[RESOLVED] No picture displayed on Backglass Monitor
I have installed PinballX according to the instructions on my Win 8.1 32 bit cabinet.
I went to the setup procedure and started PinballX.
Everythings looks nice on the playfield witrh the demo tables and audio is working too but I have nothing on my backglass monitor. I checked to see if there are files in the appropriate subdirectories and they are there.
I searched this forum but could not find an appropriate thread.
I habe a three Monitor Setup on a Nvidia GTX 650. Monitor (Full HD) 1 is the playfield,monitor 2 (full hd) is to right of 1st monitor is the backglass, monitor 3 is the dmd.
Here is my pinballx.ini
Please give me some advice.
PinballX.ini
Please provide a copy of your log.txt file and advise what, if any, codecs you have installed. Thanks!
I have installed the shark 007 codecs and used the recommended settings.
I also upgraded to 1.92 today but still nothing on the backglass.
Thank you I have solved the problem.
I misinterpreted the function of the x and y parameters in the backglass setup.
I thought that you have to define the starting coordinates of the backglass montor in relation to your monitor setup.
Obviously these parameters are there to shift the image on the backglass.
I changed them to 0,0, and the backglass appears.
These parameters are not covered in the documentation.
I reread the documentation and noticed these 0,0 settings in the example. That led me to the right track.
Thank you again.
