Hello
I'm trying to use Map Magician but I always get
"Because of your settings your map file will be blank"
I point to my ROM path with sub folders ticked (Atari 2600 unzipped to *.a26).
It asks me to select the extensions and correctly lists them.
I tick a26.
I leave the dat path blank.
When I click "Create Groups" or "View Map" (it tells me first missing ROMS excluded as I haven't got a dat file, which is correct) I always get the "map file will be blank"
Am I doing something stupid?
Thanks in advance
Sorry its not deliberate LOL!
No rush, I just thought I was being thick. I went through your instructions several times.
I do appreciate your time
Cheers
:D :D :D :D :D :D :D :D :D :D
Would you please post a screenshot of the map magician so I can see what your settings are?
You can click on 'More Reply Options' , and then attach the pic to your post.
Hello Tempest
Thanks for your help.
I've attached the screen.
Interestingly, when I select the ROM path (U:/Atari/Atari2600/_ROMS) it says there isn't any files matching my extensions of a26 or bin, even though I have scan sub folders and there is ROMS with these extensions. It must find the files as the box then appears asking me to tick the extensions. But when I click OK the ROM path reverts back to the path in the screenshot.
My ROMS are stored like this
../_ROMS
../_ROMS/1
../_ROMS/A
../_ROMS/B
etc etc
:D
post-26365-0-80211800-1395739438_thumb.j
