Hi all,
I have a little problem with the description on the bottom when you're on the list of games emulator.
The problem is that if you delete a game by pressing the DEL key, the description of the next game does not match with their description, if not with the previous game.
This builds up, and if you delete eg 5 sets and continuous browsing the list, the description of each game is of the game 5 position before.
Is there any way to update GameEx emulators list of games?
Thank you very much.
GameEx.ini
I've noticed this happening before as well. It probably has something to do with the memory cache. It's always righted itself for me when I reboot GameEx.
Hi Nullpointer!!!
Yes, normally whe you restart GameEx it's righted, but it fails some times.... I don'w know the cause of problem, but only for information about it.
Thanks for the reply.
You can manually delete all files with cache in the file name or extension and they will rebuild on restart of GameEx.
Hi Draco,
How can i do that?
Thanks in advance!!!
Use Windows explorer and navigate to the gameex config folder.
Sorry for this Draco....
I'm on GameEx config folder, but i don'w know what files to delete.... Sorry...
Can you help me to find what to delete?
Derp! I was at the grocery with my wife when I was typing it. It is in there somewhere.. nothing a search of the \gameex root using keyword cache wouldn't have found. ;)
