hello everyone, I'm sorry but it certainly is a discussion already opened in another topics.
I have a problem with the settings of mame and in particular in the recognition of roms.
in practice they are not present in the list of all roms GameEx.
I own the romset 0.153 that was controlled with clrmamepro. I have used most versions of mame all in 64-bit version MameUI, mameplus, mame, mameuifx.
all data files have been updated to the latest versions on the net.
in the advanced settings of mame, I was turned on viewing all the roms (roms clones, imperfect games, casino games, mayhong games, adult games).
at each change of configuration was executed scaning of the list of rom.
but nothing to make the game list is not complete: the list stops at letter C and precisely to CarnEvil rom (1.0.1) also chd stop at the letter C.
Who can help me?
thanks
Hi Sergio. Are you using the integrated MAME support within GameEx? Did you "Update List?" at the end of the MAME menu while GameEx was running?
Whenever reporting a possible GameEx bug or error, please you submit a copy of your log.txt and gameex.ini file so we may quickly assist you. Refer to this link for additional information.
Please add the files Draco requested.
my log text
GameEx Support File Data
23:44:48.2 11/05/2014: Opening Configuration File
23:44:48.3 11/05/2014: GameEx: Version 13.26: Starting Log
23:44:48.3 11/05/2014: Operating System Platform: Win32NT
23:44:48.3 11/05/2014: Operating System Name: Windows 7
23:44:48.3 11/05/2014: Operating System Version: 6.1.7601
23:44:48.3 11/05/2014: Aero running
23:44:48.3 11/05/2014: Initializing Vista/Windows 7 volume control
23:44:48.3 11/05/2014: Getting CPU and RAM info
23:44:48.3 11/05/2014: Intel® Core i5 CPU 750 @ 2.67GHz, 4094MB
23:44:48.3 11/05/2014: 2,67Ghz - 4 Cores or CPU's
23:44:48.3 11/05/2014: Running Randomize()
23:44:48.3 11/05/2014: Loading PlugIns
23:44:48.3 11/05/2014: Loaded Plugin:"Virtual Drive Loader" Version 1.0.9 By Adultery
23:44:48.3 11/05/2014: PlugIn: "Virtual Drive Loader" Initialized OK
23:44:48.3 11/05/2014: Using Plugin System Version: 1,41
23:44:48.3 11/05/2014: Checking for applications to Launch On Startup
23:44:48.3 11/05/2014: Setting default net connection limit to 15
23:44:48.3 11/05/2014: Running Misc startup tasks
23:44:48.3 11/05/2014: Setting Menu types
23:44:48.3 11/05/2014: Getting Configuration Values
23:44:48.3 11/05/2014: Using Theme: Default - Media Center
23:44:48.3 11/05/2014: Checking for alternate Image Directory for Theme: Default - Media Center
23:44:48.3 11/05/2014: Using Images from theme: Default - Media Center V1\MEDIA\
23:44:48.3 11/05/2014: Initialising Video/MNG DLL's
23:44:48.3 11/05/2014: GameEx will check for media insertion (may affect performance)
23:44:48.3 11/05/2014: Is Media Center running?
23:44:48.3 11/05/2014: Checking/Creating LCD Registry values
23:44:48.3 11/05/2014: Check Media Center Exit/Start Mode
23:44:48.3 11/05/2014: Media Center Mode 2
23:44:48.3 11/05/2014: Video previews on. Warning: Only recommended on modern systems
23:44:48.3 11/05/2014: Snap Delay set to: 4
23:44:48.3 11/05/2014: Get other settings
23:44:48.3 11/05/2014: Desktop set to Hide ICONS and set Background to Black
23:44:48.3 11/05/2014: Set: Find emulator artwork on best match basis
23:44:48.3 11/05/2014: Start work for Form
23:44:48.3 11/05/2014: Getting Original Screen Size
23:44:48.3 11/05/2014: Opening Database Connection
23:44:48.4 11/05/2014: Initializing Component
23:44:48.5 11/05/2014: MAME Path is: C:\Users\sergio\Desktop\mame
23:44:48.5 11/05/2014: MAME EXE file is: mame64.exe
23:44:48.5 11/05/2014: ROM Path is: D:\mame
23:44:48.5 11/05/2014: Catver.ini is located at: C:\GameEx\DATA\catver.ini
23:44:48.5 11/05/2014: controls.ini is located at: C:\GameEx\DATA\controls.ini
23:44:48.5 11/05/2014: History.dat is located at: C:\GameEx\DATA\history.dat
23:44:48.5 11/05/2014: nplayers.ini is located at: C:\GameEx\DATA\nplayers.ini
23:44:48.5 11/05/2014: command.dat is located at: C:\GameEx\DATA\command.dat
23:44:48.5 11/05/2014: MAMEinfo.dat is located at: C:\GameEx\DATA\mameinfo.dat
23:44:48.5 11/05/2014: Loading Controls.ini map file
23:44:48.5 11/05/2014: Snap Path: Not Found
23:44:48.5 11/05/2014: Database Snap Path: Not Found
23:44:48.5 11/05/2014: Background Snap Path: Not Found
23:44:48.5 11/05/2014: AVI Snap Path: Not Found
23:44:48.5 11/05/2014: Flyer Path: Not Found
23:44:48.5 11/05/2014: Cabinet Path: Not Found
23:44:48.5 11/05/2014: Cabinet 3D Path: Not Found
23:44:48.5 11/05/2014: Title Path: Not Found
23:44:48.5 11/05/2014: PCB Path: Not Found
23:44:48.5 11/05/2014: Artwork Preview Path: Not Found
23:44:48.5 11/05/2014: Panel Path: Not Found
23:44:48.6 11/05/2014: Manual Path: Not Found
23:44:48.6 11/05/2014: Icon Path: Not Found
23:44:48.6 11/05/2014: Marquee Path: Not Found
23:44:48.6 11/05/2014: Applying Language/Text
23:44:48.6 11/05/2014: Text/Language: Italian
23:44:48.6 11/05/2014: Loading Language/Text
23:44:48.6 11/05/2014: Loading Custom Emulators
23:44:48.6 11/05/2014: Loading Emulator 1: Atari 5200
23:44:48.6 11/05/2014: Loading Emulator 2: Nintendo SNES
23:44:48.6 11/05/2014: Loading Emulator 3: Nintendo N64
23:44:48.6 11/05/2014: Loading Emulator 4: [Console] Sony Playstation (ePSXe)
23:44:48.6 11/05/2014: Checking if Steam enabled
23:44:48.6 11/05/2014: Cannot find steam path
23:44:48.6 11/05/2014: gamebase support enabled.
23:44:49.3 11/05/2014: Using 3D Alpha Blended Animations.
23:44:49.3 11/05/2014: Retrieving resolution setting
23:44:49.3 11/05/2014: Using General Font: Trebuchet MS
23:44:49.3 11/05/2014: Using Title Font: Trebuchet MS
23:44:49.3 11/05/2014: Initialising Direct3D
23:44:49.4 11/05/2014: Applying GameEx is Loading Image
23:44:49.4 11/05/2014: Creating Surfaces
23:44:49.5 11/05/2014: Creating Primary Surface - Windowed Mode
23:44:49.5 11/05/2014: Creating Back Buffer
23:44:49.5 11/05/2014: Loading graphic Surfaces
23:44:49.5 11/05/2014: Display is running at: 1440x900 32bit color, 75hz
23:44:49.5 11/05/2014: Adapter: NVIDIA GeForce GTX 465
23:44:49.5 11/05/2014: Max texture size: 16384x16384
23:44:49.5 11/05/2014: Available texture memory: -1330MB
23:44:49.5 11/05/2014: Initialising Bass Audio Library
23:44:49.5 11/05/2014: Creating Surfaces Misc and Dialogs
23:44:49.6 11/05/2014: Creating Surfaces Volume
23:44:49.6 11/05/2014: Creating Surfaces Arrows
23:44:49.6 11/05/2014: Creating Surfaces GameEXlogo Text
23:44:49.6 11/05/2014: Creating Surfaces Toolbar
23:44:49.6 11/05/2014: Creating Surfaces Toolbar Controls
23:44:49.6 11/05/2014: Creating Surfaces Backgrounds
23:44:49.6 11/05/2014: Creating Surfaces GameEx Logo
23:44:49.7 11/05/2014: Creating Surface Unselected
23:44:49.7 11/05/2014: Creating Surfaces Snaps
23:44:49.7 11/05/2014: Creating Surfaces Menu and List Bars
23:44:49.8 11/05/2014: Creating Fonts
23:44:49.8 11/05/2014: Creating Game Font
23:44:49.8 11/05/2014: Creating Game Font Faded
23:44:49.9 11/05/2014: Creating Title Font
23:44:49.9 11/05/2014: Restoring Title Font From Cache
23:44:49.9 11/05/2014: Creating Font Black
23:44:50.0 11/05/2014: Creating Font Black Small
23:44:50.0 11/05/2014: Fonts Created Succesfully
23:44:50.1 11/05/2014: Attempting to load game list
23:44:50.2 11/05/2014: Running: mame64.exe -help
23:44:52.6 11/05/2014: Running: C: C:\Users\sergio\Desktop\mame\mame64.exe -help > C:\Users\sergio\Desktop\mame\help.txt
23:44:55.9 11/05/2014:
23:44:55.9 11/05/2014: Detected MAME Version as: 0.153
23:44:55.9 11/05/2014: Now Outputing mame64.exe -Help
23:44:55.9 11/05/2014: --BEGIN--
23:44:55.9 11/05/2014: M.A.M.E. v0.153 (May 10 2014) - Multiple Arcade Machine Emulator
23:44:55.9 11/05/2014: Copyright Nicola Salmoria and the MAME team
23:44:55.9 11/05/2014: MAME is an emulator: it reproduces, more or less faithfully, the behaviour of
23:44:55.9 11/05/2014: several arcade machines. But hardware is useless without software, so an image
23:44:55.9 11/05/2014: of the ROMs which run on that hardware is required. Such ROMs, like any other
23:44:55.9 11/05/2014: commercial software, are copyrighted material and it is therefore illegal to
23:44:55.9 11/05/2014: use them if you don't own the original arcade machine. Needless to say, ROMs
23:44:55.9 11/05/2014: are not distributed together with MAME. Distribution of MAME together with ROM
23:44:55.9 11/05/2014: images is a violation of copyright law and should be promptly reported to the
23:44:55.9 11/05/2014: authors so that appropriate legal action can be taken.
23:44:55.9 11/05/2014: Usage: MAME [game] [options]
23:44:55.9 11/05/2014: MAME -showusage for a brief list of options
23:44:55.9 11/05/2014: MAME -showconfig for a list of configuration options
23:44:55.9 11/05/2014: MAME -listmedia for a full list of supported media
23:44:55.9 11/05/2014: MAME -createconfig to create a mame.ini
23:44:55.9 11/05/2014: For usage instructions, please consult the files config.txt and windows.txt.
23:44:55.9 11/05/2014: --END--
23:44:55.9 11/05/2014: MAME CMD options: -nowindow -joy -skip_gameinfo
23:44:55.9 11/05/2014: Initialising DirectInput for Gamepad support
23:44:55.9 11/05/2014: Unable to create a joystick device
23:44:55.9 11/05/2014: Loading Start Page
23:44:55.9 11/05/2014: Initializing MCE Remote
23:44:55.9 11/05/2014: Playing intro sound file
23:44:56.0 11/05/2014: Initialization OK! Starting GameEx!
23:44:56.0 11/05/2014: Testing Main Loop Once: Processing Frame
23:44:56.5 11/05/2014: Testing Main Loop Once: Main Loop ran successfully
23:44:59.8 11/05/2014: Validating: Emulator_1: Snap Path: C:\GameEx\DEMO\5200\video
23:44:59.8 11/05/2014: Validating: Emulator_1: Database: [Console] Atari 5200
23:44:59.8 11/05/2014: Validating: Emulator_1: Title Snap Path: C:\GameEx\DEMO\5200\titles
23:44:59.8 11/05/2014: Validating: Emulator_1: Box Art Path: C:\GameEx\DEMO\5200\boxart
23:44:59.8 11/05/2014: Validating: Emulator_1: Cart Art Path: C:\GameEx\DEMO\5200\cart
23:44:59.8 11/05/2014: Validating: Emulator_1: Manual Path: C:\GameEx\DEMO\5200\manual
23:44:59.8 11/05/2014: Validating: Emulator_2: Snap Path: C:\GameEx\DEMO\SNES\video
23:44:59.8 11/05/2014: Validating: Emulator_2: Database: [Console] Nintendo SNES
23:44:59.8 11/05/2014: Validating: Emulator_2: Title Snap Path: C:\GameEx\DEMO\SNES\titles
23:44:59.8 11/05/2014: Validating: Emulator_2: Box Art Path: C:\GameEx\DEMO\SNES\boxart
23:44:59.8 11/05/2014: Validating: Emulator_2: Cart Art Path: C:\GameEx\DEMO\SNES\cart
23:44:59.8 11/05/2014: Validating: Emulator_2: Manual Path: C:\GameEx\DEMO\SNES\manual
23:44:59.8 11/05/2014: Validating: Emulator_3: Snap Path: C:\GameEx\DEMO\N64\video
23:44:59.8 11/05/2014: Validating: Emulator_3: Database: [Console] Nintendo N64
23:44:59.8 11/05/2014: Validating: Emulator_3: Title Snap Path: C:\GameEx\DEMO\N64\titles
23:44:59.8 11/05/2014: Validating: Emulator_3: Box Art Path: C:\GameEx\DEMO\N64\boxart
23:44:59.8 11/05/2014: Validating: Emulator_3: Cart Art Path: C:\GameEx\DEMO\N64\cart
23:44:59.8 11/05/2014: Validating: Emulator_3: Manual Path: C:\GameEx\DEMO\N64\manual
23:44:59.8 11/05/2014: Validating: Emulator_4: Snap Path: C:\Assets\Sony Playstation\Snaps
23:44:59.8 11/05/2014: Validating: Emulator_4: Control Panel Path: C:\Assets\Sony Playstation\Controls
23:44:59.8 11/05/2014: Validating: Emulator_4: Database: [Console] Sony PlayStation
23:44:59.8 11/05/2014: Validating: Emulator_4: Title Snap Path: C:\Assets\Sony Playstation\Titles
23:44:59.8 11/05/2014: Validating: Emulator_4: Box Art Path: C:\Assets\Sony Playstation\Boxes
23:44:59.8 11/05/2014: Validating: Emulator_4: Cart Art Path: C:\Assets\Sony Playstation\Cartridges
23:44:59.8 11/05/2014: Validating: Emulator_4: Manual Path: C:\Assets\Sony Playstation\Manuals
23:45:09.7 11/05/2014: Restoring Emulator from Cache: 1
23:45:09.8 11/05/2014: Restoring Emulator Database From Cache: 1
23:45:09.8 11/05/2014: Restoring Emulator from Cache: 2
23:45:09.8 11/05/2014: Restoring Emulator Database From Cache: 2
23:45:09.8 11/05/2014: Restoring Emulator from Cache: 3
23:45:09.8 11/05/2014: Restoring Emulator Database From Cache: 3
23:45:09.9 11/05/2014: Restoring Emulator Database From Cache: 4
23:45:20.4 11/05/2014: Writing Game List to disk
23:45:20.4 11/05/2014: Updating MAME Game List
23:45:20.5 11/05/2014: Running: C: C:\Users\sergio\Desktop\mame\mame64.exe -listxml > C:\Users\sergio\Desktop\mame\listinfo.dat
23:45:45.8 11/05/2014: Opening Listinfo.dat
23:45:47.3 11/05/2014: Reading ListInfo.dat
23:45:58.8 11/05/2014: Reading ListInfo.dat - DONE
23:45:58.8 11/05/2014: Total verifyable roms: 0
23:45:58.8 11/05/2014: Processing ListInfo.dat
23:46:04.4 11/05/2014: Listinfo.dat Processing Complete
23:46:04.4 11/05/2014: Sorting MAME Game List
23:46:04.5 11/05/2014: Adding Catver.ini info to gamelist
23:46:05.2 11/05/2014: Importing MAME32 Favorites
23:46:05.2 11/05/2014: Updating Custom Folders
23:46:05.2 11/05/2014: Writing MAME Game List To File
23:46:26.8 11/05/2014: Writing MAME Game List To File
23:46:30.4 11/05/2014: Adding History.dat info to gamelist
23:46:31.5 11/05/2014: Adding History.dat Series info to gamelist
23:50:10.9 11/05/2014: Adding MAMEInfo.dat info to gamelist
23:53:22.5 11/05/2014: Adding Nplayers.ini info to gamelist
23:53:23.1 11/05/2014: Writing Game List to disk
23:53:23.4 11/05/2014: Updating Year List
23:53:23.4 11/05/2014: Updating Manufacturer List
23:53:23.4 11/05/2014: Updating Category List
23:53:23.4 11/05/2014: Writing Year List To File
23:53:23.4 11/05/2014: Writing Manufacturer List To File
23:53:23.4 11/05/2014: Writing Category List To File
23:53:23.4 11/05/2014: Loading Game List
23:53:23.5 11/05/2014: Creating: [Arcade] MAME.mdb
23:53:24.2 11/05/2014: Recreating ICONS
23:53:24.3 11/05/2014: Attract Mode Re-Enabled
23:55:09.0 11/05/2014: Exiting GameEx!
23:55:09.0 11/05/2014: Disposing all videos
23:55:09.0 11/05/2014: Deleting temporary Karaoke videos
23:55:09.0 11/05/2014: Disposing Image List
23:55:09.0 11/05/2014: Disposing Fonts
23:55:09.0 11/05/2014: Disposing Surfaces
23:55:09.0 11/05/2014: Saving Settings
23:55:09.0 11/05/2014: Shutting down Bass
23:55:09.0 11/05/2014: Disposing Plugins
23:55:09.0 11/05/2014: Closing database connection
23:55:09.0 11/05/2014: Checking for applications to Launch On Exit
23:55:09.0 11/05/2014: Media Center was not open when starting GameEx, so not launching
23:55:09.1 11/05/2014: Bye
Not sure what is going on with your setup, but to look at the time/date stamps, you are from the future, my friend! You may want to get the time/date set correctly on your PC.
Also, you are running MAME from C:\Users\sergio\Desktop\mame\. I am not certain if that is going to be an issue or not, but could we be hitting against a rights issue? Running from C:\WHATEVER FODLER NAME YOU PREFER\ is usually recommended.
... Or he's from Europe. Those crazy non-Americans! :P
Usually is YYYY-MM-DD however, none of the dates add up no matter how you format them.
Sorry to steer Steering off topic but
DD/MM/YYYY MM/DD/YYYY
11 / 05 / 2014 = 05 / 11 / 2014?
I was just saying I don't necessarily think he's doing something wacky with his system date; the log is probably just representative of the system date-time format.
Back on topic this problem sounds similar nay identical to the problem described here. In that case it was necessary for Tom to address the issue. I'm wondering if maybe we had some weird regression occurring here?
i think we had this problem allready. as i remember it doesnt had to do with GameEx. I think the history-file was bad formatted. there was some semicolon error in some of the history-data. i would try one from another source. i didnt have that problem anymore, but i am sad that i cannot contribute the right file right now. as my newest setup is on the wee-cade of my girlfriend :( . maybe someone else, have the right history-data-file.
PS: ooh, i have seen that nullPointer allready has pointed to that thread... ;) .... smooth operator he is :D
I stand corrected.. totally neglected the DD-MM-YYYY format. I believe an old bug may have creeped back in, or at least one very similar.
@Sergio1968 - I am flagging this topic for Tom's attention.
The CarnEvil bug is indeed back. Snip from 0.153 history.dat:
Jacob and Lisa take 2 [shotgun|shotgun's] from the shooting gallery
The | character is what seems to halt it. I've attached a new history.dat for you to try. Last time it worked for some and not for others so maybe there is more to it.
history_0.153_fixed.zip
PS: Yes we do dates backwards to you folks in the States ;)
No problem :) I've uploaded it to the download section as we had a surge of people with this problem last time and it may get lost in the forum if it happens again. You can find it HERE.
hello
Unfortunately, I always have a problem with mame, that is not shown the full list of games.
When I use UI Mameplus my list of games is 29110.
In GameEx my list is 6149 games.
If you want to see absolutely all of your roms you will need the following in MAME Settings:
Only Working Games = No
Allow Imperfect = Yes
Verify = No
Only Existing = Yes
Use Game Filter = No
Change these to "Gimme":
No Adult Games
No Mahjong Games
No Casino Games
Load GameEx, click Update List
So whats probably happening here is GameEx is verifying your games and they aren't passing the check. ;)
hello
I tried again GameEx with mame plus.I use the settings suggested by DazzleHP excluding Existing Only set = no.
I deleted the path of extra files (mameinfo, commanddat, controlini, etc ...).
GameEx list 11400 games.
outside of GameEx, Mameplus detect 29110 games
Does the MAME Plus count include all the mechanical games and whatnot? (i.e. whack a mole, slot machines pinball machines, etc.) GameEx will filter all those games out by default since they will never be playable in MAME without major changes to the emulation.
