Window display issue with Custom Menu Editor [bug]
Anyone else seeing this? I can't access everything I need to create the menus. I tried different compatibility settings with my PC but no luck
Picture attached. The menu items on the right are all cut off
post-28301-0-75415400-1421510167_thumb.j
Hi Cartisdm,
Just out of curiosity, what is your resolution set as? I'm wondering whether an alternate resolution might clear up the issue.
It's for my HTPC so it's set at 1920x1080. I backed it down to 1280x720 and still have the issue. I've manged to work around the issue by using the tab and arrow keys but it's definitely a pain
It might help us to better help you if you told us what OS you are using and any other pertinent details as I am using Windows 8.1 and I am unable to replicate this issue.
The window is resizeable with the mouse by grabbing a corner or side.
I have a feeling it may be due to my HTPC configuration. I am using large icons and high DPI settings. I've used the Custom Menu Editor enough that I can now navigate quite easily. I'll report back once I swap some local settings around to see if it fixes the issue.
Hopefully it's not affecting anyone else. If that's the case, no need to worry about fixing the bug. Thanks!
