Is it possible to group emulators together, eg have a menu for Nintendo, a menu for Sega, etc.? And if not, is it something that could be implemented?
dude i hade the same problem, with no reply. the closest solution to this problem is to set flat menu from the display configuration to yes.
configuration -> display settings -> "Use flat menu=yes" then you could try going to the enable/disable feature and take out the buttons you dont want.
Good luck
