[RESOLVED] pbfx2 backglassvideos working ingame with pbx ??
can somebody comfirm if that backglassvideos are working in pbfx2 with pbx , i only can see still pictures as backglass in pbfx2 and not the videos they are named like the still pictures but the videos only work in pbx !?
I am beginning to say things like my parents used to say, such as "You make me sound like a broken record, because I keep repeating myself..."
When reporting a possible bug or error, please submit a copy of the following files so we may quickly assist you:
For PinballX - pinballx.ini and log.txt (Click here for additional information on how to find these files and others that may be required).
- If you are having problems related to video, it is also good to let everyone know what, if any, codec packs you have installed.
- Are you running any plugins or other programs to augment Pinball FX2, such as NukeLanucher (fine program BTW, Time!)? If so, have you checked his thread to see if anyone else encountered similar issues and for a resolution?
draco1962 there is no need to give my logs , btw its just a question not a problem , static backgrounds work thru pbx ingame in pbfx2 , but my question was do also backglassvideos like the namsan ones supposed to be working ingame thru pbx ?
also the backglassvideos for pbfx2 has nothing to do with nukelauncher , pbx does this ( static in game that i know for sure but backglassvideos..in game pbfx2 ? )
... i only can see still pictures as backglass in pbfx2 and not the videos they are named like the still pictures but the videos only work in pbx !?
This part of the your original post sounds like a problem being reported, hence my response to provide the files, and the suggestions made to research further.
no problem with wanting to help ;-) just something i like to know if it was uberhaupt possible on the side of pbx ,maybe that others have it working ..
did what you told and still no bgvideos in pbfx2 , like sayed still pictures work (.jpg), when i remove the still pictures and put the bgvideos with right naming and in right map in pbx media folder directory , still the videos dont work , they work in pbx but as soon i start the table in pbx and it starts to load the bgvideo disapears and stays black screen .
I saw in another thread you were having problems with videos related to codecs. Did that resolve the problems you stated here as well?
i used it before also but nothing then problems with it now with klite wheel is much faster but stil ingame bgvideos dont work either in klite..
@carny priest what version of pinballx you use ? also you are using nukelauncher what version ? tested alot now also the startdelay changes, in the pbfx2 .ini , i have also <hidebackglass>False</hidebackglass> in xml , they are in mp4 format, right naming,right folder, using before sharkycodec also they not worked ,now use klite , but still no videos as soon as i hit the table in pbx and the loading screen comes up then the bgvvideo is gone and black screen ,seen this video now and there they work perfectly :s https://www.youtube.com/watch?v=-IzxM1hb6Hk
PinballX v1.93, the current version
Shark codec pack as linked to on the PinballX.net home page
NukeLauncher v1.7, according to the ini file
NVidia GTX660 runs all three screens, Driver version 347.09
Windows 7 x64, Home Edition
Backglass screen native resolution is 1920x1080 which is the same as Namsan's videos. Is yours different?
I have PinballX running in windowed Full screen mode.
I have several other processes running on top of PinballX and pbfx2 to get it running the way I need it to for my configuration. I have a custom AutoHotkey script that launches NukeLauncher. I re-wrote it so that I could retain video backglasses while in-game:
http://www.gameex.info/forums/topic/12837-support-for-pinball-fx2/?p=135533
You might try testing with this. Comment out the ffmpeg and ffplay calls but keep the Sleep instructions.
NukeLauncher.ini
PinballFX2.xml
PinballX.ini
you run in windowed full screen , i think i run just full screen , gone check and see if it maybe that is the problem..
just tryed windowd full screen but then my playfield screen is resized and backglass is gone from 3rd screen, so switched back to fullscreen.
Do have backglass and DMD positions defined in pinballx.ini?
Window/Full Screen setting set to "Full Screen" AND Full screen windowed set to "Yes"?
Playfield monitor set to native resolution (1920x1080)?
:D for some reason i never saw the option full screen windowed :D
THIS IS FIX = Window/Full Screen setting set to "Full Screen" AND Full screen windowed set to "Yes"
CARNY PRIEST REALY BIG THX FOR FIXING MY PROBLEM !!!!!!!! @admin promote him :P
