Hey all first post have managed to create a template with marquee magician but have no idea what to do with it from here is there any guides around to get it setup? Also have been having some issues with gameex screen corruption the screen flips upside down and there is a lot of video corruption where do I find the log file to see if it tells me what is going on. Seems to only happen in gameex. The system is an i3 N.U.C pc with windows 8.1 and hd4000 graphics. Thanks in advance
EDIT here is my log and my gameex.ini
Edit 2 attached photo of video corruption
gammex.zip
post-26219-0-61537600-1393723119_thumb.j
Just finished a full reinstall and problem persists is it the on-board hd4000 causing the problem? Another thing I thought of that may be the cause when I attached my touch screen then mounted the panel It wasn't till I booted up I realised The screen was mounted upside down :wacko: so it is rotated via the video driver would this cause issues?
I would try it unrotated to see if that fixes it. Do you have the latest video drivers installed? I recommend gettng the drivers from your motherboard manufacturer as opposed to using the stock Windows drivers.
Will have to try un-rotated really hope that's not the issue because if it is I cant use gameex. Would be major rework to right screen. I have the official intel drivers installed.
Having been running it a good 20mins no corruption now how to remove automotive strength double sided tape to rotate screen orientation.
still going fine with no corruption anyway to rotate 180 degrees in gameex I see you can do 90 , so anyone know a tutorial to setup marquee magician?
@Bluc - Glad you got the video issue sorted! At this time, I will refer you to the Marquee Magician thread as this is a project by Tempest. I am not aware of a tutroial per se, but that would be a good place to start and ask questions with regards to setup and use.
