Hi all. I have my cab set to autostart Gameex when I power my pc on. All is fine except after it loads my screen is blank - I have to alt tab to bring the gameex to the front. I am also running the coinfx app on startup to make the coin drop sound with a 5 key.
Has anyone ran into this? It's not a killer but it would be great to show gameex window without having to alt-tab to it after bootup.
I've not seen this recently. Please submit a copy of your log.txt and gameex.ini file so we may quickly assist you. Refer to this link for additional information. Thanks!
Well, it looks like my problem involves my startup sequence. I downloaded a free delayer and delayed gameex for about 30 seconds. Seems to have fixed it. Thanks!
Glad you go it sorted! Just in case you weren't aware, Adultery has created a similar program called GameEx Launch that may work for you as well.
