helpman Posted September 19, 2014 Posted September 19, 2014 Hi there!I don't know what could be causing it, but sometimes when I switch on my cabinet (using windows 7) gameex starts minimized, and it's a pain in the... to open the cabinet, get the airmouse and struggle (as the OS is hidden and I only see the mouse pointer briefly).Weird thing is that sometimes it just launches full screen, no problem at all, and others it stays minimized...Any idea about it?If you know anything I could do on the run at startup command that I could use to force it get focus and maximize to full screen it would be great. I just don't know what can be causing it :?
Draco1962 Posted September 19, 2014 Posted September 19, 2014 Can you provide a copy of your log.txt and gameex.ini files so we can take a look? Thanks!
Tom Speirs Posted September 19, 2014 Posted September 19, 2014 You can launch it from a batch file and provide a delay before launching Gameex.exe.You can use the included sleep.exe. you can run that several times.e.ggameex.batC:cd \gameexsleep.exesleep.exegameex.exe
bclinton Posted September 19, 2014 Posted September 19, 2014 Hi there!I don't know what could be causing it, but sometimes when I switch on my cabinet (using windows 7) gameex starts minimized, and it's a pain in the... to open the cabinet, get the airmouse and struggle (as the OS is hidden and I only see the mouse pointer briefly).Weird thing is that sometimes it just launches full screen, no problem at all, and others it stays minimized...Any idea about it?If you know anything I could do on the run at startup command that I could use to force it get focus and maximize to full screen it would be great. I just don't know what can be causing it :?I had the same issue. Gameex Launch fixed it for me. Placed it in my startup folder and set it for 15 seconds. No problems since then. Another thing to check - programs prompting you to update them can steal windows focus also. Java comes to mind as one that kept popping up.
helpman Posted September 19, 2014 Author Posted September 19, 2014 I'll try that gameex Launch as it looks the most Clean way... Where's it?
nullPointer Posted September 19, 2014 Posted September 19, 2014 It's one of Adultery's many illustrious projects. You can find it right here. 2
helpman Posted September 19, 2014 Author Posted September 19, 2014 I found the launch.bat on gameex' folder... 3 sleeps then gameex /quick.I'll have a look at adultery's app too About updates and annoying popups... I already set as hidden bandicam (always with a popup at startup) but there were notifications from nvidia and windows update. They were not showing any banner or popups, but just in case I'm fixing it now EDITED: looks like adultery's launcher has everything I could ever need I'm gonna use it right now :D
Adultery Posted September 19, 2014 Posted September 19, 2014 Much appreciated friend. Thats gonna get an update one of these days to include PinballX.
rabidpuppy Posted October 8, 2014 Posted October 8, 2014 I had this happen randomly also (under Windows XP however, on a currently disassembled cab), since I was using an ipac I just used the shift function mapped to an ALT-TAB "macro" which would switch to GameEx.
