Ihave build a little bit of script that let you change to an modified dofconfig its the dirtyway but it works
I have write an Batchfile that make all the work in the background its change the wheel picture so you can see what mode is on.
you must copy your feedback and no feedback files into the foldes in the script folder
DOF folder must on C:\DirectOutput
the DOF ini(s) must delete from tablefolder or DOF folder
go to the Settings wizzard create a new emulator
use the Feedbackchanger.exe as programm file
set tablepath where ever you want
Go to Gamelist manager create a new entrie in you Feedbackchanger menu
select as table what ever you want wen only run the exe
copy the mediafiles to your Nofeedback folder in pinballX
now it must work
when anybody hast goog grafix for this please send it to me :)
post-9634-0-27752200-1412861075_thumb.jp
Feedbackchanger.rar
to disable toys that you didnt need @night Shake or gear or something else the problem is here when i played @night my neighbors kill my why my shaker it to loud.
