hi all
does anyone no how to get rid of Lav video decoder icon in hidden icon tray on win7 and there r a few Lav icons there aswell. its still there even when i exit pinballx and when i put my cursor over then they dissapear can anyone help thanks.
Likely it is because they have already ceased to run, just not clearing the notification area in Win 7 (same occurs in Win 8). Since it disappears when you try to click on it, it means that the process for it is already likely closed. This would negate running a batch file to kill the process.
You do have the option to click the up arrow for the Notification Area, click Customize and locate "Windows Media Player LAV Audio Decoder and change the option to "Hide icon and notifications." Of course, this will suppress the visibility of what is loaded.
thanks mate but i have already done that hide icon and notification and it still there. its a red square icon with LAV in it and in notification it says its Pinballx Lav Video Decoder and i have changed it to Hide icon and notifications but it still there mate.
Oddness. Are you able to identify a service or process via Task Manager?
looked in task manager and there in nothing there. and if i look at a few tables i get about 10 of the icon there and when i move cursor over them they dissappear.
i have sorted it out it were set to show icon in tray in shark decoder settings thanks for the help tho.
Glad you got it sorted. WIll be good to know for others with the same issue.
Looks like you go to Start->Shark007 Codecs->Settings Application 32bit and under Misc tab, check "LAV tray icons OFF"
  • 1 month later...
Great tip, that gets rid of one of my system tray icons, but there still is one more, can't tell what it is because if I move the mouse over it, it disappears. its blue with a triangle in it, any ideas?
  • 1 year later...
Very old thread. I have not noticed the LAV icon since uninstalling Shark007 and installing the LAV filters downloadable from the PinballX.net site.
