP
Assembly Version: 2.0.2584.40793
Win32 Version: 2.0.2584.40793
CodeBase: file:///C:/GameEx/PLUGINS/Exocortex.DSP.dll
Function Logger
Assembly Version: 1.0.5517.19887
Win32 Version: 1.0.5517.19887
CodeBase: file:///C:/GameEx/PLUGINS/Function%20Logger.dll
Game Info Plugin
Assembly Version: 1.9.5133.6272
Win32 Version: 1.9.5133.6272
CodeBase: file:///C:/GameEx/PLUGINS/Game%20Info%20Plugin.dll
Game Tagger
Assembly Version: 1.0.5551.16788
Win32 Version: 1.0.5551.16788
CodeBase: file:///C:/GameEx/PLUGINS/Game%20Tagger.dll
System.Data.SQLite
Assembly Version: 1.0.90.0
Win32 Version: 1.0.90.0
CodeBase: file:///C:/GameEx/PLUGINS/System.Data.SQLite.DLL
System.Transactions
CodeBase: file:///C:/Windows/assembly/GAC_32/System.Transactions/2.0.0.0__b77a5c561934e089/System.Transactions.dll
System.Configuration
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.EnterpriseServices
CodeBase: file:///C:/Windows/assembly/GAC_32/System.EnterpriseServices/2.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll
Interop.HTTSLib
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/GameEx/PLUGINS/Interop.HTTSLib.dll
Interop.SpeechLib
Assembly Version: 5.0.0.0
Win32 Version: 5.0.0.0
CodeBase: file:///C:/GameEx/PLUGINS/Interop.SpeechLib.dll
MAME Commander 2
Assembly Version: 2.0.4831.29935
Win32 Version: 2.1.0.0
CodeBase: file:///C:/GameEx/PLUGINS/MAME%20Commander%202.dll
System.Web
CodeBase: file:///C:/Windows/assembly/GAC_32/System.Web/2.0.0.0__b03f5f7f11d50a3a/System.Web.dll
MAME Commander Lite
Assembly Version: 1.0.5016.1986
Win32 Version: 1.0.5016.1986
CodeBase: file:///C:/GameEx/PLUGINS/MAME%20Commander%20Lite.dll
Microsoft.DirectX.DirectSound
Assembly Version: 1.0.2902.0
Win32 Version: 5.04.00.2904
CodeBase: file:///C:/Windows/assembly/GAC/Microsoft.DirectX.DirectSound/1.0.2902.0__31bf3856ad364e35/Microsoft.DirectX.DirectSound.dll
Microsoft.DirectX
CodeBase: file:///C:/Windows/assembly/GAC/Microsoft.DirectX/1.0.2902.0__31bf3856ad364e35/Microsoft.DirectX.dll
PlugInCallerID
Assembly Version: 1.0.2584.42633
Win32 Version: 1.0.2584.42633
CodeBase: file:///C:/GameEx/PLUGINS/PlugInCallerID.dll
PlugInDigDug
Assembly Version: 1.0.3165.10968
Win32 Version: 1.0.3165.10968
CodeBase: file:///C:/GameEx/PLUGINS/PlugInDigDug.dll
PlugInExit
Assembly Version: 1.0.2584.42966
Win32 Version: 1.0.2584.42966
CodeBase: file:///C:/GameEx/PLUGINS/PlugInExit.dll
PlugInLaunch
Assembly Version: 1.4.0.0
Win32 Version: 1.4.0.0
CodeBase: file:///C:/GameEx/PLUGINS/PlugInLaunch.dll
PlugInLCD
Assembly Version: 1.0.5215.21020
Win32 Version: 1.0.5215.21020
CodeBase: file:///C:/GameEx/PLUGINS/PlugInLCD.dll
PlugInRotate
Assembly Version: 1.3.0.0
Win32 Version: 1.3.0.0
CodeBase: file:///C:/GameEx/PLUGINS/PlugInRotate.dll
PlugInSpeech
Assembly Version: 1.0.4965.12105
Win32 Version: 1.0.4965.12105
CodeBase: file:///C:/GameEx/PLUGINS/PlugInSpeech.dll
PlugInUltraStik
CodeBase: file:///C:/GameEx/PLUGINS/PlugInUltraStik.dll
QuickLaunch
Assembly Version: 1.0.5551.15638
Win32 Version: 1.0.5551.15638
CodeBase: file:///C:/GameEx/PLUGINS/QuickLaunch.dll
RandomArcadeSound
Assembly Version: 1.0.4965.12139
Win32 Version: 1.0.4965.12139
CodeBase: file:///C:/GameEx/PLUGINS/RandomArcadeSound.dll
Ionic.Zip
Assembly Version: 1.9.1.8
Win32 Version: 1.9.1.8
CodeBase: file:///C:/GameEx/PLUGINS/System.Data.Zip.dll
Tapi2Lib
Assembly Version: 1.0.2.5
Win32 Version: 1.0.2.5
CodeBase: file:///C:/GameEx/PLUGINS/Tapi2Lib.dll
Xpadder Plugin
Assembly Version: 1.0.5552.37457
Win32 Version: 1.0.5552.37457
CodeBase: file:///C:/GameEx/PLUGINS/Xpadder%20Plugin.dll
CodeBase: file:///C:/GameEx/PLUGINS/Microsoft.DirectX.DirectSound.dll
Microsoft.DirectX
CodeBase: file:///C:/GameEx/PLUGINS/Microsoft.DirectX.dll
System.Management
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Management/2.0.0.0__b03f5f7f11d50a3a/System.Management.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Game Info Plugin says Object reference not set to an instance of an object and the details are
System.NullReferenceException: Object reference not set to an instance of an object.
at DracLabs.XML.Check_If_Emu_Name_Specified()
at DracLabs.XML.Check_Emu_Nodes()
at DracLabs.XML.Load(String XML_Path)
at GameEx.Config.Config_Load(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
mscorlib
PluginManager
System
System.Drawing
CursorHider
DT Loader
System.Xml
System.Data
Exocortex.DSP
Function Logger
Game Info Plugin
Game Tagger
System.Data.SQLite
System.Transactions
Interop.HTTSLib
Interop.SpeechLib
MAME Commander 2
System.Web
MAME Commander Lite
Microsoft.DirectX
PlugInCallerID
PlugInDigDug
PlugInExit
PlugInLaunch
PlugInLCD
PlugInRotate
PlugInSpeech
PlugInUltraStik
QuickLaunch
RandomArcadeSound
Ionic.Zip
Tapi2Lib
Xpadder Plugin
Microsoft.DirectX
System.Management
enabled.
For example:
For Game Info, that bug was fixed in the latest release. If you create Settings.xml and put it in the Game Info folder that won't happen. The old beta must still be in the installer.
For Function Logger, I'll fix that quick. It's looking for a log file and there isn't one yet which is my bad. That only happens if there is no log in there. :)
Its all good man none of us are infallible. :) I'm just glad its not my PC acting up. lol
Please provide updated log.txt and gameex.ini files for Tom to review. Thanks. Also, if you are using any of the potentially involved plugins as was being discussed previously, updates to them may not have made it into the 14.05 update.
The plugins weren't included in the update so I updated them again and still the problems. Here is my files and logs
GameEx.ini
QuickLaunch.7z
dtloader.7z
The lag is still there because I haven't released any updates yet... I probably won't get to it until the weekend. Sorry.
Tom put out a GameEx update, the same issue will be there until I fix dtloader. I'll post here when it's been done.
Oh, alright. Its all good man. Its just the update said smoother videos and I thought that's what Tom was talking about. My bad. :/
No worries. :)
Here's an update for everything in one zip. Let me know if they work for you now.
You're amazing dude! It doesn't straight up lock up anymore, but it still is really slow to load the videos. My MAME list is unaffected somehow by this slowdown so I can get a good comparison between what it should be and what it is. If there's a way to look at how my MAME stuff is responding compared to everything else I think you could pinpoint the exact issue. I'll update my logs and stuff for ya to check em out in the morning. Thank you for this, I know you have a life. :)
PS Function Logger still crashes with the same error.
Okay, so basically it happens in every emulator except MAME? Could you do me a solid and enable the plugin, run a mame game and an emulator game, and post the debug log?
And wth Function Logger! Lol! I'll look at that again.
Would it help to know what format the videos are in for both MAME and the other emulators affected? Are they all the same format or are some .mp4, others ,avi or .flv?
Ok so I may be mental lol. I got Function Logger to work. Its just like you said I never had a log made (because I never enabled the plugin so it could make one). Here is the sweet sexy log ;)Logger.7z
Excellent question Draco, I asked myself the same thing are every video that I have for video snaps are all in .MP4 format. MAME included.
Can you do one of the debug logs for the virtual drive loader plugin?
I really feel like this might have to do with supporting the new version of dtlite.
Here ya go.
dtloader.7z
Saturn games don't dismount my command is ssf.exe [DTLOADER-SCSI] in the config.
Virtual Drive loader has these commands for the saturn -mount 0, "[RomPathFull]" and -unmount 0
The log looks correct. Open the settings and run that batch file. Let me know if it doesn't dismount.
When I do it through GameEx when it's supposed to dismount, my DT opens up but it doesn't dismount. And it does not dismount through the batch file. My Saturn Games are normally 7zipped but I tried this with both 7zipped and raw ISO formats, and both wont dismount.
