[RESOLVED] Is there a way to disable the Menu?
For a V4 theme, is there a way to disable/hide the Menu?
I am able to find how to disable various functions of the menu such as Hide Change View, Hide Shutdown, Hide Restart, Hide Create Snaps, etc...but what I would like to be able to do is to disable the entire menu at the Home level and emulator/mame levels. Is there an option for this?
I know that I can 'hide' the menu field by moving it off screen, but the options will still be there if you navigate to far up the List field.
Thank you.
