Hi
I am keen to try out the GameEX FE, but I have the following questions:
(1) Is there a theme available or is it possible to have a theme (something similar to the old FE – ArcadeOS), which allows:
( a ) Full screen snaps OR Full screen videos (ie. emu movies videos)
( b ) Games lists centred on the screen on top of the snap or video with the selected game somehow highlighted in the centre of the screen OR Games lists at the edge of the screen on top of the snap or video similar to the Hyperspin wheel list with the selected game somehow highlighted.
( c ) Ability to use the Hyperspin game wheel images for the game list in ( b ) above.
(2) Does GameEX FE also allow for favourite games to be selected from a main games lists into an favourite games list? And that the favourite games list can be launched as soon as GameFE starts?
Look forward to your replies
D
1-A: Yes.
1-B: Yes.
1-C: Not officially without some extensive work arounds, so no.
2-A: Yes.
2-B: No, but it's one click. ;)
Hi Adultery
Thank you for your prompt reply.
I understand that possible Evolution will be the next FE taking over from Game EX?
If that is the case, will Evolution support all of my requirements as listed in my earlier post?
Thank you.
D
It's possible. :)
Hi Adultery
With the release of GameEX Evolution (Preview)? Is the FE able to support my earlier requirements being:
I look forward to your reply.
Thank you
D
Refer to this post. I believe most of your questions will be answered there and I am sure there will be other neat things that you will like as well! Stay tuned!
Hi Adultery
Thank you
D
I'm not familiar with ArcadeOS, but i can answer a few of your questions:
1a, Yes, can be done in GameEx
1b, Yes, can be done, although won't look like Hyperspin - it will look like GameEx
1c, No, because GameEx is not Hyperspin :)
2 - Yes, absolutely, although to have it "start" may require "unconventional" means, but viable absolutely.
You've no doubt seen what is coming, and for that i cannot comment (out of the loop i'm afraid) but GameEx itself is way more powerful than it's given credit for, that i can vouch for.
One of the listed features is the ability to render HS themes, so IMO that is incorrect.
Although I have to admit that GameEX is not Hyperspin. :P
Possibly, but the question started with "With the release of GameEX Evolution (Preview)?" so I assume he meant Evo, and not GameEX. Otherwise, it would be the equivalent of asking "Since I bought a new car, will I be able to play the piano?" :)
I think he was answering for GameEx in its current state. ;)
I was yes ^_^ i had a mind fart :P I guess i need to read really carefully from this point on, to make sure i'm not answering about Evo heheh. My apologies :)
Thank you for the replies.
I was hoping that Game EX Evolution would support "wheel art" like Hyperspin FE does.
I am sure nevertheless when Game EX Evolution is release that it will be a great FE.
I did ask the question a while back on the Hyperspin forum if there are any other FE's that support "wheel art", and the response was yes, but no one could point me to a FE that did. Does any one in this forum know if there are any other FE's which can support "wheel art", and the name of the FE(s)? My investigations of many other FE's conclude that only Hyperspin supports "wheel art", but I would like to be proven wrong.
Thanks D
Since most HS themes involve wheel art, I believe that Evolution will also do so as well.
