Hi
I am having a problem with the latest GameEx - when I exit from MAME the screen starts flashing. Every 2 seconds the screen goes blank and while blank input is not processed for about 1 second, then it comes back again. The log file says 'Mouse input is disabled' every time it does this.
I have a older copy of GameEx on the same machine which does not have this problem. It doesn't matter if I use a new ini file or I take the ini file from the older working copy of GameEx. It also doesn't matter if I use a new copy of MAME or the same one used by the working installation.
If during the 2 seconds I select a new game, the system plays the game fine. It's only when I go back to GameEx does the screen start flashing again.
Any help appreciated.
17:48:26.6 24/05/2014: Running: cmd.exe /c C: C:\mame\mameui32.exe altbeast -rompath C:\mame\roms -nowindow -joy -skip_gameinfo
17:48:26.6 24/05/2014: Shutting down display
17:48:32.3 24/05/2014: Exiting game
17:48:32.8 24/05/2014: Shutting down RawInput Hook
17:48:32.9 24/05/2014: Writing MAME stats
17:48:32.9 24/05/2014: Plugin: Game Exit
17:48:32.9 24/05/2014: Plugin: Process Commands
17:48:32.9 24/05/2014: Restoring Window
17:48:33.0 24/05/2014: Reinitializing Graphics System
17:48:33.0 24/05/2014: Mouse Input is disabled
17:48:34.1 24/05/2014: Returning to GameEx
17:48:34.5 24/05/2014: Mouse Input is disabled
17:48:37.3 24/05/2014: Mouse Input is disabled
17:48:40.2 24/05/2014: Mouse Input is disabled
17:48:42.8 24/05/2014: Mouse Input is disabled
17:48:45.7 24/05/2014: Mouse Input is disabled
17:48:48.4 24/05/2014: Mouse Input is disabled
17:48:51.3 24/05/2014: Mouse Input is disabled
17:48:54.1 24/05/2014: Mouse Input is disabled
17:48:57.0 24/05/2014: Mouse Input is disabled
17:48:59.9 24/05/2014: Mouse Input is disabled
Would you mind supplying a copy of your gameex.ini files as well, please? Thanks!
I've realised what's wrong. VNC appears to be somehow incompatible with the latest GameEx. :-(
Strange that the old GameEx doesn't have a problem - maybe it's something fixable?
