running 1.76 but problem started a couple versions earlier... vpinmame is not saving scores, volume or adjustments only when running through pinballx. works fine directly running vp manually.
So glad you mentioned this....
I'm not crazy after all
I am testing submitting hiscores from pinballx , using plugin pinemhi leaderboard but every once in a while the score is the same as the previous one.
So i kept thinking it was my program that did that......tried it out not using the plugin and indeed....the problem occurs.
Maybe the exit method is causing this?
Strange thing is it doesn't happen all the time (for me)
I can confirm with 100% certainty its a pinballx issue. Tried for hours and is only a problem through frontend. It used to work just fine but couldn't tell you what version broke it...FYI I tried moving vpinmame install, everything is admin rights read write, deleted all nvram files but front end just don't allow saving of nvram.
my juke box also was "broke" around same time I script it to backglass and jukebox is now behind black windowed backglass..again not sure what version broke that either.
I should save old versions so I can go back and inform what version works and what version don't so maybe would be easier for tom to find issue.
did some digging around and found version 1.67 and works(50% of time)or less in that version..1.71-1.72 not working..
Please post your pinballx.ini and log.txt files, fellas! Tom will need these. Thanks!
ini file
[Display]
Monitor=0
rotate=270
Windowed=False
WindowWidth=480
WindowHeight=720
WindowX=0
WindowY=65
PlayFieldBrightness=230
WheelTextColor=ffffffff
InfoTextColor=ffffffff
InfoTextOutlineColor=ff000000
FilterTextColor=ffffffff
FullScreenWindowed=False
[backGlass]
monitor=1
x=12
y=10
width=1280
height=1024
[DMD]
Enabled=False
monitor=2
x=0
y=0
width=900
height=300
[interface]
DesktopModeEnabled=False
[Audio]
StreamVolume=10
SampleVolume=10
PlaySoundInVideos=False
[startup]
playsound=False
playvideo=False
[KeyCodes]
quit=27
left=160
right=161
select=13
rotate=84
pageleft=49
pageright=53
exitemulator=27
ingame=80
screenshot=83
screenshotbackglass=86
instructions=73
[JoyCodes]
quit=10
left=0
right=1
select=2
rotate=
pageleft=4
pageright=5
exitemulator=6
ingame=13
[Text]
Line1=You unlock this pinball with the key of imagination
Line2=Press flipper buttons to scroll through games
[FuturePinball]
WorkingPath=C:\Games\Future Pinball\BAM
TablePath=C:\Games\Future Pinball\Tables
Executable=FPLoader.exe
Parameters=/open "[TABLEPATH]\[TABLEFILE]" /play /exit /arcaderender /STAYINRAM
LaunchBeforeEnabled=false
LaunchBeforeWorkingPath=
LaunchBeforeHideWindow=False
LaunchBeforeWaitForExit=True
LaunchAfterEnabled=False
LaunchAfterWorkingPath=
LaunchAfterHideWindow=False
LaunchAfterWaitForExit=True
MouseClickFocus=True
[VisualPinball]
WorkingPath=C:\Program Files (x86)\Visual Pinball
TablePath=C:\Program Files (x86)\Visual Pinball\Tables
Executable=VPinball.exe
LaunchBeforeEnabled=False
LaunchBeforeWorkingPath=C:\PinballX\Plugins\QuickLaunch
LaunchAfterEnabled=True
LaunchAfterWorkingPath=C:\PinballX
LaunchAfterExecutable=ledclear.bat
LaunchAfterWaitForExit=False
LaunchAfterParameters=
NVRAMPath=C:\Program Files (x86)\Visual Pinball\vpinmame\nvram
[ExitScreen]
EnableExit=True
EnableShutdown=True
[startupProgram]
Enabled=false
WorkingPath=
Paramaters=
HideWindow=true
WaitForExit=false
[ExitProgram]
Enabled=false
WorkingPath=
Paramaters=
HideWindow=False
WaitForExit=
[AttractMode]
Timer=2
ShowFor=30
[system_1]
Name=Pinball FX2
WorkingPath=C:\Program Files (x86)\Microsoft Game Studios\Pinball FX2
TablePath=
Executable=Pinball FX2.exe
Parameters=-applaunch 226990
LaunchBeforeEnabled=True
LaunchBeforeWorkingPath=C:\PinballX\Scripts
LaunchBeforeExecutable=PinballFX2.exe
LaunchBeforeWaitForExit=False
LaunchBeforeParameters=[TABLEFILE]
[Plugin_1]
Enabled=False
Name=PlugInSpeech.dll
[setupWizard]
EmuPath1=C:\Emulators
AssetPath1=C:\Assets
RomPath1=C:\Roms
DefaultPathPrompt=True
DownloadDatabasePrompt=True
DownloadEmulatorPrompt=True
WizardMode=0
CustomArray=
SearchArray=
SavePosition=False
SectionIndex=0
SearchText=
EmulatorIndex=0
EmulatorGroupIndex=0
DaphneIndex=0
HTMLAppsIndex=0
ExternalAppsIndex=0
RadioStationsIndex=0
NewsFeedsIndex=0
MappedDrivesIndex=0
SystemIndex=1
ShowPanel=True
FontSize=1
WindowState=0
WindowSize=1183,787
WindowLocation=85,103
[internal]
lastselected=Medieval MadnessMedieval-Madness_VP91x_2.4.3FSVisualPinball
filter_year=
filter_company=
filter_custom=Visual Pinball
filtername=Visual Pinball Tables
[Plugin_2]
Enabled=False
[Plugin_3]
Enabled=False
Name=Xpadder Plugin.dll
[system_2]
Name=Jukebox
Executable=newjuke.exe
Parameters=
LaunchBeforeExecutable=jukebox.bat
LaunchAfterExecutable=LEDBlinky.exe 2
LaunchAfterWorkingPath=C:\PinballX\LEDBlinky
[system_3]
Name=mame
WorkingPath=C:\PinballX\mameplus
TablePath=C:\PinballX\mameplus
Executable=mamep.exe
[system_4]
Name=Visualpinball2
[system_5]
Name=laser
WorkingPath=c:\DRAGONS LAIR
TablePath=c:\DRAGONS LAIR
Executable=Lair.bat
LaunchBeforeWorkingPath=c:\DRAGONS LAIR
LaunchBeforeExecutable=Lair.bat
[Login]
Enabled=False
[system_6]
Name=The Pinball Arcade
WorkingPath=C:\Program Files (x86)\FarSight Studios\The Pinball Arcade
TablePath=
Executable=PinballArcade.exe
LaunchBeforeExecutable=The Pinball Arcade.exe
Parameters=-applaunch 238260
LaunchAfterExecutable=The Pinball Arcade.ahk
LaunchAfterWorkingPath=C:\PinballX\Scripts
LaunchAfterParameters=[TABLEFILE]
[system_7]
Name=NEW VP DX9
Executable=VP9DX9.exe
log
log
01:03:11.4 3/12/2014: PinballX - Version 1.76
01:03:11.4 3/12/2014: Loading Settings
01:03:11.4 3/12/2014: Initialize Component
01:03:11.4 3/12/2014: Initialize Display
01:03:11.4 3/12/2014: Loading PlugIns
01:03:11.6 3/12/2014: Created DirectX BackGlass Window
01:03:11.6 3/12/2014: Hiding Cursor
01:03:11.7 3/12/2014: Hiding Taskbar
01:03:11.7 3/12/2014: Load Game List
01:03:11.7 3/12/2014: Loading Database: Future Pinball
01:03:11.7 3/12/2014: Loading Database: Visual Pinball
01:03:11.7 3/12/2014: Loading Database: Pinball FX2
01:03:11.7 3/12/2014: Loading Database: Jukebox
01:03:11.7 3/12/2014: Loading Database: mame
01:03:11.7 3/12/2014: Loading Database: laser
01:03:11.7 3/12/2014: Loading Database: The Pinball Arcade
01:03:11.7 3/12/2014: Loading Database: NEW VP DX9
01:03:11.7 3/12/2014: Loading Custom Database: Visual Pinball 2
01:03:11.7 3/12/2014: Finding and matching artwork and videos
01:03:24.5 3/12/2014: Loading Game Statistics and Scores
01:03:24.9 3/12/2014: Initialize Audio
01:03:24.9 3/12/2014: Set Keyboard Controls
01:03:24.9 3/12/2014: Initialize Joystick
01:03:24.9 3/12/2014: 1 Joystick Attached
01:03:24.9 3/12/2014: Started
01:03:53.8 3/12/2014: Launch System
01:03:53.8 3/12/2014: Waiting for threads
01:03:53.8 3/12/2014: Disposing display
01:03:55.1 3/12/2014: C:\Program Files (x86)\Visual Pinball\VPinball.exe /play -"C:\Program Files (x86)\Visual Pinball\Tables\Medieval-Madness_VP91x_2.4.3FS.vpt"
01:03:55.1 3/12/2014: C:\PinballX\vpauto.exe
01:04:00.4 3/12/2014: Found PinMAME ROM: mm_10.nv
01:04:23.9 3/12/2014: Exit System Control Pressed
01:04:26.6 3/12/2014: C:\PinballX\ledclear.bat
01:04:26.8 3/12/2014: Created DirectX BackGlass Window
01:04:29.4 3/12/2014: Launch System
01:04:29.4 3/12/2014: Waiting for threads
01:04:29.4 3/12/2014: Disposing display
01:04:30.7 3/12/2014: C:\Program Files (x86)\Visual Pinball\VPinball.exe /play -"C:\Program Files (x86)\Visual Pinball\Tables\Medieval-Madness_VP91x_2.4.3FS.vpt"
01:04:30.7 3/12/2014: C:\PinballX\vpauto.exe
01:04:36.0 3/12/2014: Found PinMAME ROM: mm_10.nv
01:04:44.7 3/12/2014: Exit System Control Pressed
01:04:47.4 3/12/2014: C:\PinballX\ledclear.bat
01:04:47.9 3/12/2014: Created DirectX BackGlass Window
01:04:49.8 3/12/2014: Exiting
01:04:49.9 3/12/2014: Showing Taskbar
01:04:49.9 3/12/2014: Unhiding Mouse Cursor
01:04:49.9 3/12/2014: Disposing Plugins
01:04:49.9 3/12/2014: Saving Settings
Just to add a comment to this ... I have only been using PinX since 1.74 but the way that it shuts down VP is not working correctly as it does not allow DOF to exit properly meaning that VP was not shut down correctly. This means that the command to kill the LedWiz, that comes from DOF, never happens and so whatever toys were running when you exited the table back to PBX continue to run until the next table is selected. If you run only VP this works correctly by hitting the "Q" 2 times.
Not to hijack the thread but these two are linked issues and also after reading this I tested again and only 25% of the time the high score saves. Out of 10 games played and high scores made 2 of them saved. All 5 games only in VP saved just fine.
I would like to see this fixed as this is the second time I have posted about VP not exiting correctly even though the Frontend works fine.
It's basically a forgone conclusion that Tom will see this thread, and followup accordingly with due diligence. In the meantime I would urge patience. I appreciate that this issue may have been reported on more than one occasion, but bear in mind that PinballX is maintained by a single person and that he supports several software projects simultaneously in addition to having a full time job. Tom can only work so quickly no matter how entitled anyone may feel that he respond instantly to bug reports.
I was not rushing at all and in fact Tom took time for me a couple weeks ago to figure out a stupid mistake I made. Heck, I am probably wrong about this also but it was related so I wanted to report my findings.
Great work and thanks Tom
I was not rushing at all and in fact Tom took time for me a couple weeks ago to figure out a stupid mistake I made. Heck, I am probably wrong about this also but it was related so I wanted to report my findings. Great work and thanks Tom
Les, i f you don't mind, please post your pinballx.ini and log.txt files so Tom can have a more complete sampling. Thanks!
I never thought about it as I use a clear script but les is correct ledwiZ does leave ports on when exiting in pinballx so maybe VRAM not saving is related! As both nvram and ledwiz clear when running vp direct.
I think it just needs a delay waiting for VP for close but I am not even sure it is possible to close VP without killing it. If it is something that used to work though there is hope!
See if the attached is any better,
PinballX.zip
Isn't it possible to send the close vp and wait till vpm window has been closed and then go on with the rest of the actions?
That would ensure that vpm closes correctly.
no change for me... i tried with and without clear script and still no nvram save.
Is odd really....how does hyperpin differ from pinballx when it closes VP?
I can remember they had problems using the esc button...maybe you could try mapping the exit to another key?
For instance the e button...
I am using "e" maybe I should try "esc" instead? Lol heck can't hurt to try
Well that can't be it then :)
I am using esc and have the same problem
Couldn't test it myself as i was at work...
I tried "e", "esc" both ways and same result nvram just will not save. I wonder if its just a win7 issue? "e" or"esc" running vp direct saved nvram either way
sorry this is late but I had a couple of errors with these logs I am posting
Log
03:13:05.1 3/15/2014: PinballX - Version 1.76
03:13:05.1 3/15/2014: Loading Settings
03:13:05.2 3/15/2014: Initialize Component
03:13:05.3 3/15/2014: Initialize Display
03:13:07.5 3/15/2014: Start with windows is set so waiting 5 seconds. Boot Time = 3/15/2014 3:12:55 AM
03:13:15.0 3/15/2014: Loading PlugIns
03:13:15.9 3/15/2014: Created DirectX BackGlass Window
03:13:15.9 3/15/2014: Created DirectX DMD Window
03:13:16.0 3/15/2014: Hiding Cursor
03:13:16.1 3/15/2014: Hiding Taskbar
03:13:16.1 3/15/2014: Start with windows is set so waiting 5 seconds
03:13:21.1 3/15/2014: Loading Font
03:13:21.1 3/15/2014: Load Game List
03:13:21.1 3/15/2014: Loading Database: Visual Pinball
03:13:21.2 3/15/2014: Loading Database: Pinball FX2
03:13:21.2 3/15/2014: Loading Database: Mame64
03:13:21.2 3/15/2014: Loading Custom Database: Zen FX2
03:13:21.2 3/15/2014: Finding and matching artwork and videos
03:13:21.4 3/15/2014: Loading Game Statistics and Scores
03:13:21.9 3/15/2014: Initialize Audio
03:13:22.2 3/15/2014: Set Keyboard Controls
03:13:22.2 3/15/2014: Initialize Joystick
03:13:22.3 3/15/2014: No Joysticks Attached
03:13:22.3 3/15/2014: Started
03:14:56.3 3/15/2014: Launch System
03:14:56.3 3/15/2014: Waiting for threads
03:14:56.3 3/15/2014: Disposing display
03:14:58.3 3/15/2014: C:\Program Files (x86)\Visual Pinball\VPinball.exe /play -"C:\Program Files (x86)\Visual Pinball\Tables\Attack from Mars 9.2.vpt"
03:14:58.3 3/15/2014: C:\PinballX\vpauto.exe
03:15:05.7 3/15/2014: Found PinMAME ROM: afm_113b.nv
03:16:12.1 3/15/2014: Created DirectX BackGlass Window
03:16:12.2 3/15/2014: Created DirectX DMD Window
03:16:13.8 3/15/2014: Exit System Control Pressed
03:16:17.7 3/15/2014: C:\LedWiz\Ledwiz87.exe
03:16:18.0 3/15/2014: Created DirectX BackGlass Window
03:16:18.0 3/15/2014: Created DirectX DMD Window
03:16:32.3 3/15/2014: Exiting
03:16:32.4 3/15/2014: Showing Taskbar
03:16:32.4 3/15/2014: Unhiding Mouse Cursor
03:16:32.4 3/15/2014: Disposing Plugins
03:16:32.4 3/15/2014: Saving Settings
03:16:32.4 3/15/2014: Waiting for Online Thread
.ini
[Display]
Monitor=0
rotate=270
Windowed=False
WindowWidth=480
WindowHeight=720
WindowX=0
WindowY=65
WheelTextColor=ff2d2dff
WheelTextOutlineColor=ff00ff00
InfoTextColor=ff400080
InfoTextOutlineColor=ff00ff00
FilterTextColor=ff0000ff
FilterTextOutlineColor=ff00ff00
MenuColor=ff0000ff
[backGlass]
monitor=1
x=0
y=0
width=1360
height=768
[DMD]
monitor=2
x=25
y=115
width=750
height=375
[FileSystem]
EnableFileMatching=False
[interface]
EnableAdditionalDetail=True
ShowSystem=True
ShowRatings=True
[Audio]
StreamVolume=40
SampleVolume=50
PlaySoundInVideos=True
[startup]
playsound=False
playvideo=True
StartWithWindows=Yes
[KeyCodes]
quit=27
left=160
right=161
select=49
rotate=82
pageleft=90
pageright=191
exitemulator=81
ingame=69
screenshot=83
screenshotbackglass=66
instructions=73
[JoyCodes]
quit=
left=
right=
select=
rotate=
pageleft=
pageright=
exitemulator=
ingame=
instructions=
[Text]
Line1=<< Use Flippers to Scroll >>
Line2=Press Start to Select Game
[FuturePinball]
Enabled=False
WorkingPath=
TablePath=
Executable=
Parameters=
FPRAMPath=
[VisualPinball]
LaunchAfterWorkingPath=C:\LedWiz
LaunchAfterExecutable=Ledwiz87.exe
LaunchAfterHideWindow=True
NVRAMPath=C:\Program Files (x86)\Visual Pinball\VPinMame\nvram
[ExitScreen]
EnableExit=True
EnableShutdown=True
[startupProgram]
Enabled=False
WorkingPath=
Executable=
Paramaters=
HideWindow=False
WaitForExit=false
[ExitProgram]
Enabled=False
WorkingPath=
Executable=
Paramaters=
HideWindow=False
WaitForExit=False
[AttractMode]
Timer=1
ShowFor=30
[system_1]
Name=Pinball FX2
TablePath=
Executable=Steam.exe
Parameters=-applaunch 226980
[system_2]
Name=Mame64
WorkingPath=D:\Mame
TablePath=D:\Mame\romdummy
Executable=mame64.exe
[AutoExit]
Minutes=10
[internal]
lastselected=AvengersAvengersVisualPinball
filter_year=
filter_company=
filter_custom=
filtername=Tables
[setupWizard]
RomPath1=C:\Roms
WizardMode=1
CustomArray=
SearchArray=
SavePosition=False
SectionIndex=18
SearchText=
EmulatorIndex=0
DaphneIndex=0
HTMLAppsIndex=0
ExternalAppsIndex=0
NewsFeedsIndex=0
MappedDrivesIndex=0
SystemIndex=1
ShowPanel=True
FontSize=1
WindowState=0
WindowSize=1168,852
WindowLocation=543,46
Exit is still mapped to esc for me in PinX and VP exits using "Q"
I have not tried the new exe you posted Tom ... I will tomorrow ... it is late here.
Interesting. We all have vpinmame in programs folder...while it works fine from vp direct I wonder if pinballx has a problem writing to program folder of windows?
I think I have fixed it and provided a better solution. I also noticed the playfied video freezing up after launching a few tables which hopefully is fixed now too.
Please try the attached. As always on some OS's PinballX needs to run as admin.
PinballX.zip
