Hello,
First, I want to say that I have no problems with 1.76, it's working perfectly with VP9.2.1.
But when I upgrade with 1.77, crashs occured when I exit from VP9.
It's not on every table, juste a few one.
I suspect VP9 to be not fully compatible with these tables, but 1.76 was working very well them and succeed in closing VP9 properly even if there was an ".net" error.
Now with 1.77, when I quit VP9, I have a Windows popup saying : " Vpinball 9.2.1 has stopped to work, Do you want to close ?"
Error detail :
Application : VPinball.exe
Version Framework : v4.0.30319
Description : le processus a été arrêté en raison d'une exception non gérée.
Informations sur l'exception : code d'exception c0000005, adresse d'exception 5C6065A4
It seems that 1.77 don't succeed to handle vp9 error.
I just came back to 1.76 and the vp error has no more effect on pinballx.
When reporting a possible bug or error, please submit a copy of the following files so we may quickly assist you:
For PinballX - pinballx.ini and log.txt (Click here for additional information on how to find these files and others that may be required)
I'm also having the same problem. Here are the two files requested...
20:57:38.0 3/24/2014: PinballX - Version 1.77
20:57:38.0 3/24/2014: Loading Settings
20:57:38.0 3/24/2014: Initialize Component
20:57:38.0 3/24/2014: Initialize Display
20:57:38.1 3/24/2014: Loading PlugIns
20:57:38.2 3/24/2014: Created DirectX BackGlass Window
20:57:38.2 3/24/2014: Created DirectX DMD Window
20:57:38.3 3/24/2014: Hiding Cursor
20:57:38.3 3/24/2014: Hiding Taskbar
20:57:38.3 3/24/2014: Load Game List
20:57:38.3 3/24/2014: Loading Database: Visual Pinball
20:57:38.4 3/24/2014: Finding and matching artwork and videos
20:57:38.5 3/24/2014: Loading Game Statistics and Scores
20:57:39.7 3/24/2014: Initialize Audio
20:57:39.8 3/24/2014: Set Keyboard Controls
20:57:39.8 3/24/2014: Initialize Joystick
20:57:39.8 3/24/2014: 1 Joystick Attached
20:57:39.8 3/24/2014: Started
20:57:49.8 3/24/2014: Launch System
20:57:49.8 3/24/2014: Waiting for threads
20:57:50.0 3/24/2014: Disposing display
20:57:51.8 3/24/2014: C:\Program Files (x86)\Visual Pinball\VPinball.exe /play -"C:\Program Files (x86)\Visual Pinball\Tables\Hurricane (Williams 1991).vpt"
20:57:51.8 3/24/2014: C:\PinballX\vpauto.exe
20:58:03.7 3/24/2014: Found PinMAME ROM: hurr_l2.nv
20:58:31.1 3/24/2014: Exit System Control Pressed
20:58:33.9 3/24/2014: Created DirectX BackGlass Window
20:58:33.9 3/24/2014: Created DirectX DMD Window
20:58:38.5 3/24/2014: Exiting
20:58:38.6 3/24/2014: Showing Taskbar
20:58:38.6 3/24/2014: Unhiding Mouse Cursor
20:58:38.6 3/24/2014: Disposing Plugins
20:58:38.6 3/24/2014: Saving Settings
PinballX.ini
[Display]
Monitor=0
Rotate=270
Windowed=False
WindowWidth=480
WindowHeight=720
WindowX=0
WindowY=65
PlayFieldBrightness=230
WheelTextColor=ffffffff
InfoTextColor=ffffffff
InfoTextOutlineColor=ff000000
FilterTextColor=ffffffff
MenuColor=ffffa500
[backGlass]
monitor=1
x=0
y=0
width=1360
height=768
[DMD]
monitor=2
x=0
y=188
width=1373
height=380
[FileSystem]
EnableFileMatching=True
[interface]
DesktopModeEnabled=False
EnableAdditionalDetail=True
ShowSystem=True
ShowRatings=True
[Audio]
StreamVolume=90
SampleVolume=90
PlaySoundInVideos=True
[startup]
playsound=True
playvideo=False
StartWithWindows=No
[KeyCodes]
quit=27
left=37
right=39
select=13
rotate=82
pageleft=33
pageright=34
exitemulator=27
ingame=80
screenshot=83
screenshotbackglass=66
instructions=73
[JoyCodes]
quit=8
left=7
right=3
select=10
rotate=
pageleft=5
pageright=2
exitemulator=8
ingame=
instructions=
[Text]
Line1=Free Play
Line2=Press Start
[FuturePinball]
Enabled=False
WorkingPath=h:\-PINBALL-\-FUTURE PINBALL-
TablePath=h:\-PINBALL-\-FUTURE PINBALL-\Tables
Executable=Future Pinball.exe
LaunchBeforeEnabled=false
LaunchBeforeWorkingPath=
LaunchBeforeHideWindow=False
LaunchBeforeWaitForExit=True
LaunchAfterEnabled=False
LaunchAfterWorkingPath=
LaunchAfterHideWindow=False
LaunchAfterWaitForExit=True
MouseClickFocus=True
[VisualPinball]
WorkingPath=C:\Program Files (x86)\Visual Pinball
TablePath=C:\Program Files (x86)\Visual Pinball\Tables
Executable=VPinball.exe
NVRAMPath=C:\Program Files (x86)\Visual Pinball\VPinMame\nvram
[ExitScreen]
EnableExit=True
EnableShutdown=True
[startupProgram]
Enabled=false
WorkingPath=
Paramaters=
HideWindow=true
WaitForExit=false
[ExitProgram]
Enabled=false
WorkingPath=
Paramaters=
HideWindow=False
WaitForExit=
[AttractMode]
Timer=1
ShowFor=15
[system_1]
Name=Pinball FX2
Enabled=False
WorkingPath=C:\Steam
TablePath=C:\Steam\Tables
Executable=PinballFX.exe
Parameters=
[system_2]
Name=MAME
Enabled=False
TablePath=C:\
Executable=mamep64.exe
Parameters=[TABLEFILE]
[AutoExit]
Enabled=False
Minutes=10
[Login]
Enabled=False
[internal]
lastselected=Hurricane (Williams 1991)Hurricane (Williams 1991)VisualPinball
filter_year=
filter_company=
filter_custom=
filtername=Tables
[setupWizard]
EmuPath1=C:\Emulators
AssetPath1=C:\Assets
RomPath1=C:\Roms
DefaultPathPrompt=True
DownloadDatabasePrompt=True
DownloadEmulatorPrompt=True
WizardMode=3
CustomArray=
SearchArray=Audio Settings
SavePosition=False
SectionIndex=0
SearchText=video
EmulatorIndex=0
EmulatorGroupIndex=0
DaphneIndex=0
HTMLAppsIndex=0
ExternalAppsIndex=0
RadioStationsIndex=0
NewsFeedsIndex=0
MappedDrivesIndex=0
SystemIndex=0
ShowPanel=True
FontSize=1
WindowState=0
WindowSize=650,478
WindowLocation=-953,173
[Plugin_1]
Enabled=False
Name=PlugInSpeech.dll
[Plugin_2]
Enabled=False
[Plugin_3]
Enabled=False
Name=Xpadder Plugin.dll
Thank you for answering so quickly but I still have the crash window which prevent PinballX from restarting until I click "OK to close" it.
No, that didn't make it go away. In fact, the close window box stayed up longer than it did before. Log file attached:
16:33:05.0 3/25/2014: PinballX - Version 1.77
16:33:05.0 3/25/2014: Loading Settings
16:33:05.0 3/25/2014: Initialize Component
16:33:05.1 3/25/2014: Initialize Display
16:33:05.1 3/25/2014: Loading PlugIns
16:33:05.2 3/25/2014: Created DirectX BackGlass Window
16:33:05.3 3/25/2014: Created DirectX DMD Window
16:33:05.4 3/25/2014: Hiding Cursor
16:33:05.4 3/25/2014: Hiding Taskbar
16:33:05.4 3/25/2014: Load Game List
16:33:05.4 3/25/2014: Loading Database: Visual Pinball
16:33:05.4 3/25/2014: Finding and matching artwork and videos
16:33:05.5 3/25/2014: Loading Game Statistics and Scores
16:33:06.7 3/25/2014: Initialize Audio
16:33:06.8 3/25/2014: Set Keyboard Controls
16:33:06.8 3/25/2014: Initialize Joystick
16:33:06.8 3/25/2014: 1 Joystick Attached
16:33:06.8 3/25/2014: Started
16:33:19.8 3/25/2014: Launch System
16:33:19.8 3/25/2014: Waiting for threads
16:33:20.1 3/25/2014: Disposing display
16:33:22.2 3/25/2014: C:\Program Files (x86)\Visual Pinball\VPinball.exe /play -"C:\Program Files (x86)\Visual Pinball\Tables\Creature from the Black Lagoon (Bally 1992).vpt"
16:33:22.3 3/25/2014: C:\PinballX\vpauto.exe
16:33:32.5 3/25/2014: Found PinMAME ROM: cftbl_l4.nv
16:33:51.0 3/25/2014: Exit System Control Pressed
16:33:58.8 3/25/2014: Created DirectX BackGlass Window
16:33:58.9 3/25/2014: Created DirectX DMD Window
16:34:12.9 3/25/2014: Exiting
16:34:13.0 3/25/2014: Showing Taskbar
16:34:13.1 3/25/2014: Unhiding Mouse Cursor
16:34:13.1 3/25/2014: Disposing Plugins
16:34:13.1 3/25/2014: Saving Settings
Mine does return to PinballX. I open a table and then when I close the table I get a screen that says "Visual Pinball has stopped working" and gives the option to check online for a solution or close the program. This window goes away after about 3 seconds and then returns to PinballX.
For me : I open a table and then when I close the table I get a screen that says "Visual Pinball has stopped working" and gives the option to check online for a solution or close the program. This window doesnt go away until I click manually. Then after about 3 seconds it returns to PinballX.
The error doesn't clear but when manually cleared it returns to pinballx
What versions of windows are you both running?
Just to be clear though the best we are going to get is to clear the error and have everything still running properly.
I'm running Windows 7 Ultimate 64 bit, but I fixed the problem!
I noticed that for a split second just before the error popped up that the Visual Pinball exit screen was popping up. I had read somewhere that you need to disable that function for it to work properly with front-end software. I went into the keys preferences in visual pinball and checked the box to disable the esc key and removed my button assignment from the exit key. So if I ran a table directly from visual pinball I would have no way to exit. When I run any game through PinballX the error is gone and the tables exit smoothly.
I'm running Windows 7 professionel 64bits.
I tried to to check the box to disable the esc key and removed my button assignment from the exit key but it doesn't change anyhing.
Still a crash wich does not clear.
An update : I solved my problem with a new Vpinball.exe. I am now testing : "VP9_DX9_test13.exe"
At the moment this version is working very nice, with no crash like with 9.2.1.
So as a consequence, PinballX 1.77 is working fine too ...
I think a lot of peoples issues are due to running "test" versions of VP. I too am running latest(always do) and 1.77 started glitch but has been fine for me lately. So happy about the nvram saving!
It would still be nice to have PinballX monitor for these VP crashes and close out the popup dialog, so Pinballx menu resumes control. I have attached the vp dx9test13 screenshot. For a VP9.2.1 crash the windows dialog title is "Visual Pinball 9.2.1"
post-25949-0-86224900-1396026721_thumb.p
PinballX.ini
That's right, 1.76 was dealing with crash perfectly, it's a regression that 1.77 do not (even if I know that bugs are not obvious at all ...)
