I have enabled the three options for "show additional detail"
enable = yes
show system = yes
show ratings = yes
When regardless of the "enable Desktop mode" setting. If my "Main Display Rotation" is set to "Horizontal" I only see the company logo in the top right corner of the screen. No box, no other information anywhere.
My main display IS running in portrait mode in windows. Hopefully that isn't a problem. I don't rotate my screen, which is why I chose PinballX to begin with.
any ideas?
-Mike
edit: just for clarification, the logo I see is the table manufacturer logo, not the software logo.
Unless someone knows what may be going on, please provide a copy of your pinballx.ini and log.txt (Click here for additional information on how to find these files and others that may be required).
I think this was discussed in a previous post. Due to the lack of space in desktop mode the additional details are not present. If it's a feature you would like to see, post in the features and enhancements thread.
Z
Well here is my ini:
[Display]
Monitor=0
rotate=0
Windowed=False
WindowWidth=480
WindowHeight=720
WindowX=0
WindowY=65
PlayFieldBrightness=230
WheelTextColor=ffc0c0c0
InfoTextColor=ffff0000
InfoTextOutlineColor=ff000000
FilterTextColor=ff008000
MenuColor=ff83973e
[backGlass]
monitor=1
x=0
y=0
width=1360
height=768
[DMD]
monitor=2
x=15
y=58
width=1245
height=310
[FileSystem]
EnableFileMatching=True
[interface]
DesktopModeEnabled=True
EnableAdditionalDetail=True
ShowSystem=True
ShowRatings=True
[Audio]
StrleamVolume=90
SampleVolume=90
PlaySoundInVideos=True
[startup]
playsound=True
playvideo=False
StartWithWindows=No
[KeyCodes]
quit=27
left=160
right=161
select=13
rotate=82
pageleft=162
pageright=162
exitemulator=27
ingame=80
screenshot=83
screenshotbackglass=66
instructions=73
[JoyCodes]
quit=
left=
right=
select=
rotate=
pageleft=
pageright=
exitemulator=
ingame=
instructions=
[Text]
Line1=
Line2=Press Start
[FuturePinball]
Enabled=False
WorkingPath=h:\-PINBALL-\-FUTURE PINBALL-
TablePath=h:\-PINBALL-\-FUTURE PINBALL-\Tables
Executable=Future Pinball.exe
LaunchBeforeEnabled=false
LaunchBeforeWorkingPath=
LaunchBeforeHideWindow=False
LaunchBeforeWaitForExit=True
LaunchAfterEnabled=False
LaunchAfterWorkingPath=
LaunchAfterHideWindow=False
LaunchAfterWaitForExit=True
MouseClickFocus=True
[VisualPinball]
WorkingPath=C:\Visual Pinball
Executable=VPinball990.exe
NVRAMPath=C:\Visual Pinball\nvram
[ExitScreen]
EnableExit=True
EnableShutdown=False
[startupProgram]
Enabled=false
WorkingPath=
Paramaters=
HideWindow=true
WaitForExit=false
[ExitProgram]
Enabled=false
WorkingPath=
Paramaters=
HideWindow=False
WaitForExit=
[AttractMode]
Timer=1
ShowFor=15
[system_1]
Name=Pinball FX2
TablePath=
Executable=Steam.exe
Parameters=-applaunch 226990
LaunchBeforeEnabled=True
LaunchBeforeWorkingPath=C:\PinballX\Scripts\Pinball FX2
LaunchBeforeExecutable=Pinball FX2.exe
LaunchBeforeParameters=[TABLEFILE]
LaunchBeforeWaitForExit=False
LaunchAfterWaitForExit=False
[system_3]
Name=The Pinball Arcade
Enabled=False
TablePath=
Parameters=-applaunch 238260
LaunchBeforeEnabled=False
LaunchAfterWorkingPath=C:\PinballX\Scripts
[system_4]
Name=VP PhysMod
Executable=VP_physmod5.exe
[system_2]
Name=MAME
Enabled=False
TablePath=C:\
Executable=mamep64.exe
[AutoExit]
Enabled=False
Minutes=10
[Login]
Enabled=False
[internal]
lastselected=The Addams Family (Midway 1992)The Addams Family (Williams 1992) - physmodSystem_4
filter_year=
filter_company=
filter_custom=VP - PhysMods
filtername=VP - PhysMods Tables
[setupWizard]
EmuPath1=C:\Emulators
AssetPath1=C:\Assets
RomPath1=C:\Roms
DefaultPathPrompt=True
DownloadDatabasePrompt=True
DownloadEmulatorPrompt=True
WizardMode=1
CustomArray=
SearchArray=
SavePosition=False
SectionIndex=3
SearchText=
EmulatorIndex=0
EmulatorGroupIndex=0
DaphneIndex=0
HTMLAppsIndex=0
ExternalAppsIndex=0
RadioStationsIndex=0
NewsFeedsIndex=0
MappedDrivesIndex=0
SystemIndex=3
ShowPanel=False
FontSize=1
WindowState=0
WindowSize=650,790
WindowLocation=179,670
[Plugin_1]
Enabled=False
Name=PlugInSpeech.dll
[Plugin_2]
Enabled=False
[Plugin_3]
Enabled=False
Name=Xpadder Plugin.dll
and here is my log:
17:37:39.9 7/16/2014: PinballX - Version 1.85
17:37:39.9 7/16/2014: Loading Settings
17:37:39.9 7/16/2014: Initialize Component
17:37:40.0 7/16/2014: Initialize Display
17:37:40.0 7/16/2014: Loading PlugIns
17:37:40.1 7/16/2014: Created DirectX BackGlass Window
17:37:40.1 7/16/2014: Created DirectX DMD Window
17:37:40.3 7/16/2014: Hiding Cursor
17:37:40.3 7/16/2014: Hiding Taskbar
17:37:40.3 7/16/2014: Loading Font
17:37:40.3 7/16/2014: Load Game List
17:37:40.3 7/16/2014: Loading Database: Visual Pinball
17:37:40.3 7/16/2014: Loading Database: Pinball FX2
17:37:40.3 7/16/2014: Loading Database: VP PhysMod
17:37:40.3 7/16/2014: Finding and matching artwork and videos
17:37:42.0 7/16/2014: Loading Game Statistics and Scores
17:37:42.4 7/16/2014: Initialize Audio
17:37:42.4 7/16/2014: Set Keyboard Controls
17:37:42.4 7/16/2014: Initialize Joystick
17:37:42.5 7/16/2014: 1 Joysticks Attached
17:37:42.5 7/16/2014: Started
17:37:52.9 7/16/2014: Launch System
17:37:52.9 7/16/2014: Waiting for threads
17:37:52.9 7/16/2014: Disposing display
17:37:54.7 7/16/2014: C:\Visual Pinball\VPinball990.exe /play -"C:\Visual Pinball\Tables\Cirqus_Voltaire_Platinum_Edition v1.5_FS_B2S.vpt"
17:37:54.7 7/16/2014: C:\PinballX\vpauto.exe
17:38:00.0 7/16/2014: Found PinMAME ROM: cv_14.nv
17:40:20.1 7/16/2014: Exit System Control Pressed
17:40:22.6 7/16/2014: Created DirectX BackGlass Window
17:40:22.6 7/16/2014: Created DirectX DMD Window
17:40:43.8 7/16/2014: Launch System
17:40:43.8 7/16/2014: Waiting for threads
17:40:43.8 7/16/2014: Disposing display
17:40:45.8 7/16/2014: C:\Visual Pinball\VP_physmod5.exe /play -"C:\Visual Pinball\Tables\The Addams Family (Williams 1992) - physmod.vpt"
17:43:32.4 7/16/2014: Exit System Control Pressed
17:43:35.0 7/16/2014: Created DirectX BackGlass Window
17:43:35.0 7/16/2014: Created DirectX DMD Window
17:43:39.2 7/16/2014: Exiting
17:43:39.4 7/16/2014: Showing Taskbar
17:43:39.4 7/16/2014: Unhiding Mouse Cursor
17:43:39.4 7/16/2014: Disposing Plugins
17:43:39.4 7/16/2014: Saving Settings
Based on the behavior, It does seem something more like Zeenon mentioned. I thought I searched pretty well for the right keywords but maybe I missed it.
-Mike
