Hey Tom.
When GameEx goes into attract mode, I have to kill GameExtender from the task manager before it will run anything. After I kill it, everything goes as expected. Nothing in it, but here's my log file (you can see by the pause between starting attract and the cmd line actually being sent). Must be something wrong with the new update because it was working fine last revision.
LOG FILES
GameExtender Log:
13:21:25.3  3/3/2014:  Starting GameExtender on: 192.168.25.150:129013:21:25.3  3/3/2014:  GameExtender using specific custom images for systems.13:21:25.3  3/3/2014:  Parsing IP Address of: 192.168.25.15013:21:25.3  3/3/2014:  Mapping IP Address to port: 129013:21:25.3  3/3/2014:  Creating Socket13:21:25.3  3/3/2014:  Binding Socket13:21:25.3  3/3/2014:  Listening......13:21:25.3  3/3/2014:  Listening...... Initialization success......13:21:27.9  3/3/2014:  Accepted First connection13:21:27.9  3/3/2014:  Handling First connection13:21:27.9  3/3/2014:  GET: getimage gxre1366|768endre justi    QUERY: 13:21:27.9  3/3/2014:  First Connection handling Success13:21:27.9  3/3/2014:  Waiting for more connections13:21:33.9  3/3/2014:  GET: getimage gxre1366|768endre justi    QUERY: 13:21:39.3  3/3/2014:  GET: getimage gxre1366|768endre justi    QUERY: 13:21:44.6  3/3/2014:  GET: getimage gxre1366|768endre justi    QUERY:
GameEx log:
13:21:18.8  3/3/2014:  Opening Configuration File13:21:18.8  3/3/2014:  GameEx: Version 13.22: Starting Log13:21:18.8  3/3/2014:  Operating System Platform: Win32NT13:21:18.8  3/3/2014:  Operating System Name: Windows 713:21:18.9  3/3/2014:  Operating System Version: 6.1.760113:21:18.9  3/3/2014:  Aero running13:21:18.9  3/3/2014:  Initializing Vista/Windows 7 volume control13:21:18.9  3/3/2014:  Getting CPU and RAM info13:21:18.9  3/3/2014:  Intel(R) Core(TM)2 Duo CPU E7500 @ 2.93GHz, 3327MB13:21:18.9  3/3/2014:  2.93Ghz - 2 Cores or CPU's13:21:18.9  3/3/2014:  Running Randomize()13:21:18.9  3/3/2014:  Loading PlugIns13:21:18.9  3/3/2014:  Loaded Plugin:"Virtual Drive Loader" Version 1.0.9 By Adultery13:21:19.0  3/3/2014:  PlugIn: "Virtual Drive Loader" Initialized OK13:21:19.0  3/3/2014:  Using Plugin System Version: 1.4113:21:19.0  3/3/2014:  Loaded Plugin:"Game Info Plugin" Version 1.2.6 By Adultery13:21:20.1  3/3/2014:  PlugIn: "Game Info Plugin" Initialized OK13:21:20.1  3/3/2014:  Using Plugin System Version: 1.4113:21:20.1  3/3/2014:  Loaded Plugin:"Game Tagger" Version 1.0.0 By Adultery13:21:20.3  3/3/2014:  PlugIn: "Game Tagger" Initialized OK13:21:20.3  3/3/2014:  Using Plugin System Version: 1.413:21:20.3  3/3/2014:  Loaded Plugin:"Hi-Score Snapper" Version 1.0.2 By Adultery13:21:20.5  3/3/2014:  PlugIn: "Hi-Score Snapper" Initialized OK13:21:20.5  3/3/2014:  Using Plugin System Version: 1.4113:21:20.5  3/3/2014:  Loaded Plugin:"MAME Commander 2" Version 2.1.6u2 By Adultery13:21:20.6  3/3/2014:  PlugIn: "MAME Commander 2" Initialized OK13:21:20.6  3/3/2014:  Using Plugin System Version: 1.413:21:20.6  3/3/2014:  Loaded Plugin:"QuickLaunch" Version 1.0.3 By Adultery13:21:20.6  3/3/2014:  PlugIn: "QuickLaunch" Initialized OK13:21:20.6  3/3/2014:  Using Plugin System Version: 1.4113:21:20.6  3/3/2014:  Loaded Plugin:"Xpadder Plugin" Version 1.1.9 By Adultery13:21:20.8  3/3/2014:  PlugIn: "Xpadder Plugin" Initialized OK13:21:20.8  3/3/2014:  Using Plugin System Version: 1.4113:21:20.8  3/3/2014:  Checking for applications to Launch On Startup13:21:20.8  3/3/2014:  Launching and waiting: "C:/GameEx/HiScoreUpdater.exe" -type 1 -fpath "E:\MAME\Favorites\HSComp.ini"13:21:21.1  3/3/2014:  Setting default net connection limit to 1513:21:21.1  3/3/2014:  Running Misc startup tasks13:21:21.1  3/3/2014:  Setting Menu types13:21:21.1  3/3/2014:  Getting Configuration Values13:21:21.1  3/3/2014:  Using Theme: Default - MegaMame - 1680x105013:21:21.1  3/3/2014:  Checking for alternate Image Directory for Theme: Default - MegaMame - 1680x105013:21:21.1  3/3/2014:  Launching GameExtender.exe (GameExtender Viewer)13:21:21.3  3/3/2014:  Launching HideOS.exe13:21:21.3  3/3/2014:  Initialising Video/MNG DLL's13:21:21.3  3/3/2014:  Hiding Taskbar13:21:21.3  3/3/2014:  Using Cabinet Friendly Control System13:21:21.3  3/3/2014:  Is Media Center running?13:21:21.3  3/3/2014:  Checking/Creating LCD Registry values13:21:21.3  3/3/2014:  Check Media Center Exit/Start Mode13:21:21.3  3/3/2014:  Media Center Mode 213:21:21.3  3/3/2014:  Video previews on. Warning: Only recommended on modern systems13:21:21.4  3/3/2014:  Custom Keyboard Input enabled: Getting custom codes13:21:21.4  3/3/2014:  Advanced Custom Keyboard Input enabled: Getting custom codes13:21:21.4  3/3/2014:  Snap Delay set to: 213:21:21.4  3/3/2014:  Get other settings13:21:21.4  3/3/2014:  Desktop set to Hide ICONS and set Background to Black13:21:21.4  3/3/2014:  Set: Find emulator artwork on best match basis13:21:21.4  3/3/2014:  Using DirectInput for keyboard input13:21:21.4  3/3/2014:  Start work for Form13:21:21.4  3/3/2014:  Getting Original Screen Size13:21:21.4  3/3/2014:  Opening Database Connection13:21:21.5  3/3/2014:  Initializing Component13:21:21.5  3/3/2014:  MAME Path is: F:\Emulators\MAME13:21:21.5  3/3/2014:  Client/Server MAME Path is: C:\MAMEHub\dist13:21:21.5  3/3/2014:  Client/Server MAME EXE file is: csmame.exe13:21:21.5  3/3/2014:  Use Client/Server MAME On. csmame.exe will launch NetPlay games13:21:21.5  3/3/2014:  Model 2 Path Path is: F:\Emulators\M213:21:21.5  3/3/2014:  Multi Core/Hyper Threading detected. Looking for emulator_multicpu.exe13:21:21.5  3/3/2014:  Model 2 EXE file is: emulator_multicpu.exe13:21:21.5  3/3/2014:  Model 2 emulator with command line support detected13:21:21.5  3/3/2014:  Use Model 2 on. emulator_multicpu.exe will launch Sega Model 2 games13:21:21.6  3/3/2014:  MAME EXE file is: mame.exe13:21:21.6  3/3/2014:  ROM Path is: R:\Roms\MAME\roms13:21:21.6  3/3/2014:  Catver.ini is located at: F:\Emulators\MAME\Catver.ini13:21:21.6  3/3/2014:  controls.ini is located at: F:\Emulators\MAME\controls.ini13:21:21.6  3/3/2014:  History.dat is located at: F:\Emulators\MAME\history.dat13:21:21.6  3/3/2014:  nplayers.ini is located at: F:\Emulators\MAME\nplayers.ini13:21:21.6  3/3/2014:  command.dat is located at: F:\Emulators\MAME\command.dat13:21:21.6  3/3/2014:  MAMEinfo.dat is located at: F:\Emulators\MAME\mameinfo.dat13:21:21.7  3/3/2014:  Loading Controls.ini map file13:21:21.7  3/3/2014:  Snap Path is: C:\Artwork\MAME\Snap13:21:21.7  3/3/2014:  Database Snap Path: Not Found13:21:21.7  3/3/2014:  Background Snap Path: Not Found13:21:21.7  3/3/2014:  AVI Snap Path is: C:\Artwork\MAME\Video_MP413:21:21.7  3/3/2014:  Flyer Path is: C:\Artwork\MAME\Advert13:21:21.7  3/3/2014:  Cabinet Path is: C:\Artwork\MAME\Cabinet13:21:21.7  3/3/2014:  Cabinet 3D Path is: C:\Artwork\MAME\Cabinet_3D13:21:21.7  3/3/2014:  Title Path is: C:\Artwork\MAME\Title13:21:21.7  3/3/2014:  PCB Path is: C:\Artwork\MAME\PCB13:21:21.7  3/3/2014:  Artwork Preview Path is: C:\Artwork\MAME\GameEx13:21:21.7  3/3/2014:  Panel Path is: C:\Artwork\MAME\CP13:21:21.7  3/3/2014:  Manual Path is: C:\Artwork\MAME\Manual13:21:21.7  3/3/2014:  Icon Path is: C:\Artwork\MAME\Icon13:21:21.7  3/3/2014:  Marquee Path is: C:\Artwork\MAME\Marquee13:21:21.7  3/3/2014:  Applying Language/Text13:21:21.7  3/3/2014:  Text/Language: English13:21:21.7  3/3/2014:  Loading Language/Text13:21:21.8  3/3/2014:  Loading Custom Emulators13:21:21.8  3/3/2014:  Loading Emulator 1: NINTENDO WiiWare13:21:21.8  3/3/2014:  Loading Emulator 2: NINTENDO Game Cube13:21:21.8  3/3/2014:  Loading Emulator 3: NINTENDO N6413:21:21.8  3/3/2014:  Loading Emulator 4: NINTENDO SNES13:21:21.8  3/3/2014:  Loading Emulator 5: NINTENDO NES13:21:21.8  3/3/2014:  Loading Emulator 6: NINTENDO DS13:21:21.8  3/3/2014:  Loading Emulator 7: NINTENDO GameBoy Advance13:21:21.8  3/3/2014:  Loading Emulator 8: NINTENDO GameBoy Color13:21:21.8  3/3/2014:  Loading Emulator 9: NINTENDO Game Boy13:21:21.8  3/3/2014:  Loading Emulator 10: SEGA Dreamcast13:21:21.8  3/3/2014:  Loading Emulator 11: SEGA Saturn13:21:21.8  3/3/2014:  Loading Emulator 12: SEGA CD13:21:21.8  3/3/2014:  Loading Emulator 13: SEGA 32X13:21:21.8  3/3/2014:  Loading Emulator 14: SEGA Genesis13:21:21.8  3/3/2014:  Loading Emulator 15: SEGA Master System13:21:21.8  3/3/2014:  Loading Emulator 16: SEGA Game Gear13:21:21.8  3/3/2014:  Loading Emulator 17: ATARI 780013:21:21.8  3/3/2014:  Loading Emulator 18: ATARI 520013:21:21.9  3/3/2014:  Loading Emulator 19: ATARI 260013:21:21.9  3/3/2014:  Loading Emulator 21: NEC TurboGrafx-1613:21:21.9  3/3/2014:  Loading Emulator 22: COLECO Vision13:21:21.9  3/3/2014:  Loading Emulator 23: MATTEL Intellivision13:21:21.9  3/3/2014:  Loading Emulator 25: VISUAL PinMAME13:21:21.9  3/3/2014:  Loading Emulator 26: FUTURE Pinball13:21:21.9  3/3/2014:  Loading Emulator 28: SONY Playstation13:21:21.9  3/3/2014:  Loading Emulator 29: MICROSOFT Windows13:21:21.9  3/3/2014:  Loading Emulator 30: MICROSOFT Windows13:21:21.9  3/3/2014:  Loading Emulator 31: MICROSOFT Windows13:21:21.9  3/3/2014:  Loading Emulator 32: HOMEBREW Games13:21:21.9  3/3/2014:  Loading Emulator 33: OPEN Beats Of Rage13:21:21.9  3/3/2014:  Loading Emulator 34: TAITO Type X13:21:21.9  3/3/2014:  Loading Emulator 35: PANASONIC 3DO13:21:21.9  3/3/2014:  Loading Emulator 36: SONY PSP13:21:21.9  3/3/2014:  Checking if Steam enabled13:21:21.9  3/3/2014:  Steam is installed correctly13:21:22.0  3/3/2014:  Found Steam Base Install Folder: c:/program files/steam13:21:22.0  3/3/2014:  Found Steam Game: Orcs Must Die! 2. AppID=201790. Location:C:\Program Files\Steam\steamapps\common\Orcs Must Die 213:21:22.0  3/3/2014:  Found Steam Game: Sanctum 2. AppID=210770. Location:C:\Program Files\Steam\steamapps\common\Sanctum213:21:22.0  3/3/2014:  Found Steam Game: FEZ. AppID=224760. Location:C:\Program Files\Steam\steamapps\common\FEZ13:21:22.0  3/3/2014:  Found Steam Game: Brütal Legend. AppID=225260. Location:C:\Program Files\Steam\steamapps\common\BrutalLegend13:21:22.0  3/3/2014:  Found Steam Game: Pinball FX2. AppID=226980. Location:C:\Program Files\Steam\steamapps\common\Pinball FX213:21:22.0  3/3/2014:  Found Steam Game: DisplayFusion. AppID=227260. Location:c:\Program Files\Steam\steamapps\common\DisplayFusion13:21:22.0  3/3/2014:  Found Steam Game: DuckTales Remastered. AppID=237630. Location:C:\Program Files\Steam\steamapps\common\DuckTales Remastered13:21:22.1  3/3/2014:  Found Steam Game: Pinball Arcade. AppID=238260. Location:C:\Program Files\Steam\steamapps\common\PinballArcade13:21:22.1  3/3/2014:  Found Steam Game: Trine 2. AppID=35720. Location:C:\Program Files\Steam\steamapps\common\Trine 213:21:22.1  3/3/2014:  Found Steam Game: Psychonauts. AppID=3830. Location:C:\Program Files\Steam\steamapps\common\Psychonauts13:21:22.1  3/3/2014:  Found Steam Game: Garry's Mod. AppID=4000. Location:C:\Program Files\Steam\steamapps\common\GarrysMod13:21:22.1  3/3/2014:  Found Steam Game: Serious Sam 3: BFE. AppID=41070. Location:c:\program files\steam\steamapps\common\serious sam 313:21:22.1  3/3/2014:  Found Steam Game: Magicka. AppID=42910. Location:C:\Program Files\Steam\steamapps\common\Magicka13:21:22.1  3/3/2014:  Found Steam games. Steam enabled.13:21:22.2  3/3/2014:  gamebase support enabled.13:21:22.2  3/3/2014:  Loading Emulator Group 1: MICROSOFT Windows13:21:22.2  3/3/2014:  Using Version 3 Themes Animations13:21:22.2  3/3/2014:  Retrieving resolution setting13:21:22.2  3/3/2014:  Using General Font: Tahoma13:21:22.2  3/3/2014:  Using Title Font: Tahoma13:21:22.2  3/3/2014:  GameEx will try to reduce CPU usage13:21:22.3  3/3/2014:  Initialising Direct3D13:21:22.3  3/3/2014:  Applying GameEx is Loading Image13:21:22.4  3/3/2014:  Setting Resolution to 1680x1050 32 bit color13:21:22.4  3/3/2014:  Creating Surfaces13:21:22.7  3/3/2014:  Creating Primary Surface - Full Screen Mode13:21:22.7  3/3/2014:  Creating Back Buffer13:21:22.7  3/3/2014:  Version 2 Theme being used. Loading.13:21:22.8  3/3/2014:  Loading Button Data13:21:22.8  3/3/2014:  Loading Font Data13:21:22.8  3/3/2014:  Loading Layout Data13:21:22.8  3/3/2014:  Loading Taskbar Data13:21:22.8  3/3/2014:  Loading graphic Surfaces13:21:22.8  3/3/2014:  Display is running at: 1680x1050 32bit color, 59hz13:21:22.8  3/3/2014:  Adapter: ATI Radeon HD 4600 Series13:21:22.8  3/3/2014:  Max texture size: 8192x819213:21:22.8  3/3/2014:  Available texture memory: -1691MB13:21:22.9  3/3/2014:  Initialising Bass Audio Library13:21:22.9  3/3/2014:  Creating Surfaces Misc and Dialogs13:21:23.0  3/3/2014:  Creating Surfaces Volume13:21:23.0  3/3/2014:  Creating Surfaces Arrows13:21:23.0  3/3/2014:  Creating Surfaces GameEXlogo Text13:21:23.0  3/3/2014:  Creating Surfaces Toolbar13:21:23.1  3/3/2014:  Creating Surfaces Toolbar Controls13:21:23.1  3/3/2014:  Creating Surfaces Backgrounds13:21:23.1  3/3/2014:  Creating Surfaces GameEx Logo13:21:23.1  3/3/2014:  Creating Surface Unselected13:21:23.1  3/3/2014:  Creating Surfaces Snaps13:21:23.1  3/3/2014:  Creating Surfaces Menu and List Bars13:21:23.2  3/3/2014:  Creating Fonts13:21:23.2  3/3/2014:  Creating Game Font13:21:23.2  3/3/2014:  Creating Game Font Faded13:21:23.3  3/3/2014:  Creating Title Font13:21:23.3  3/3/2014:  Restoring Title Font From Cache13:21:23.4  3/3/2014:  Creating Font Black13:21:23.4  3/3/2014:  Creating Font Black Small13:21:23.5  3/3/2014:  Fonts Created Succesfully13:21:23.5  3/3/2014:  Loading News Feed: http://www.gameex.net/gameexnews.xml13:21:25.1  3/3/2014:  Attempting to load game list13:21:25.3  3/3/2014:  GameExtender Not found snap: F:\Images\no_img.png13:21:25.3  3/3/2014:  Starting GameExtender on: 192.168.25.150:129013:21:25.3  3/3/2014:  GameExtender using specific custom images for systems.13:21:25.3  3/3/2014:  MAME CMD options: -nowindow -joy -mt -video d3d -mouse -noka -tb13:21:25.3  3/3/2014:  Initialising DirectInput for Gamepad support13:21:25.3  3/3/2014:  GameEx will just check for activity on Gamepad13:21:25.4  3/3/2014:  Using Device Controller (Xbox 360 Wireless Receiver for Windows)13:21:25.4  3/3/2014:  Initialising DirectInput for Keyboard support13:21:25.5  3/3/2014:  Loading Start Page13:21:25.5  3/3/2014:  Initializing MCE Remote13:21:25.5  3/3/2014:  Playing intro sound file13:21:25.6  3/3/2014:  Initialization OK! Starting GameEx!13:21:25.6  3/3/2014:  Testing Main Loop Once: Processing Frame13:21:25.8  3/3/2014:  Testing Main Loop Once: Main Loop ran successfully13:21:26.5  3/3/2014:  [XPADDER PLUGIN] Xpadder Plugin (1.1.9) Initialized successfully!13:21:26.5  3/3/2014:  [XPADDER PLUGIN] Profile successfully loaded for GameEx Interface!13:21:29.3  3/3/2014:  Validating: Emulator_1: Custom Background: back-nintendo_wiiware.png13:21:29.3  3/3/2014:  Validating: Emulator_1: Snap Path: C:\Artwork\Nintendo_WiiWare\Snap13:21:29.3  3/3/2014:  Validating: Emulator_1: Not Found Image: C:\Artwork\no_img.png13:21:29.3  3/3/2014:  Validating: Emulator_1: Database: [Console] Nintendo Wii13:21:29.3  3/3/2014:  Validating: Emulator_1: Title Snap Path: C:\Artwork\Nintendo_WiiWare\Title13:21:29.3  3/3/2014:  Validating: Emulator_1: Manual Path: C:\Artwork\Nintendo_WiiWare\Manual13:21:29.3  3/3/2014:  Validating: Emulator_2: Custom Background: back-nintendo_gamecube.png13:21:29.3  3/3/2014:  Validating: Emulator_2: Snap Path: F:\Emulators\Dolphin\Artwork\Snap13:21:29.3  3/3/2014:  Validating: Emulator_2: Control Panel Path: F:\Images\Controls\Emulators\Game Cube.png13:21:29.4  3/3/2014:  Validating: Emulator_2: Database: [Console] Nintendo GameCube13:21:29.4  3/3/2014:  Validating: Emulator_2: Title Snap Path: F:\Emulators\Dolphin\Artwork\Title13:21:29.4  3/3/2014:  Validating: Emulator_2: Box Art Path: F:\Emulators\Dolphin\Artwork\Box13:21:29.4  3/3/2014:  Validating: Emulator_2: Cart Art Path: F:\Emulators\Dolphin\Artwork\Cart13:21:29.4  3/3/2014:  Validating: Emulator_2: Manual Path: F:\Emulators\Dolphin\Artwork\Manual13:21:29.4  3/3/2014:  Validating: Emulator_3: Custom Background: back-nintendo_64.png13:21:29.4  3/3/2014:  Validating: Emulator_3: Snap Path: E:\Artwork\Nintendo_N64\Snap13:21:29.4  3/3/2014:  Validating: Emulator_3: Video Snap Path: E:\Artwork\Nintendo_N64\Video_MP413:21:29.4  3/3/2014:  Validating: Emulator_3: Custom Art Path 1: E:\Artwork\Nintendo_N64\Snap13:21:29.4  3/3/2014:  Validating: Emulator_3: Custom Art Path 2: E:\Artwork\Nintendo_N64\Advert13:21:29.4  3/3/2014:  Validating: Emulator_3: Control Panel Path: E:\Artwork\GameExtender\Controls\Nintendo 64\N64.png13:21:29.4  3/3/2014:  Validating: Emulator_3: Database: [Console] Nintendo N6413:21:29.4  3/3/2014:  Validating: Emulator_3: Title Snap Path: E:\Artwork\Nintendo_N64\Title13:21:29.4  3/3/2014:  Validating: Emulator_3: Box Art Path: E:\Artwork\Nintendo_N64\Box13:21:29.4  3/3/2014:  Validating: Emulator_3: Cart Art Path: E:\Artwork\Nintendo_N64\Cart13:21:29.4  3/3/2014:  Validating: Emulator_3: TV Ad Path: E:\Artwork\Nintendo_N64\Video_Advert_MP413:21:29.4  3/3/2014:  Validating: Emulator_3: Manual Path: E:\Artwork\Nintendo_N64\Manual13:21:29.4  3/3/2014:  Validating: Emulator_4: Custom Background: back-nintendo_snes.png13:21:29.4  3/3/2014:  Validating: Emulator_4: Snap Path: E:\Artwork\Nintendo_SNES\Snap13:21:29.4  3/3/2014:  Validating: Emulator_4: Video Snap Path: E:\Artwork\Nintendo_SNES\Video_MP413:21:29.4  3/3/2014:  Validating: Emulator_4: Custom Art Path 1: E:\Artwork\Nintendo_SNES\Advert13:21:29.4  3/3/2014:  Validating: Emulator_4: Custom Art Path 2: E:\Artwork\Nintendo_SNES\Map13:21:29.4  3/3/2014:  Validating: Emulator_4: Control Panel Path: E:\Artwork\GameExtender\Controls\Nintendo SNES\SNES.png13:21:29.4  3/3/2014:  Validating: Emulator_4: Database: [Console] Nintendo SNES13:21:29.4  3/3/2014:  Validating: Emulator_4: Title Snap Path: E:\Artwork\Nintendo_SNES\Title13:21:29.4  3/3/2014:  Validating: Emulator_4: Box Art Path: E:\Artwork\Nintendo_SNES\Box_3D13:21:29.4  3/3/2014:  Validating: Emulator_4: Cart Art Path: E:\Artwork\Nintendo_SNES\Cart13:21:29.4  3/3/2014:  Validating: Emulator_4: Music Path: E:\Artwork\Nintendo_SNES\Music13:21:29.5  3/3/2014:  Validating: Emulator_4: TV Ad Path: E:\Artwork\Nintendo_SNES\Video_Advert_MP413:21:29.5  3/3/2014:  Validating: Emulator_4: Manual Path: E:\Artwork\Nintendo_SNES\Manual13:21:29.5  3/3/2014:  Validating: Emulator_5: Custom Background: back-nintendo_nes.png13:21:29.5  3/3/2014:  Validating: Emulator_5: Snap Path: E:\Artwork\Nintendo_NES\Snap13:21:29.5  3/3/2014:  Validating: Emulator_5: Video Snap Path: E:\Artwork\Nintendo_NES\Video_MP413:21:29.5  3/3/2014:  Validating: Emulator_5: Custom Art Path 1: E:\Artwork\Nintendo_NES\Advert13:21:29.5  3/3/2014:  Validating: Emulator_5: Control Panel Path: E:\Artwork\GameExtender\Controls\Nintendo NES\NES.png13:21:29.5  3/3/2014:  Validating: Emulator_5: Database: [Console] Nintendo NES13:21:29.5  3/3/2014:  Validating: Emulator_5: Title Snap Path: E:\Artwork\Nintendo_NES\Title13:21:29.5  3/3/2014:  Validating: Emulator_5: Box Art Path: E:\Artwork\Nintendo_NES\Box_3D13:21:29.5  3/3/2014:  Validating: Emulator_5: Cart Art Path: E:\Artwork\Nintendo_NES\Cart13:21:29.5  3/3/2014:  Validating: Emulator_5: Music Path: E:\Artwork\Nintendo_NES\Music13:21:29.5  3/3/2014:  Validating: Emulator_5: TV Ad Path: E:\Artwork\Nintendo_NES\Video_Advert_MP413:21:29.5  3/3/2014:  Validating: Emulator_5: Manual Path: E:\Artwork\Nintendo_NES\Manual13:21:29.5  3/3/2014:  Validating: Emulator_6: Custom Background: back-nintendo_ds.png13:21:29.5  3/3/2014:  Validating: Emulator_6: Control Panel Path: F:\Images\Controls\Emulators\Nintendo DS.png13:21:29.5  3/3/2014:  Validating: Emulator_6: Database: [Handheld] Nintendo DS13:21:29.5  3/3/2014:  Validating: Emulator_6: Box Art Path: E:\Artwork\Nintendo_NES\Box_3D13:21:29.5  3/3/2014:  Validating: Emulator_7: Custom Background: back-nintendo_game_boy_advance.png13:21:29.5  3/3/2014:  Validating: Emulator_7: Snap Path: E:\Artwork\Nintendo_Game_Boy_Advance\Snap13:21:29.5  3/3/2014:  Validating: Emulator_7: Video Snap Path: E:\Artwork\Nintendo_Game_Boy_Advance\Video_MP413:21:29.5  3/3/2014:  Validating: Emulator_7: Custom Art Path 1: E:\Artwork\Nintendo_Game_Boy_Advance\Snap13:21:29.5  3/3/2014:  Validating: Emulator_7: Custom Art Path 2: E:\Artwork\Nintendo_Game_Boy_Advance\Advert13:21:29.5  3/3/2014:  Validating: Emulator_7: Control Panel Path: E:\Artwork\GameExtender\Controls\Gameboy Advance\GBA.png13:21:29.5  3/3/2014:  Validating: Emulator_7: Database: [Handheld] Nintendo Game Boy Advance13:21:29.5  3/3/2014:  Validating: Emulator_7: Title Snap Path: E:\Artwork\Nintendo_Game_Boy_Advance\Title13:21:29.5  3/3/2014:  Validating: Emulator_7: Box Art Path: E:\Artwork\Nintendo_Game_Boy_Advance\Box_3D13:21:29.5  3/3/2014:  Validating: Emulator_7: Cart Art Path: E:\Artwork\Nintendo_Game_Boy_Advance\Cart13:21:29.6  3/3/2014:  Validating: Emulator_7: TV Ad Path: E:\Artwork\Nintendo_Game_Boy_Advance\Video_Advert_MP413:21:29.6  3/3/2014:  Validating: Emulator_8: Custom Background: back-nintendo_game_boy_color.png13:21:29.6  3/3/2014:  Validating: Emulator_8: Snap Path: E:\Artwork\Nintendo_Game_Boy_Color\Video_MP413:21:29.6  3/3/2014:  Validating: Emulator_8: Video Snap Path: E:\Artwork\Nintendo_Game_Boy_Color\Video_MP413:21:29.6  3/3/2014:  Validating: Emulator_8: Custom Art Path 1: E:\Artwork\Nintendo_Game_Boy_Color\Snap13:21:29.6  3/3/2014:  Validating: Emulator_8: Custom Art Path 2: E:\Artwork\Nintendo_Game_Boy_Color\Advert13:21:29.6  3/3/2014:  Warning: Emulator_8: Custom Art Path 2 Does not exist13:21:29.6  3/3/2014:  Validating: Emulator_8: Control Panel Path: E:\Artwork\GameExtender\Controls\Gameboy Color\GBC.png13:21:29.6  3/3/2014:  Validating: Emulator_8: Database: [Handheld] Nintendo Game Boy Color13:21:29.6  3/3/2014:  Validating: Emulator_8: Title Snap Path: E:\Artwork\Nintendo_Game_Boy_Color\Title13:21:29.6  3/3/2014:  Validating: Emulator_8: Box Art Path: E:\Artwork\Nintendo_Game_Boy_Color\Box13:21:29.6  3/3/2014:  Validating: Emulator_8: Cart Art Path: E:\Artwork\Nintendo_Game_Boy_Color\Cart13:21:29.6  3/3/2014:  Validating: Emulator_8: Music Path: E:\Artwork\Nintendo_Game_Boy_Color\Music13:21:29.6  3/3/2014:  Validating: Emulator_8: TV Ad Path: E:\Artwork\Nintendo_Game_Boy_Color\Video_Advert_MP413:21:29.6  3/3/2014:  Validating: Emulator_8: Manual Path: E:\Artwork\Nintendo_Game_Boy_Color\Manual13:21:29.6  3/3/2014:  Validating: Emulator_9: Snap Path: E:\Artwork\Nintendo_Game_Boy\Snap13:21:29.6  3/3/2014:  Validating: Emulator_9: Video Snap Path: E:\Artwork\Nintendo_Game_Boy\Video_MP413:21:29.6  3/3/2014:  Validating: Emulator_9: Custom Art Path 1: E:\Artwork\Nintendo_Game_Boy\Snap13:21:29.6  3/3/2014:  Validating: Emulator_9: Custom Art Path 2: E:\Artwork\Nintendo_Game_Boy\Map13:21:29.6  3/3/2014:  Validating: Emulator_9: Control Panel Path: E:\Artwork\GameExtender\Controls\Gameboy Color\GBC.png13:21:29.6  3/3/2014:  Validating: Emulator_9: Database: [Handheld] Nintendo Game Boy13:21:29.6  3/3/2014:  Validating: Emulator_9: Title Snap Path: E:\Artwork\Nintendo_Game_Boy\Title13:21:29.6  3/3/2014:  Validating: Emulator_9: Cart Art Path: E:\Artwork\Nintendo_Game_Boy\Cart13:21:29.6  3/3/2014:  Validating: Emulator_9: Music Path: E:\Artwork\Nintendo_Game_Boy\Music13:21:29.6  3/3/2014:  Validating: Emulator_9: TV Ad Path: E:\Artwork\Nintendo_Game_Boy\Video_Advert_MP413:21:29.6  3/3/2014:  Validating: Emulator_9: Manual Path: E:\Artwork\Nintendo_Game_Boy\Manual13:21:29.6  3/3/2014:  Validating: Emulator_10: Custom Background: back-sega_dreamcast.png13:21:29.7  3/3/2014:  Validating: Emulator_10: Snap Path: F:\Emulators\NullDC\artwork\Snaps13:21:29.7  3/3/2014:  Validating: Emulator_10: Database: [Console] Sega Dreamcast13:21:29.7  3/3/2014:  Validating: Emulator_10: Title Snap Path: F:\Emulators\NullDC\artwork\Titles13:21:29.7  3/3/2014:  Validating: Emulator_11: Custom Background: back-sega_saturn.png13:21:29.7  3/3/2014:  Validating: Emulator_11: Snap Path: E:\Artwork\Sega_Saturn\Snap13:21:29.7  3/3/2014:  Warning: Emulator_11: Snap Path Does not exist13:21:29.7  3/3/2014:  Validating: Emulator_11: Custom Art Path 1: E:\Artwork\Sega_Saturn\BoxBack13:21:29.7  3/3/2014:  Warning: Emulator_11: Custom Art Path 1 Does not exist13:21:29.7  3/3/2014:  Validating: Emulator_11: Custom Art Path 2: E:\Artwork\Sega_Saturn\Advert13:21:29.7  3/3/2014:  Warning: Emulator_11: Custom Art Path 2 Does not exist13:21:29.7  3/3/2014:  Validating: Emulator_11: Control Panel Path: E:\Artwork\GameExtender\Controls\Saturn\Saturn.png13:21:29.7  3/3/2014:  Validating: Emulator_11: Database: [Console] Sega Saturn13:21:29.7  3/3/2014:  Validating: Emulator_11: Title Snap Path: E:\Artwork\Sega_Saturn\Title13:21:29.7  3/3/2014:  Warning: Emulator_11: Title Snap Path Does not exist13:21:29.7  3/3/2014:  Validating: Emulator_11: Box Art Path: E:\Artwork\Sega_Saturn\Box13:21:29.7  3/3/2014:  Warning: Emulator_11: Box Art Path Does not exist13:21:29.7  3/3/2014:  Validating: Emulator_11: Cart Art Path: E:\Artwork\Sega_Saturn\CD13:21:29.7  3/3/2014:  Warning: Emulator_11: Cart Art Path Does not exist13:21:29.7  3/3/2014:  Validating: Emulator_11: Manual Path: E:\Artwork\Sega_Saturn\Manual13:21:29.7  3/3/2014:  Warning: Emulator_11: Manual Path Does not exist13:21:29.7  3/3/2014:  Validating: Emulator_12: Custom Background: back-sega_cd.png13:21:29.7  3/3/2014:  Validating: Emulator_12: Snap Path: E:\Artwork\Sega_CD\Snap13:21:29.7  3/3/2014:  Validating: Emulator_12: Video Snap Path: E:\Artwork\Sega_CD\Video_MP413:21:29.7  3/3/2014:  Validating: Emulator_12: Custom Art Path 1: E:\Artwork\Sega_CD\Snap13:21:29.7  3/3/2014:  Validating: Emulator_12: Custom Art Path 2: E:\Artwork\Sega_CD\Advert13:21:29.7  3/3/2014:  Validating: Emulator_12: Custom Art Path 3: E:\Artwork\Sega_CD\Map13:21:29.7  3/3/2014:  Validating: Emulator_12: Custom Art Path 4: E:\Artwork\Sega_CD\BoxBack13:21:29.7  3/3/2014:  Validating: Emulator_12: Control Panel Path: E:\Artwork\GameExtender\Controls\Sega CD\SCD.png13:21:29.8  3/3/2014:  Validating: Emulator_12: Database: [Console] Sega CD13:21:29.8  3/3/2014:  Validating: Emulator_12: Title Snap Path: E:\Artwork\Sega_CD\Title13:21:29.8  3/3/2014:  Validating: Emulator_12: Box Art Path: E:\Artwork\Sega_CD\Box13:21:29.8  3/3/2014:  Validating: Emulator_12: Cart Art Path: E:\Artwork\Sega_CD\CD13:21:29.8  3/3/2014:  Validating: Emulator_12: TV Ad Path: E:\Artwork\Sega_CD\Video_Advert_MP413:21:29.8  3/3/2014:  Validating: Emulator_12: Manual Path: E:\Artwork\Sega_CD\Manual13:21:29.8  3/3/2014:  Validating: Emulator_13: Custom Background: back-sega_genesis.png13:21:29.8  3/3/2014:  Validating: Emulator_13: Snap Path: E:\Artwork\Sega_32x\Snaps13:21:29.8  3/3/2014:  Warning: Emulator_13: Snap Path Does not exist13:21:29.8  3/3/2014:  Validating: Emulator_13: Video Snap Path: E:\Artwork\Sega_32x\Video_MP413:21:29.8  3/3/2014:  Validating: Emulator_13: Control Panel Path: E:\Artwork\GameExtender\Controls\Sega Genesis\GEN.png13:21:29.8  3/3/2014:  Warning: Emulator_13: Control Panel Path Does not exist13:21:29.8  3/3/2014:  Validating: Emulator_13: Database: [Console] Sega 32X13:21:29.8  3/3/2014:  Validating: Emulator_13: Title Snap Path: E:\Artwork\Sega_32x\Title13:21:29.8  3/3/2014:  Validating: Emulator_13: Box Art Path: E:\Artwork\Sega_32x\Box_3D13:21:29.8  3/3/2014:  Validating: Emulator_13: Cart Art Path: E:\Artwork\Sega_32x\CD13:21:29.8  3/3/2014:  Validating: Emulator_13: Manual Path: E:\Artwork\Sega_32x\Manual13:21:29.8  3/3/2014:  Validating: Emulator_14: Custom Background: back-sega_genesis.png13:21:29.8  3/3/2014:  Validating: Emulator_14: Snap Path: E:\Artwork\Sega_Genesis\Snap13:21:29.8  3/3/2014:  Validating: Emulator_14: Video Snap Path: E:\Artwork\Sega_Genesis\Video_MP413:21:29.8  3/3/2014:  Validating: Emulator_14: Custom Art Path 1: E:\Artwork\Sega_Genesis\Snap13:21:29.8  3/3/2014:  Validating: Emulator_14: Custom Art Path 2: E:\Artwork\Sega_Genesis\Advert13:21:29.8  3/3/2014:  Validating: Emulator_14: Custom Art Path 3: E:\Artwork\Sega_Genesis\CartTop13:21:29.8  3/3/2014:  Validating: Emulator_14: Control Panel Path: E:\Artwork\GameExtender\Controls\Sega Genesis\GEN.png13:21:29.8  3/3/2014:  Warning: Emulator_14: Control Panel Path Does not exist13:21:29.8  3/3/2014:  Validating: Emulator_14: Database: [Console] Sega Genesis13:21:29.8  3/3/2014:  Validating: Emulator_14: Title Snap Path: E:\Artwork\Sega_Genesis\Title13:21:29.8  3/3/2014:  Validating: Emulator_14: Box Art Path: E:\Artwork\Sega_Genesis\Box_3D13:21:29.8  3/3/2014:  Validating: Emulator_14: Cart Art Path: E:\Artwork\Sega_Genesis\Cart13:21:29.9  3/3/2014:  Validating: Emulator_14: Music Path: E:\Artwork\Sega_Genesis\Music13:21:29.9  3/3/2014:  Warning: Emulator_14: Music Path Does not exist13:21:29.9  3/3/2014:  Validating: Emulator_14: TV Ad Path: E:\Artwork\Sega_Genesis\Video_Advert_MP413:21:29.9  3/3/2014:  Validating: Emulator_14: Manual Path: E:\Artwork\Sega_Genesis\Manual13:21:29.9  3/3/2014:  Validating: Emulator_15: Custom Background: back-sega_master_system.png13:21:29.9  3/3/2014:  Validating: Emulator_15: Snap Path: E:\Artwork\Sega_Master_System\Snap13:21:29.9  3/3/2014:  Warning: Emulator_15: Snap Path Does not exist13:21:29.9  3/3/2014:  Validating: Emulator_15: Video Snap Path: E:\Artwork\Sega_Master_System\Video_MP413:21:29.9  3/3/2014:  Warning: Emulator_15: Video Snap Path Does not exist13:21:29.9  3/3/2014:  Validating: Emulator_15: Custom Art Path 1: E:\Artwork\Sega_Master_System\Snap13:21:29.9  3/3/2014:  Warning: Emulator_15: Custom Art Path 1 Does not exist13:21:29.9  3/3/2014:  Validating: Emulator_15: Control Panel Path: E:\Artwork\GameExtender\Controls\Sega Master System\SMS.png13:21:29.9  3/3/2014:  Validating: Emulator_15: Database: [Console] Sega Master System13:21:29.9  3/3/2014:  Validating: Emulator_15: Title Snap Path: E:\Artwork\Sega_Master_System\Title13:21:29.9  3/3/2014:  Warning: Emulator_15: Title Snap Path Does not exist13:21:29.9  3/3/2014:  Validating: Emulator_15: Box Art Path: E:\Artwork\Sega_Master_System\Box_3D13:21:29.9  3/3/2014:  Warning: Emulator_15: Box Art Path Does not exist13:21:29.9  3/3/2014:  Validating: Emulator_15: Cart Art Path: E:\Artwork\Sega_Master_System\Cart13:21:29.9  3/3/2014:  Warning: Emulator_15: Cart Art Path Does not exist13:21:29.9  3/3/2014:  Validating: Emulator_15: Music Path: E:\Artwork\Sega_Master_System\Music13:21:29.9  3/3/2014:  Warning: Emulator_15: Music Path Does not exist13:21:29.9  3/3/2014:  Validating: Emulator_15: TV Ad Path: E:\Artwork\Sega_Master_System\Video_Advert_MP413:21:29.9  3/3/2014:  Warning: Emulator_15: TV Ad Path Does not exist13:21:29.9  3/3/2014:  Validating: Emulator_15: Manual Path: E:\Artwork\Sega_Master_System\Manual13:21:29.9  3/3/2014:  Warning: Emulator_15: Manual Path Does not exist13:21:29.9  3/3/2014:  Validating: Emulator_16: Custom Background: back-sega_game_gear.png13:21:29.9  3/3/2014:  Validating: Emulator_16: Snap Path: E:\Artwork\Sega_Game_Gear\Snap13:21:29.9  3/3/2014:  Validating: Emulator_16: Video Snap Path: E:\Artwork\Sega_Game_Gear\Video_MP413:21:29.9  3/3/2014:  Validating: Emulator_16: Custom Art Path 1: E:\Artwork\Sega_Game_Gear\Snap13:21:30.0  3/3/2014:  Validating: Emulator_16: Custom Art Path 2: E:\Artwork\Sega_Game_Gear\Advert13:21:30.0  3/3/2014:  Validating: Emulator_16: Control Panel Path: E:\Artwork\GameExtender\Controls\Game Gear\GG.png13:21:30.0  3/3/2014:  Validating: Emulator_16: Database: [Handheld] Sega Game Gear13:21:30.0  3/3/2014:  Validating: Emulator_16: Title Snap Path: E:\Artwork\Sega_Game_Gear\Title13:21:30.0  3/3/2014:  Validating: Emulator_16: Box Art Path: E:\Artwork\Sega_Game_Gear\Box13:21:30.0  3/3/2014:  Validating: Emulator_16: Cart Art Path: E:\Artwork\Sega_Game_Gear\Cart13:21:30.0  3/3/2014:  Validating: Emulator_16: Music Path: E:\Artwork\Sega_Game_Gear\Music13:21:30.0  3/3/2014:  Validating: Emulator_16: TV Ad Path: E:\Artwork\Sega_Game_Gear\Video_Advert_MP413:21:30.0  3/3/2014:  Validating: Emulator_16: Manual Path: E:\Artwork\Sega_Game_Gear\Manual13:21:30.0  3/3/2014:  Validating: Emulator_17: Custom Background: back-atari_7800.png13:21:30.0  3/3/2014:  Validating: Emulator_17: Snap Path: C:\Artwork\Atari_7800\Snap13:21:30.0  3/3/2014:  Warning: Emulator_17: Snap Path Does not exist13:21:30.0  3/3/2014:  Validating: Emulator_17: Video Snap Path: E:\Artwork\Atari_7800\Video_MP413:21:30.0  3/3/2014:  Validating: Emulator_17: Custom Art Path 1: E:\Artwork\Atari_7800\Snap13:21:30.0  3/3/2014:  Validating: Emulator_17: Control Panel Path: E:\Artwork\GameExtender\Controls\7800\7800.png13:21:30.0  3/3/2014:  Validating: Emulator_17: Database: [Console] Atari 780013:21:30.0  3/3/2014:  Validating: Emulator_17: Title Snap Path: E:\Artwork\Atari_7800\Title13:21:30.0  3/3/2014:  Validating: Emulator_17: Box Art Path: E:\Artwork\Atari_7800\Box_3D13:21:30.0  3/3/2014:  Validating: Emulator_17: Cart Art Path: E:\Artwork\Atari_7800\Cart13:21:30.0  3/3/2014:  Validating: Emulator_17: TV Ad Path: E:\Artwork\Atari_7800\Video_Advert_MP413:21:30.0  3/3/2014:  Validating: Emulator_17: Manual Path: E:\Artwork\Atari_7800\Manual13:21:30.0  3/3/2014:  Validating: Emulator_18: Custom Background: back-atari_5200.png13:21:30.0  3/3/2014:  Validating: Emulator_18: Snap Path: E:\Artwork\Atari_5200\Snap13:21:30.0  3/3/2014:  Validating: Emulator_18: Video Snap Path: E:\Artwork\Atari_5200\Video_MP413:21:30.0  3/3/2014:  Validating: Emulator_18: Custom Art Path 1: E:\Artwork\Atari_5200\BoxBack13:21:30.0  3/3/2014:  Validating: Emulator_18: Custom Art Path 2: E:\Artwork\Atari_5200\Overlay13:21:30.0  3/3/2014:  Validating: Emulator_18: Control Panel Path: E:\Artwork\GameExtender\Controls\5200\5200.png13:21:30.0  3/3/2014:  Validating: Emulator_18: Database: [Console] Atari 520013:21:30.1  3/3/2014:  Validating: Emulator_18: Title Snap Path: E:\Artwork\Atari_5200\Title13:21:30.1  3/3/2014:  Validating: Emulator_18: Box Art Path: E:\Artwork\Atari_5200\Box_3D13:21:30.1  3/3/2014:  Validating: Emulator_18: Cart Art Path: E:\Artwork\Atari_5200\Cart13:21:30.1  3/3/2014:  Validating: Emulator_18: Music Path: E:\Artwork\Atari_5200\Music13:21:30.1  3/3/2014:  Validating: Emulator_18: TV Ad Path: E:\Artwork\Atari_5200\Video_Advert_MP413:21:30.1  3/3/2014:  Validating: Emulator_18: Manual Path: E:\Artwork\Atari_5200\Manual13:21:30.1  3/3/2014:  Validating: Emulator_19: Custom Background: back-atari_2600.png13:21:30.1  3/3/2014:  Validating: Emulator_19: Snap Path: E:\Artwork\Atari_2600\Snap13:21:30.1  3/3/2014:  Validating: Emulator_19: Video Snap Path: E:\Artwork\Atari_2600\Video_MP413:21:30.1  3/3/2014:  Validating: Emulator_19: Custom Art Path 1: E:\Artwork\Atari_2600\Snap13:21:30.1  3/3/2014:  Validating: Emulator_19: Custom Art Path 2: E:\Artwork\Atari_2600\Overlay13:21:30.1  3/3/2014:  Validating: Emulator_19: Control Panel Path: E:\Artwork\GameExtender\Controls\2600\2600.png13:21:30.1  3/3/2014:  Validating: Emulator_19: Database: [Console] Atari 260013:21:30.1  3/3/2014:  Validating: Emulator_19: Box Art Path: E:\Artwork\Atari_2600\Box_3D13:21:30.1  3/3/2014:  Validating: Emulator_19: Cart Art Path: E:\Artwork\Atari_2600\Cart13:21:30.1  3/3/2014:  Validating: Emulator_19: TV Ad Path: E:\Artwork\Atari_2600\Video_Advert_MP413:21:30.1  3/3/2014:  Validating: Emulator_19: Manual Path: E:\Artwork\Atari_2600\Manual13:21:30.1  3/3/2014:  Validating: Emulator_21: Custom Background: back-nec_tg16.png13:21:30.1  3/3/2014:  Validating: Emulator_21: Snap Path: E:\Artwork\NEC_TurboGrafx_16\Snap13:21:30.1  3/3/2014:  Warning: Emulator_21: Snap Path Does not exist13:21:30.1  3/3/2014:  Validating: Emulator_21: Video Snap Path: E:\Artwork\NEC_TurboGrafx_16\Video_MP413:21:30.1  3/3/2014:  Warning: Emulator_21: Video Snap Path Does not exist13:21:30.1  3/3/2014:  Validating: Emulator_21: Custom Art Path 1: E:\Artwork\NEC_TurboGrafx_16\Snap13:21:30.1  3/3/2014:  Warning: Emulator_21: Custom Art Path 1 Does not exist13:21:30.2  3/3/2014:  Validating: Emulator_21: Custom Art Path 2: E:\Artwork\NEC_TurboGrafx_16\Advert13:21:30.2  3/3/2014:  Warning: Emulator_21: Custom Art Path 2 Does not exist13:21:30.2  3/3/2014:  Validating: Emulator_21: Control Panel Path: E:\Artwork\GameExtender\Controls\TG 16\TG16.png13:21:30.2  3/3/2014:  Validating: Emulator_21: Database: [Console] NEC TurboGrafx-1613:21:30.2  3/3/2014:  Validating: Emulator_21: Title Snap Path: E:\Artwork\NEC_TurboGrafx_16\Title13:21:30.2  3/3/2014:  Warning: Emulator_21: Title Snap Path Does not exist13:21:30.2  3/3/2014:  Validating: Emulator_21: Box Art Path: E:\Artwork\NEC_TurboGrafx_16\Box13:21:30.2  3/3/2014:  Warning: Emulator_21: Box Art Path Does not exist13:21:30.2  3/3/2014:  Validating: Emulator_21: Cart Art Path: E:\Artwork\NEC_TurboGrafx_16\Cart13:21:30.2  3/3/2014:  Warning: Emulator_21: Cart Art Path Does not exist13:21:30.2  3/3/2014:  Validating: Emulator_21: Music Path: E:\Artwork\NEC_TurboGrafx_16\Music13:21:30.2  3/3/2014:  Warning: Emulator_21: Music Path Does not exist13:21:30.2  3/3/2014:  Validating: Emulator_21: Manual Path: E:\Artwork\NEC_TurboGrafx_16\Manual13:21:30.2  3/3/2014:  Warning: Emulator_21: Manual Path Does not exist13:21:30.2  3/3/2014:  Validating: Emulator_22: Custom Background: back-colecovision.png13:21:30.2  3/3/2014:  Validating: Emulator_22: Snap Path: E:\Artwork\Coleco_Vision\Snap13:21:30.2  3/3/2014:  Validating: Emulator_22: Video Snap Path: E:\Artwork\Coleco_Vision\Video_MP413:21:30.2  3/3/2014:  Validating: Emulator_22: Custom Art Path 1: E:\Artwork\Coleco_Vision\Snap13:21:30.2  3/3/2014:  Validating: Emulator_22: Custom Art Path 2: E:\Artwork\Coleco_Vision\Overlay13:21:30.2  3/3/2014:  Validating: Emulator_22: Control Panel Path: E:\Artwork\GameExtender\Controls\Coleco Vision\Colecovision.png13:21:30.2  3/3/2014:  Validating: Emulator_22: Database: [Console] Coleco Vision13:21:30.2  3/3/2014:  Validating: Emulator_22: Title Snap Path: E:\Artwork\Coleco_Vision\Title13:21:30.2  3/3/2014:  Validating: Emulator_22: Box Art Path: E:\Artwork\Coleco_Vision\Box13:21:30.2  3/3/2014:  Validating: Emulator_22: Cart Art Path: E:\Artwork\Coleco_Vision\Cart13:21:30.2  3/3/2014:  Validating: Emulator_22: TV Ad Path: E:\Artwork\Coleco_Vision\Video_Advert_MP413:21:30.2  3/3/2014:  Validating: Emulator_22: Manual Path: E:\Artwork\Coleco_Vision\Manual13:21:30.2  3/3/2014:  Validating: Emulator_23: Custom Background: back-mattell_intellivision.png13:21:30.2  3/3/2014:  Validating: Emulator_23: Snap Path: E:\Artwork\Mattel_Intellivision\Snap13:21:30.2  3/3/2014:  Validating: Emulator_23: Video Snap Path: E:\Artwork\Mattel_Intellivision\Video_MP413:21:30.2  3/3/2014:  Validating: Emulator_23: Custom Art Path 1: E:\Artwork\Mattel_Intellivision\Overlay13:21:30.3  3/3/2014:  Validating: Emulator_23: Custom Art Path 2: E:\Artwork\Mattel_Intellivision\CartTop13:21:30.3  3/3/2014:  Validating: Emulator_23: Control Panel Path: E:\Artwork\GameExtender\Controls\Intellivision\Intellivision.png13:21:30.3  3/3/2014:  Validating: Emulator_23: Database: [Console] Mattel Intellivision13:21:30.3  3/3/2014:  Validating: Emulator_23: Title Snap Path: E:\Artwork\Mattel_Intellivision\Title13:21:30.3  3/3/2014:  Validating: Emulator_23: Box Art Path: E:\Artwork\Mattel_Intellivision\Box_3D13:21:30.3  3/3/2014:  Validating: Emulator_23: Cart Art Path: E:\Artwork\Mattel_Intellivision\Cart13:21:30.3  3/3/2014:  Validating: Emulator_23: TV Ad Path: E:\Artwork\Mattel_Intellivision\Video_Advert_MP413:21:30.3  3/3/2014:  Validating: Emulator_23: Manual Path: E:\Artwork\Mattel_Intellivision\Manual13:21:30.3  3/3/2014:  Validating: Emulator_25: Custom Background: back-visual_pinball.png13:21:30.3  3/3/2014:  Validating: Emulator_25: Snap Path: C:\Artwork\Visual_Pinball\Snap13:21:30.3  3/3/2014:  Validating: Emulator_25: Video Snap Path: C:\Artwork\Visual_Pinball\Video_F4V13:21:30.3  3/3/2014:  Validating: Emulator_25: Custom Art Path 1: F:\Pinball\artwork\Backglass13:21:30.3  3/3/2014:  Warning: Emulator_25: Custom Art Path 1 Does not exist13:21:30.3  3/3/2014:  Validating: Emulator_25: Custom Art Path 2: F:\Pinball\artwork\Playfield13:21:30.3  3/3/2014:  Warning: Emulator_25: Custom Art Path 2 Does not exist13:21:30.3  3/3/2014:  Validating: Emulator_25: Custom Art Path 3: F:\Pinball\artwork\Flyer13:21:30.3  3/3/2014:  Warning: Emulator_25: Custom Art Path 3 Does not exist13:21:30.3  3/3/2014:  Validating: Emulator_25: Control Panel Path: C:\Artwork\Controls\Main\VPIN.png13:21:30.3  3/3/2014:  Validating: Emulator_25: Database: [Pinball] Visual Pinball13:21:30.3  3/3/2014:  Validating: Emulator_25: Manual Path: E:\Pinball\artwork\Manual13:21:30.3  3/3/2014:  Validating: Emulator_26: Custom Background: back-future_pinball.png13:21:30.3  3/3/2014:  Validating: Emulator_26: Snap Path: C:\Artwork\Future_Pinball\Snap13:21:30.3  3/3/2014:  Validating: Emulator_26: Database: [Pinball] Future Pinball13:21:30.3  3/3/2014:  Validating: Emulator_28: Custom Background: back-sony_playstation.png13:21:30.3  3/3/2014:  Validating: Emulator_28: Snap Path: C:\Artwork\Sony_Playstation\Snap13:21:30.3  3/3/2014:  Validating: Emulator_28: Video Snap Path: C:\Artwork\Sony_Playstation\Video_AVI13:21:30.3  3/3/2014:  Validating: Emulator_28: Custom Art Path 1: C:\Artwork\Sony_Playstation\Snap13:21:30.3  3/3/2014:  Validating: Emulator_28: Control Panel Path: C:\Artwork\Controls\PSX.png13:21:30.3  3/3/2014:  Validating: Emulator_28: Database: [Console] Sony PlayStation13:21:30.4  3/3/2014:  Validating: Emulator_28: Title Snap Path: C:\Artwork\Sony_Playstation\Title13:21:30.4  3/3/2014:  Validating: Emulator_28: Box Art Path: C:\Artwork\Sony_Playstation\Box13:21:30.4  3/3/2014:  Validating: Emulator_28: TV Ad Path: C:\Artwork\Sony_Playstation\Video_Advert_AVI13:21:30.4  3/3/2014:  Validating: Emulator_28: Manual Path: C:\Artwork\Sony_Playstation\Manual13:21:30.4  3/3/2014:  Validating: Emulator_29: Custom Background: back-windows_games.png13:21:30.4  3/3/2014:  Validating: Emulator_29: Snap Path: E:\WinGames\Artwork\Snaps13:21:30.4  3/3/2014:  Validating: Emulator_29: Video Snap Path: E:\WinGames\Artwork\Video_MP413:21:30.4  3/3/2014:  Validating: Emulator_29: Custom Art Path 1: E:\WinGames\Artwork\Snaps13:21:30.4  3/3/2014:  Validating: Emulator_29: Control Panel Path: F:\Images\Controls\Windows13:21:30.4  3/3/2014:  Validating: Emulator_29: Title Snap Path: E:\WinGames\Artwork\Titles13:21:30.4  3/3/2014:  Validating: Emulator_29: Box Art Path: E:\WinGames\Artwork\Boxes13:21:30.4  3/3/2014:  Validating: Emulator_29: Cart Art Path: E:\WinGames\Artwork\Discs13:21:30.4  3/3/2014:  Validating: Emulator_29: Manual Path: E:\WinGames\Artwork\Manuals13:21:30.4  3/3/2014:  Validating: Emulator_30: Custom Background: back-windows_games.png13:21:30.4  3/3/2014:  Validating: Emulator_30: Snap Path: E:\WinGames\Artwork\Snaps13:21:30.4  3/3/2014:  Validating: Emulator_30: Video Snap Path: E:\WinGames\Artwork\Video_MP413:21:30.4  3/3/2014:  Validating: Emulator_30: Control Panel Path: F:\Images\Controls\Windows13:21:30.4  3/3/2014:  Validating: Emulator_30: Title Snap Path: E:\WinGames\Artwork\Titles13:21:30.4  3/3/2014:  Validating: Emulator_30: Box Art Path: E:\WinGames\Artwork\Boxes13:21:30.4  3/3/2014:  Validating: Emulator_30: Cart Art Path: E:\WinGames\Artwork\Discs13:21:30.4  3/3/2014:  Validating: Emulator_30: Manual Path: E:\WinGames\Artwork\Manuals13:21:30.4  3/3/2014:  Validating: Emulator_31: Custom Background: back-windows_games.png13:21:30.4  3/3/2014:  Validating: Emulator_31: Snap Path: E:\WinGames\Artwork\Snaps13:21:30.4  3/3/2014:  Validating: Emulator_31: Video Snap Path: E:\WinGames\Artwork\Video_MP413:21:30.4  3/3/2014:  Validating: Emulator_31: Control Panel Path: F:\Images\Controls\Windows13:21:30.4  3/3/2014:  Validating: Emulator_31: Title Snap Path: E:\WinGames\Artwork\Titles13:21:30.4  3/3/2014:  Validating: Emulator_31: Box Art Path: E:\WinGames\Artwork\Boxes13:21:30.4  3/3/2014:  Validating: Emulator_31: Cart Art Path: E:\WinGames\Artwork\Discs13:21:30.4  3/3/2014:  Validating: Emulator_31: Manual Path: E:\WinGames\Artwork\Manuals13:21:30.4  3/3/2014:  Validating: Emulator_32: Custom Background: back-homebrew_games.png13:21:30.5  3/3/2014:  Validating: Emulator_32: Snap Path: E:\WinGames\Artwork\Snaps13:21:30.5  3/3/2014:  Validating: Emulator_32: Video Snap Path: E:\WinGames\Artwork\Video_MP413:21:30.5  3/3/2014:  Validating: Emulator_32: Title Snap Path: E:\WinGames\Artwork\Titles13:21:30.5  3/3/2014:  Validating: Emulator_32: Box Art Path: E:\WinGames\Artwork\Boxes13:21:30.5  3/3/2014:  Validating: Emulator_32: Cart Art Path: E:\WinGames\Artwork\Discs13:21:30.5  3/3/2014:  Validating: Emulator_32: Manual Path: E:\WinGames\Artwork\Manuals13:21:30.5  3/3/2014:  Validating: Emulator_33: Custom Background: back-beats_of_rage.png13:21:30.5  3/3/2014:  Validating: Emulator_33: Snap Path: C:\Artwork\OpenBOR\Snap13:21:30.5  3/3/2014:  Validating: Emulator_33: Video Snap Path: C:\Artwork\OpenBOR\Video_MP4_HI_QUAL13:21:30.5  3/3/2014:  Validating: Emulator_33: Control Panel Path: F:\Images\Controls\Emulators\Open BOR.png13:21:30.5  3/3/2014:  Validating: Emulator_33: Title Snap Path: C:\Artwork\OpenBOR\Title13:21:30.5  3/3/2014:  Validating: Emulator_34: Custom Background: back-taito_type_x.png13:21:30.5  3/3/2014:  Validating: Emulator_34: Snap Path: C:\Artwork\Taito_Type_X_Merged\Snap13:21:30.5  3/3/2014:  Validating: Emulator_34: Video Snap Path: C:\Artwork\Taito_Type_X_Merged\Video_MP413:21:30.5  3/3/2014:  Validating: Emulator_34: Custom Art Path 1: C:\Artwork\Taito_Type_X_Merged\Snap13:21:30.5  3/3/2014:  Validating: Emulator_34: Title Snap Path: C:\Artwork\Taito_Type_X_Merged\Title13:21:30.5  3/3/2014:  Validating: Emulator_35: Custom Background: back-3do.png13:21:30.5  3/3/2014:  Validating: Emulator_35: Snap Path: E:\Artwork\Panasonic_3DO\Snap13:21:30.5  3/3/2014:  Validating: Emulator_35: Video Snap Path: E:\Artwork\Panasonic_3DO\Video_MP413:21:30.5  3/3/2014:  Validating: Emulator_35: Database: [Console] Panasonic 3DO13:21:30.5  3/3/2014:  Validating: Emulator_35: Title Snap Path: E:\Artwork\Panasonic_3DO\Title13:21:30.5  3/3/2014:  Validating: Emulator_35: Box Art Path: E:\Artwork\Panasonic_3DO\Box13:21:30.5  3/3/2014:  Validating: Emulator_35: Manual Path: E:\Artwork\Panasonic_3DO\Manual13:21:30.5  3/3/2014:  Validating: Emulator_36: Not Found Image: C:\Artwork\no_img.png13:21:30.5  3/3/2014:  Validating: Emulator_36: Database: [Handheld] Sony PSP13:21:30.7  3/3/2014:  Restoring Emulator from Cache: 113:21:30.8  3/3/2014:  No Database Data: 113:21:30.8  3/3/2014:  Restoring Emulator Database From Cache: 313:21:31.0  3/3/2014:  Restoring Emulator Database From Cache: 413:21:31.1  3/3/2014:  Restoring Emulator Database From Cache: 513:21:31.2  3/3/2014:  No Database Data: 613:21:31.3  3/3/2014:  Restoring Emulator Database From Cache: 713:21:31.4  3/3/2014:  Restoring Emulator Database From Cache: 813:21:31.5  3/3/2014:  Restoring Emulator Database From Cache: 913:21:31.5  3/3/2014:  Restoring Emulator from Cache: 1013:21:31.5  3/3/2014:  Restoring Emulator Database From Cache: 1013:21:31.6  3/3/2014:  Restoring Emulator from Cache: 1113:21:31.6  3/3/2014:  Restoring Emulator Database From Cache: 1113:21:31.6  3/3/2014:  Restoring Emulator Database From Cache: 1213:21:31.7  3/3/2014:  Restoring Emulator Database From Cache: 1313:21:31.8  3/3/2014:  Restoring Emulator Database From Cache: 1413:21:31.9  3/3/2014:  Restoring Emulator Database From Cache: 1513:21:31.9  3/3/2014:  Restoring Emulator Database From Cache: 1613:21:32.0  3/3/2014:  Restoring Emulator Database From Cache: 1713:21:32.0  3/3/2014:  Restoring Emulator Database From Cache: 1813:21:32.1  3/3/2014:  Restoring Emulator Database From Cache: 1913:21:32.2  3/3/2014:  Restoring Emulator Database From Cache: 2113:21:32.2  3/3/2014:  Restoring Emulator Database From Cache: 2213:21:32.3  3/3/2014:  Restoring Emulator Database From Cache: 2313:21:32.3  3/3/2014:  Restoring Emulator from Cache: 2513:21:32.3  3/3/2014:  Restoring Emulator Database From Cache: 2513:21:32.4  3/3/2014:  Restoring Emulator from Cache: 2613:21:32.4  3/3/2014:  No Database Data: 2613:21:32.4  3/3/2014:  Restoring Emulator from Cache: 2813:21:32.5  3/3/2014:  Restoring Emulator Database From Cache: 2813:21:32.5  3/3/2014:  Restoring Emulator from Cache: 2913:21:32.5  3/3/2014:  Restoring Emulator from Cache: 3013:21:32.5  3/3/2014:  Restoring Emulator from Cache: 3213:21:32.6  3/3/2014:  Restoring Emulator from Cache: 3313:21:32.6  3/3/2014:  Restoring Emulator from Cache: 3413:21:32.6  3/3/2014:  Restoring Emulator Database From Cache: 3513:21:32.6  3/3/2014:  Restoring Emulator from Cache: 3613:21:32.6  3/3/2014:  Restoring Emulator Database From Cache: 3613:24:25.8  3/3/2014:  Starting Attract Mode13:24:25.8  3/3/2014:  Reading MAME hall of fame13:24:26.4  3/3/2014:  Shutting down display13:33:36.9  3/3/2014:  Setting Up RawInput Hook13:33:36.9  3/3/2014:  Launching RawInputHook.exe13:33:38.2  3/3/2014:  Running: cmd.exe /c F: F:\Emulators\MAME\mame.exe canyon -rompath R:\Roms\MAME\roms -nowindow -joy -mt -video d3d -mouse -noka -tb -volume -32
Thanks for having a look at this. :)
Another user was reporting an issue with Game Extender with the 12.22 update.It should be resolved as of 12.23 and later.
