Well I tried a DVI digital cable from the GPU to the monitor and still the same problem. PBX will open and run
only if I am using one screen. As long as both screens are active it won't open.
OK ! I just finished tinkering with settings . . . I changed the main display from display 1 to display 3 and now PBX RUNS ! I can select tables and they work ! Here are my 2 new problems now . . .
1. There is no back glass while in PBX ( Just the windows screen on my monitor). However, when I load a table the b2s backglass loads and functions properly with the table. I tried assigning the backglass to different displays and it didn't do the trick. If I assign the
backglass to monitor 2, PBX won't load at all ? Right now my main display is display 3 and backglass is 1.
2. Now when I exit a table, PBX and VP closes completely instead of returning me to the table menu. Doe this have something to do with the recent update ? Thanks
Let's get updated pinballx.ini and log.txt files immediately following the errors noted in #2. My guess so far as #1 is concerned is that the numbering convention for the GPU outputs is something endemic to the GPU and it may not be possible to change via PinballX. Again, someone more knowledgeable may have a differing opinion or idea.
Here is the .ini ?
  Reveal hidden contents
[Display]
Monitor=2
rotate=270
Windowed=False
WindowWidth=16
WindowHeight=9
WindowX=0
WindowY=0
PlayFieldBrightness=230
WheelTextColor=ffffffff
InfoTextColor=ffffffff
InfoTextOutlineColor=ff000000
FilterTextColor=ffffffff
MenuColor=ffffa500
FullScreenWindowed=True
[backGlass]
monitor=0
x=0
y=0
width=1680
height=1050
[DMD]
monitor=0
x=0
y=0
width=1680
height=1050
UsePinMAME=False
AutoPositionPinMAME=False
[FileSystem]
EnableFileMatching=False
[interface]
DesktopModeEnabled=False
EnableAdditionalDetail=True
ShowSystem=True
ShowRatings=True
OneClickLaunch=True
EnableDefaultFilters=True
[Audio]
StreamVolume=90
SampleVolume=90
PlaySoundInVideos=True
[startup]
playsound=True
playvideo=False
StartWithWindows=No
[KeyCodes]
quit=9
left=162
right=164
select=67
rotate=82
pageleft=33
pageright=34
exitemulator=88
ingame=86
screenshot=83
screenshotbackglass=66
instructions=73
volumedown=109
volumeup=107
[JoyCodes]
quit=10
left=0
right=1
select=2
rotate=3
pageleft=4
pageright=5
exitemulator=6
ingame=13
instructions=14
[Text]
Line1=Free Play
Line2=Press Start
[FuturePinball]
Enabled=False
WorkingPath=h:\-PINBALL-\-FUTURE PINBALL-
TablePath=h:\-PINBALL-\-FUTURE PINBALL-\Tables
Executable=Future Pinball.exe
LaunchBeforeEnabled=false
LaunchBeforeWorkingPath=
LaunchBeforeHideWindow=False
LaunchBeforeWaitForExit=True
LaunchAfterEnabled=False
LaunchAfterWorkingPath=
LaunchAfterHideWindow=False
LaunchAfterWaitForExit=True
MouseClickFocus=True
[VisualPinball]
WorkingPath=C:\Program Files (x86)\Pinball
TablePath=C:\Program Files (x86)\Pinball\Tables
Executable=VPinball921.exe
[ExitScreen]
EnableExit=True
EnableShutdown=True
[startupProgram]
Enabled=false
WorkingPath=
Paramaters=
HideWindow=true
WaitForExit=false
[ExitProgram]
Enabled=false
WorkingPath=
Paramaters=
HideWindow=False
WaitForExit=
[AttractMode]
Timer=1
ShowFor=15
MuteAudio=False
[system_1]
Name=Pinball FX2
Enabled=False
WorkingPath=C:\Steam
TablePath=C:\Steam\Tables
Executable=PinballFX.exe
Parameters=
SystemType=0
[system_2]
Name=MAME
Enabled=False
TablePath=C:\
Executable=mamep64.exe
Parameters=[TABLEFILE]
SystemType=0
[AutoExit]
Enabled=False
Minutes=10
[Login]
Enabled=False
[internal]
lastselected=Medieval Madness (Williams 1997)Medieval-Madness_FS_B2SVisualPinball
filter_year=
filter_company=
filter_custom=
filtername=Tables
[setupWizard]
EmuPath1=C:\Emulators
AssetPath1=C:\Assets
RomPath1=C:\Roms
DefaultPathPrompt=True
DownloadDatabasePrompt=True
DownloadEmulatorPrompt=True
WizardMode=2
CustomArray=Display Settings
SearchArray=
SavePosition=False
SectionIndex=4
SearchText=
EmulatorIndex=0
EmulatorGroupIndex=0
DaphneIndex=0
HTMLAppsIndex=0
ExternalAppsIndex=0
RadioStationsIndex=0
NewsFeedsIndex=0
MappedDrivesIndex=0
SystemIndex=0
ShowPanel=True
FontSize=1
WindowState=2
WindowSize=650,478
WindowLocation=635,281
[GameListManager]
onlinemode=false
[Plugin_1]
Enabled=False
Name=PlugInSpeech.dll
[Plugin_2]
Enabled=False
[Plugin_3]
Enabled=False
Name=Xpadder Plugin.dll
and here is the log.txt
16:36:32.1 9/30/2014: PinballX - Version 1.88
16:36:32.2 9/30/2014: Windows 7 Professional Service Pack 1 64-bit (1.9GB)
16:36:32.2 9/30/2014: Loading Settings
16:36:32.3 9/30/2014: Initialize Component
16:36:32.3 9/30/2014: Initialize Display
16:36:32.3 9/30/2014: Loading PlugIns
16:36:32.6 9/30/2014: Hiding Cursor
16:36:32.6 9/30/2014: Hiding Taskbar
16:36:32.9 9/30/2014: CPU: Pentium® Dual-Core CPU E5500 @ 2.80GHz
16:36:32.9 9/30/2014: GPU 1: NVIDIA GeForce 210
16:36:32.9 9/30/2014: Displays: 2
16:36:32.9 9/30/2014: Load Game List
16:36:32.9 9/30/2014: Loading Database: Visual Pinball
16:36:32.9 9/30/2014: Finding and matching artwork and videos
16:36:33.0 9/30/2014: Loading Game Statistics and Scores
16:36:33.5 9/30/2014: Loading Surfaces
16:36:33.9 9/30/2014: Finished Loading Surfaces
16:36:33.9 9/30/2014: Initialize Audio
16:36:34.0 9/30/2014: Set Keyboard Controls
16:36:34.0 9/30/2014: Initialize Joystick
16:36:34.0 9/30/2014: No Joysticks Attached
16:36:34.0 9/30/2014: Started
16:36:38.7 9/30/2014: Launch System
16:36:38.7 9/30/2014: Waiting for threads
16:36:38.7 9/30/2014: Disposing display
16:36:40.9 9/30/2014: C:\Program Files (x86)\Pinball\VPinball921.exe /play -"C:\Program Files (x86)\Pinball\Tables\Medieval-Madness_FS_B2S.vpt"
16:36:40.9 9/30/2014: C:\PinballX\vpauto.exe
16:36:50.7 9/30/2014: Found PinMAME ROM: mm_10.nv
16:36:51.9 9/30/2014: Hidden Visual Pinball Editor Window
16:37:06.3 9/30/2014: Exit System Control Pressed
16:37:14.2 9/30/2014: Error. Exiting
16:37:14.2 9/30/2014: Unable to cast COM object of type 'Shell32.ShellClass' to interface type 'Shell32.IShellDispatch6'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{286E6F1B-7113-4355-9562-96B7E9D64C54}' failed due to the following error: No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
16:37:14.3 9/30/2014: at Shell32.ShellClass.ToggleDesktop()
16:37:14.3 9/30/2014: at PinballX.Main.l()
16:37:14.3 9/30/2014: at PinballX.Main.ai()
16:37:14.3 9/30/2014: at PinballX.Main..ctor()
16:37:14.3 9/30/2014: Disposing Plugins
16:37:14.3 9/30/2014: Showing Taskbar
16:37:14.4 9/30/2014: Unhiding Mouse Cursor
16:37:14.4 9/30/2014: Bye
After reading through tons of threads, I decided to try installing PBX 1.85. Voila! It works pretty flawlessly.
Thanks everyone for helping guide me to a solution. I'm thrilled.
