i have double pinball fx2 tables showing now after i installed latest pbx version , there is no double pinball fx 2 xml in database searched for the problem but cant see something wrong , in pbxsetup pinball fx2 system is dissabled because i wanted to keep my existing pbfx2 setup , can it maybe be that there is something in windows registery that i need to dissable to remove the double pbfx2 tables ?
in log i see that it loads pbfx2 2 times :
11:26:06.9 15/03/2015: Loading Database: Pinball FX2
11:26:06.9 15/03/2015: Loading Database: Visual Pinball
right after i posted found the problem , in pbxsetup i had to first enable pbfx2 system and then save and close the setup ,entered back in pbx setup and back dissable pbfx2 system and now double pbfx2 tables are gone problem fixed
also had pinemhi crashes on some tables with closing the table after playing and returning to pbxmenu , found out there was a folder HIscores within that folder there where hi- files remove that folder totally and problem was fixed
Wow, all that and got it sorted yourself! Good job! Thanks for sharing the solution as well! Will mark this as resolved!
