Help on ATARI ST (Steem) Configuration in GameEx
Hi,
Please , Can you help me about configuration steem (ATARI ST) in GameEx ?
I would like to get configuration example whose command line with start in fullscreen.
I am disappointed that the wizard does not offer this type of emulation Machine (Amiga differently) because of its popularity.
thanks
Have you considered running STEEM via GameBase? GameEx supports GameBase setups and there is a fantastic tutorial to be found here. Even if you prefer to not go with GameBase, there may be some STEEM setup information you may find useful.
Here is a config for steem. Don't forget to adjust your paths.
Enabled=TrueSTARTPAGENAME=Atari STTITLETEXT=Atari ST GamesStartPageLogo=Atari STROMFilter=RomPath=d:\mess\software\ataristSnapPath=TitlePath=BoxPath=CartPath=ManualPath=ControlPanelPath=InstructionsPath=WorkingPath=d:\emulators\stMapKeys=WaitBeforeKeys=600SendKeys=NReplaceDash=ReplaceUnder=Capitals=RemoveBrackets=ShowDesktop=FalseDebug=MAPFile=AlsoLaunch=Command=Steem.exe "[rompath]/[romfile]" FULLSCREENOLDatZip=LaunchBefore=LaunchAfter=configFile=[Mapping Off] Exit (Process Close)ExcludedFiles=CustomBackground=Back - Atari ST.pngPlayMusic=DontShowInfo=PlaySelectionMusic=SelectionMusicFolder=PCGame=DATABASE=GamesIn7Zips=FalsePlayInScreenSaver=ShowMostPlayed=TrueRandomMostPlayed=TrueCDCheck=CDCheckFile=
