I have latest Gameex version installed and want to know if its possible to access Gameex Online and how to do it.
When i enter to online.gameex.com and put my credentials, it says that are not valid.
I need to register to enter it or are the same credentials of Gameex page?
Thanks in advance!!!
Should be the same as your forum credentials. Did you enter them into your GameEx setup also?
Hi Adultery,
Where i can enter my credentials on Gameex setup? Where is that option?
EDIT: Yes, i have my credentials on Gameex Setup.
How Gameex Online works? I need to enter inside Gameex?
No. You log on to http://online.gameex.com and if your GameEx is running and connected you can access that stuff from there. ;)
Thanks Adultery, then my problem is i can not loggin in Gameex Online.
I think i have no credentials to do this or i have no permission....
Sorry, now i can access in.
The problem was i changed my password long time ago on the forum, and did not remember it.
SORRY for that.
