I just bought a pair of these guns and they work fantastic in Mame32 version 1.03.
I cant get them to function in Gameex however. Any Ideas?
i had the same issue with my usb track ball and had to manually fix.
open your mame ini file then open mame configuration file and about halfway down where it says dual lightgun 0 change it to 1 and that should force it to detect.
hope that helps!
hope that helps!
Thanks for the suggestion. I have fixed the problem though, not sure how. It just started working. :unsure:
