Hi Guys,
I have setup nukelauncher for pinball fx 2 and have got it working great from the command line. I have also setup pinball X to use nukelauncher with the exact settings recomended (Settings below). However when I try to launch a Pinball FX2 table from Pinbal X I just see the loading screen and nothing happens.
[system_1]
Name=Pinball FX2
WorkingPath=C:\Program Files (x86)
TablePath=
Executable=Steam\NukeLauncher.exe
Parameters="[TABLEFILE]"
SystemType=0
08:42:18.3 10/01/2015: PinballX - Version 1.92
08:42:18.5 10/01/2015: Windows 8.1 Pro 64-bit (3.4GB)
08:42:18.5 10/01/2015: Loading Settings
08:42:18.5 10/01/2015: Initialize Component
08:42:18.5 10/01/2015: Initialize Display
08:42:18.6 10/01/2015: Loading PlugIns
08:42:18.7 10/01/2015: Created DirectX BackGlass Window
08:42:18.9 10/01/2015: Hiding Cursor
08:42:18.9 10/01/2015: Hiding Taskbar
08:42:19.0 10/01/2015: CPU: Intel® Celeron® CPU 1007U @ 1.50GHz
08:42:19.0 10/01/2015: GPU 1: Intel® HD Graphics
08:42:19.0 10/01/2015: Displays: 2
08:42:19.0 10/01/2015: Load Game List
08:42:19.1 10/01/2015: Loading Database: Future Pinball
08:42:19.1 10/01/2015: Loading Database: Visual Pinball
08:42:19.1 10/01/2015: Loading Database: Pinball FX2
08:42:19.1 10/01/2015: Finding and matching artwork and videos
08:42:19.5 10/01/2015: Loading Game Statistics and Scores
08:42:19.9 10/01/2015: Loading Surfaces
08:42:20.4 10/01/2015: Finished Loading Surfaces
08:42:20.4 10/01/2015: Initialize Audio
08:42:20.5 10/01/2015: Set Keyboard Controls
08:42:20.5 10/01/2015: Initialize Joystick
08:42:20.5 10/01/2015: No Joysticks Attached
08:42:20.5 10/01/2015: Started
08:42:25.3 10/01/2015: Launch System
08:42:25.3 10/01/2015: Waiting for threads
08:42:25.5 10/01/2015: Disposing display
08:42:28.4 10/01/2015: C:\Program Files (x86)\Steam\NukeLauncher.exe "Plants vs. Zombies"
08:42:43.5 10/01/2015: Created DirectX BackGlass Window
08:42:46.8 10/01/2015: Exiting
08:42:47.6 10/01/2015: Showing Taskbar
08:42:47.8 10/01/2015: Unhiding Mouse Cursor
08:42:47.9 10/01/2015: Disposing Plugins
08:42:47.9 10/01/2015: Saving Settings
08:42:48.0 10/01/2015: Bye
I have to press escape or enter and it go's back into pinball x.
Any ideas?
