how do i make the new roms or isos that i added to gameex pop up? Ive added like a hundred games into the frontend across various systems but i still dont see anything but the previous ones. ive even deleted some roms and they are still on the list. The only update game list i see is the section for mame. plz help
That's not normal behavior... Try deleting all the files in the data directory that say .cache in them.
So i can delete every single one of those extensions and nothing bad will happen?
I cannot guarantee nothing bad will happen. Something bad happens everywhere! ;) You should be fine... just do it!
