Hello guys, I don't know if this is a bug or something but I just can't get pinballx to respond to my keyboard presses.
Here is the whole story. I recently reformatted my system but backed up PinballX install dir to a D:\Pinball\PinballX drive. (My first installation was on C:\PinballX) . After copy/paste the backup I updated pinballx through the installer to 1.72 but since the restore process I just can't get my keyboard to work. I went through the settings wizzard process and was able to map the keys but I'm getting no response from PinballX.
I tried everything, uninstall and reinstall did not work. I've also checked to config file and the keys were mapped correctly in the file.
Any clues?
btw. I'm using windows 7 and I tried the same with Hyperpin and everything works fine.
Thanks in advance
  • 4 weeks later...
I have seen someone else reported exacly same problem - but I lost mentioned post and can't find again...
When I run settings.exe everythig seems to be fine and I can setup my keyboard - all keys work.
When I start PinballX with PinballX.exe keyboard seems to be totaly dead, nothing works
This is killing me... help please.
Using win7 64bit; usb keyboard logitech k290
[EDIT]
Tested with another, ps2 keyboard - nothing change - keybord works in setup but stop responding after running frontend
Did you find problem couse and solution?
I have exactly the same problem... keyboard not responding after running pinballx.exe, but all ok when configuring after running settings.exe...
I tryed with another, older ps2 keybord - same - keys dont work.
In hyperpinh everything works like a charm... in pinballX keybord is dead
WTF?!
I found and merged both threads as they are reporting the same issue. Sorry you are having a problem with the keyboard. I ask both of you to read this thread and provide the oft-requested log.txt and pinballx.ini files noted in the thread. Also provide details about your OS and any codecs you have installed. Thanks, guys!
07:58:13.3 2014-02-17: PinballX - Version 1.74
07:58:13.3 2014-02-17: Loading Settings
07:58:13.3 2014-02-17: Initialize Component
07:58:13.4 2014-02-17: Initialize Display
07:58:13.4 2014-02-17: Loading PlugIns
07:58:13.5 2014-02-17: Created DirectX BackGlass Window
07:58:13.5 2014-02-17: Hiding Cursor
07:58:13.5 2014-02-17: Hiding Taskbar
07:58:13.5 2014-02-17: Load Game List
07:58:13.5 2014-02-17: Loading Database: Visual Pinball
07:58:13.5 2014-02-17: Loading Custom Database: Visual Pinball - Copy
07:58:13.5 2014-02-17: Finding and matching artwork and videos
07:58:13.5 2014-02-17: Loading Game Statistics and Scores
07:58:14.8 2014-02-17: Initialize Audio
07:58:14.9 2014-02-17: Set Keyboard Controls
07:58:14.9 2014-02-17: Initialize Joystick
07:58:14.9 2014-02-17: No Joysticks Attached
07:58:14.9 2014-02-17: Started
08:04:08.2 2014-02-17: Created DirectX BackGlass Window
08:04:18.4 2014-02-17: Exiting
08:04:18.4 2014-02-17: Showing Taskbar
08:04:18.4 2014-02-17: Unhiding Mouse Cursor
08:04:18.4 2014-02-17: Disposing Plugins
08:04:18.4 2014-02-17: Saving Settings
"07:58:13.5 2014-02-17: Hiding Cursor" - not true. I can see cursor all the time! I am using 3 monitor display prepared to become cabinet. After running PinballX.exe I have 2 monitors "taken" by Frontend (wannnabe-dmd monitor just shows wallpaper) and visible cursor - I can move cursor to 3th monitor and click - this minimalize PinballX to taskbar and I can click on it and choose "close window" - its only thing that saves me from hard reset.
"07:58:13.5 2014-02-17: Loading Custom Database: Visual Pinball - Copy" - I deleted this file but it didn't change anythying
Forget to mention - keybord is like PinballX-dead. If I pres ctrl+alt+del I can start task menager but right after start its hidden under PinballX frontend so with no 3th monitor and possilility to click on its area to minimalize probably I would have to hard reset my rig. Looks like "focus" is on this damn cursor, and frontend works on "lower layer" or something?!
What OS (and codecs - while not necessary in this case, good to know regardless)?
Do you have the issue with an usb keyboard too?
If it is a focus problem: I think you already tried alt+tab to set focus on PinballX, don´t you?
What monitor setup (Numbers and order) do you have in windows display settings?
Win7 64 bit, pretty nice rig with [email protected] and GFX770.
My keybord is USB logitech k290. I tryed to switch to old PS2 keyboard - but as I mention that does not change a thing.
I did not installed any extra codecs - don't think my system needs it, every video file I have tryed seems to play with no problem.
Hyperpin works like a charm.
My monitors:
Playfield: [1920x1080 iyama] Backglass: [1600x1200 nec] DMD: [1600x1200 iyama]
In nvidia panel order is
MONITOR2 [1920x1080 iyama] (* main / dvi): MONITOR3 [1600x1200 nec / dvi] MONITOR1: [1600x1200 iyama / hdmi]
But as mentioned - everything works nice in Hyperpin. Seems to also work nice in PnballX - graphics or monitor order is not my problem - lack of keyboard response is.
Alt+tab do nothing.
alt+f4 do nothing
ctrl+alt+del brings standar win screen alowing me to start task menager - but right after Ill do it its hidden under PinballX and only possibility to move this damn cursor (visable all the time) and click on this "dmd" screen saves me from hard reset.
Cursor is visible all the time.
Just taking a stab here....what is your default language and keyboard language set to?
I know there were issues with FP if you were not running an English OS, not the same issue you are having....but it has to be something simple.
Z
Issue with FP is about measurement system - it can be fixed by changing it in system or by modification table script... and if no fixed it results with mess on dmd when displaying score and has nothing to do with non responding keyboard.
I am using english Win 7 ultimate 64 bit with system language set to us english and polish programmer keyboard. I tryed to switch keyboard seting anyway but just like I thought it didn't solve the problem.
I think problem is somehow connected with this bloody cursor visible all the time. :(
Both pinballx.exe AND vpinball.exe are both unblocked and set to run as adminstrator?
Something to look at:
http://www.gopinball.com/forum/viewtopic.php?f=15&t=3920
Z
"Do you have an IR receiver attached to the box? I recall a while ago there was an issue w/ a MSFT mouse/keyboard/HID driver being installed that you had to remove and the key control came back. 103 key keyboard? Something like that, affected VP too." - from your link.
Thank you for your help Zeenon.
Yap,I think it's probably something like this.
I have logitech usb beyboard k290, logitech mouse MX518 (both don't require any extra driver) and x-box 360 wierless controller (extra driver installed)...
Even If I could I am unwiling to uninstall any of my drivers - maybye it's x-box controller, but I am using it in many games....
I tryed to set x-box controller as joystick and it PARTIALY work - I am abble to start first table, but flippers dont move, I can't turn frontend wheele, etc - I can't play... But start buttton works. Damn strange.
I give up, I will stick to hyperpin.Maybye I will try PinballX in few months in other, newer version.
Please Devs, sort this out.
Not much the devs can do to sort it out without more troubleshooting. I would recommend using standard keyboard, mouse and possibly a gamepad to see if that remedies the issue, then add your components back one at a time to see which one "breaks" the functionality again. Since there are a myriad of 3rd party pads, wireless keyboards, etc., it is truly difficult for a developer to account for every one of them without the end-users performing some of the heavy lifting and reporting back their results.
While I understand your frustration, saying "I give up, I will stick to hyperpin.Maybye I will try PinballX in few months in other, newer version. Please Devs, sort this out." won't help them to make your experience with the product better.
Mate, I did my best: I switched keyboards, played with my system and frontend setting, tryed to google some solution and tryed every advise ppl gave me here (thank you all).
And I tryed to deliver as much information in problem description as I could.
I really wanted to try PinballX. But enough is enough. Hyperpin works like a charm! I am not going to waste more time on this, now it's up to devs.
Last thing:
Uninstaller is broken - uninstall proces left PinballX folder with "Flash.ocx" inside. File has broken ownership status/rights and cannot be delated manualy untill you fix this. I am not computer geek so it took me another few minutes to google how to do it... it should not be like this! FIX THIS DEVS!
Vinthar - I understand your frustration but it does sound to me like you are having other issues with your setup that are complicating what should not be this difficult.
If this is an issue with the application proper, we should be hearing from more than one or two users out of hundreds that are using it successfully. Textually screaming "FIX THIS DEVS!" is not going to get you very far and, if you are unwilling to do any leg work and provide detailed responses to our questions as we try to step you through an issue, nothing is going to change for you, I'm afraid.
I am not frustrated Draco. I think PinballX has some very cool features - like dmd movie - and I wanted to try it. Bit since PinballX does not works on my system and looks like there is nothing I can do to fix this (and believe me I have tryed!)I see no reason to be frustrated or to waste time while other software with the same function works for me just fine.
So I simply report to devs: on some systems keyboard does not work and unistaller have some serious issues.
I will for sure try PinballX again in future when some newer version will be available.
For now enough is enough - I want to play pinball in my free time, not waste time for fighting with pinball frontend...
Thanks to everyone who tryed to help.
Latest info:
Just tryed new v1.75 and it's all the same - keyboard is not rsponsive and unistaller is broken - "Flash.ocx" belongs to noone and require manual intervention in owning rights, other way it's undeletable...
Any clues?
Thanks in advance
Hi Rainman. Just wanted you to know that we haven't forgotten about you regarding this issue. Have you been able to resolve this issue for yourself or do you still require assistance? Please provide a copy of your pinballx.ini and log.txt file and any other pertinent information. You will also want to download and install version 1.75 prior to providing your log.txt. Thanks!
Some things to try:
1. Is PinballX losing focus when you launch it? Try clicking your mouse on the window. Does it respond to input now?
2. Install the latest version of Flash (http://get.adobe.com/flashplayer/)
3. Install video codecs (http://shark007.net/win7codecs.html)
Try each step in order and check after each step if anything changed. Report back your findings here.
As for the issue with Flash.ocx, try deleting it using Unlocker (http://www.emptyloop.com/unlocker/). It will also tell you what process is preventing the file from being deleted. Let us know what file is preventing it from being deleted. It may clue us in to what the problem is. Most likely it will be PinballX.exe in which case it would seem that PinballX is infact crashing and not exiting gracefully.
Some things to try:
PinballX starts with mouse cursor visible... I can run cursor but keybord does not work, clicking mouse does nothing untill I move cursor to 3th monitor (1,& 2 are occupy by PinballX). Clicking mouse on 3th monitor minimize frontend to task bar and I can close it.
I have latest version of Flash.
I installed this codecs but it changed nothing.
Flash.ocx stil has messed owning rights and is undeletable withouth previous manuall ingerention.
I am aware of the flash issue.
I see no log in this topic or information about the ops system hardware and software.
PinbalX log is at post #5 - you can take a look but nothing wrong in it.
System hardware was also mention before. Don't know if this will help but here is dxdiag log:
System Information
Time of this report: 2/23/2014, 20:13:28
Machine name: IMRIEL
Operating System: Windows 7 Ultimate 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130828-1532)
Language: Polish (Regional Setting: Polish)
System Manufacturer: MSI
System Model: MS-7751
BIOS: BIOS Date: 10/30/13 16:13:20 Ver: 04.06.05
Processor: Intel® Core i7-3770K CPU @ 3.50GHz (8 CPUs), ~3.5GHz
Memory: 16384MB RAM
Available OS Memory: 16332MB RAM
Page File: 4284MB used, 28377MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Display Tab 2: No problems found.
Display Tab 3: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce GTX 770
Manufacturer: NVIDIA
Chip type: GeForce GTX 770
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_1184&SUBSYS_36031458&REV_A1
Display Memory: 4038 MB
Dedicated Memory: 1990 MB
Shared Memory: 2048 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: PL2209HD
Monitor Id: IVM560B
Native Mode: 1920 x 1080(p) (60.000Hz)
Output Type: DVI
Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
Driver File Version: 9.18.0013.3489 (English)
Driver Version: 9.18.13.3489
DDI Version: 11
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 2/8/2014 19:34:51, 17715784 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B71E3E-52C4-11CF-497A-0E161CC2C435}
Vendor ID: 0x10DE
Device ID: 0x1184
SubSys ID: 0x36031458
Revision ID: 0x00A1
Driver Strong Name: oem53.inf:NVIDIA_SetA_Devices.NTamd64.6.1:Section093:9.18.13.3489:pci\ven_10de&dev_1184
Rank Of Driver: 00E02001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
D3D9 Overlay: Supported
DXVA-HD: Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Current Mode: 1600 x 1200 (32 bit) (60Hz)
Monitor Model: LCD2170NX
Monitor Id: NEC6695
Native Mode: 1600 x 1200(p) (60.000Hz)
Output Type: DVI
DDI Version: 11
WHQL Logo'd: Yes
WHQL Date Stamp:
Vendor ID: 0x10DE
Device ID: 0x1184
Revision ID: 0x00A1
DXVA-HD: Supported
D3D Status: Enabled
AGP Status: Enabled
Monitor Model: PLE511S
Monitor Id: IVM5341
Native Mode: 1280 x 1024(p) (59.907Hz)
Output Type: HDMI
DDI Version: 11
WHQL Logo'd: Yes
WHQL Date Stamp:
Vendor ID: 0x10DE
Device ID: 0x1184
Revision ID: 0x00A1
DXVA-HD: Supported
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Description: Speakers (Realtek High Definition Audio)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0899&SUBSYS_1462D751&REV_1000
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RTKVHD64.sys
Driver Version: 6.00.0001.7037 (English)
WHQL Logo'd: Yes
Date and Size: 9/10/2013 21:40:40, 3640024 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX 2.0 Listen/Src: No, No
I3DL2 Listen/Src: No, No
Sensaura ZoomFX: No
Description: Realtek Digital Output (Realtek High Definition Audio)
Default Sound Playback: No
Default Voice Playback: No
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF1F
HW Memory: 0
Sensaura ZoomFX: No
Sound Capture Devices
Description: Microphone (Realtek High Definition Audio)
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x1
Format Flags: 0xFFFFF
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: USB Keyboard
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC31F
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x1E26
| Matching Device ID: usb\root_hub20
| Service: usbhub
+-+ Generic USB Hub
| | Vendor/Product ID: 0x8087, 0x0024
| | Matching Device ID: usb\class_09
| | Service: usbhub
Gameport Devices
PS/2 Devices
+ HID Keyboard Device
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
+ HID-compliant mouse
| Vendor/Product ID: 0x046D, 0xC051
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 297.6 GB
Total Space: 614.8 GB
File System: NTFS
Model: WDC WD3001FAEX-00MJRA0 ATA Device
Drive: D:
Free Space: 315.7 GB
Total Space: 1120.0 GB
File System: NTFS
Drive: E:
Free Space: 953.9 GB
Total Space: 1126.6 GB
File System: NTFS
Drive: H:
Free Space: 981.8 GB
Total Space: 1000.0 GB
File System: NTFS
Model: WDC WD30EFRX-68AX9N0 ATA Device
Drive: I:
Drive: J:
Drive: Y:
Free Space: 233.3 GB
File System: NTFS
Model: n/a
Drive: Z:
Free Space: 188.8 GB
Total Space: 861.5 GB
File System: NTFS
Model: n/a
Drive: F:
Model: HL-DT-ST BD-RE BH16NS40 ATA Device
Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7601.17514 (Polish), , 0 bytes
Drive: G:
Model: ZKNEV 5EBKXM741 SCSI CdRom Device
System Devices
Name: Intel® Z77 Express Chipset LPC Controller - 1E44
Device ID: PCI\VEN_8086&DEV_1E44&SUBSYS_77511462&REV_04\3&11583659&0&F8
Driver: n/a
Name: Intel® 7 Series/C216 Chipset Family PCI Express Root Port 2 - 1E12
Device ID: PCI\VEN_8086&DEV_1E12&SUBSYS_77511462&REV_C4\3&11583659&0&E1
Driver: n/a
Name: NVIDIA GeForce GTX 770
Device ID: PCI\VEN_10DE&DEV_1184&SUBSYS_36031458&REV_A1\4&2D1605AF&0&0008
Driver: n/a
Name: Intel® Management Engine Interface
Device ID: PCI\VEN_8086&DEV_1E3A&SUBSYS_77511462&REV_04\3&11583659&0&B0
Driver: n/a
Name: Intel® 7 Series/C216 Chipset Family PCI Express Root Port 1 - 1E10
Device ID: PCI\VEN_8086&DEV_1E10&SUBSYS_77511462&REV_C4\3&11583659&0&E0
Driver: n/a
Name: High Definition Audio Controller
Device ID: PCI\VEN_10DE&DEV_0E0A&SUBSYS_36031458&REV_A1\4&2D1605AF&0&0108
Driver: n/a
Name: Intel® USB 3.0 eXtensible Host Controller
Device ID: PCI\VEN_8086&DEV_1E31&SUBSYS_77511462&REV_04\3&11583659&0&A0
Driver: n/a
Name: Intel® 7 Series/C216 Chipset Family SATA AHCI Controller - 1E02
Device ID: PCI\VEN_8086&DEV_1E02&SUBSYS_77511462&REV_04\3&11583659&0&FA
Driver: n/a
Name: Intel® 7 Series/C216 Chipset Family USB Enhanced Host Controller - 1E2D
Device ID: PCI\VEN_8086&DEV_1E2D&SUBSYS_77511462&REV_04\3&11583659&0&D0
Driver: n/a
Name: Intel® 7 Series/C216 Chipset Family USB Enhanced Host Controller - 1E26
Device ID: PCI\VEN_8086&DEV_1E26&SUBSYS_77511462&REV_04\3&11583659&0&E8
Driver: n/a
Name: Xeon® processor E3-1200 v2/3rd Gen Core processor PCI Express Root Port - 0151
Device ID: PCI\VEN_8086&DEV_0151&SUBSYS_77511462&REV_09\3&11583659&0&08
Driver: n/a
Name: Intel® 7 Series/C216 Chipset Family SMBus Host Controller - 1E22
Device ID: PCI\VEN_8086&DEV_1E22&SUBSYS_77511462&REV_04\3&11583659&0&FB
Driver: n/a
Name: Xeon® processor E3-1200 v2/3rd Gen Core processor DRAM Controller - 0150
Device ID: PCI\VEN_8086&DEV_0150&SUBSYS_77511462&REV_09\3&11583659&0&00
Driver: n/a
Device ID: PCI\VEN_8086&DEV_1E20&SUBSYS_D7511462&REV_04\3&11583659&0&D8
Driver: n/a
Name: Renesas Electronics USB 3.0 Host Controller
Device ID: PCI\VEN_1912&DEV_0014&SUBSYS_77511462&REV_03\4&17BD0AFE&0&00E7
Driver: n/a
Name: Intel® 7 Series/C216 Chipset Family PCI Express Root Port 8 - 1E1E
Device ID: PCI\VEN_8086&DEV_1E1E&SUBSYS_77511462&REV_C4\3&11583659&0&E7
Driver: n/a
Name: Realtek PCIe GBE Family Controller
Device ID: PCI\VEN_10EC&DEV_8168&SUBSYS_77511462&REV_06\4&EEA626D&0&00E1
Driver: n/a
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7601.17514
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7601.17514
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7601.17514
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7601.17514
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7601.18221
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
PP PCM Wrapper,0x00200000,1,1,ppPCMEnc.ax,1.01.0000.0321
CyberLink Editing Service 4.5 (Source),0x00200000,0,2,CLEdtKrn.dll,4.05.0000.3103
CyberLink UltraSpeed/SVRT Demultiplexer,0x00600000,1,0,SE_CLEdtDemuxer.ax,1.02.0002.4213
CyberLink MP3/WAV Wrapper,0x00200000,1,1,P2GMP3Wrap.ax,3.07.0000.1314
PP Video Regulator,0x00200000,1,1,CLResample.ax,2.05.0000.1818
PP TV Audio Decoder,0x00200000,1,1,claudTV.ax,6.03.0000.1029
DV Muxer,0x00400000,0,0,qdv.dll,6.06.7601.17514
PP YUY2 Deinterlace,0x00200000,1,1,ppDItlYuY2.ax,2.05.0000.2703
CyberLink AudioCD Filter,0x00200000,0,1,P2GAudioCD.ax,5.00.0000.1321
Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7601.17713
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7601.17514
CyberLink Audio Wizard,0x00201010,1,1,CLAudWizard.ax,1.00.0000.4414
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7601.17514
AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7601.17713
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7601.17713
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7601.17528
PP IDM,0x00200000,1,1,ppIDMF.ax,1.00.0000.5113
CyberLink UltraSpeed/SVRT Demultiplexer,0x00200000,1,0,CLEdtDemuxer.ax,1.02.0001.8712
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,12.00.9200.16426
PP Video Effect,0x00200000,1,1,CLVidFx.ax,1.00.0000.4602
CyberLink Line21 Decoder (PDVD10),0x00200000,0,2,CLLine21.ax,4.00.0000.10324
Cyberlink TS Information,0x00200000,1,0,CLTSInfo.ax,1.02.0001.3026
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
CyberLink DVD Navigator (PDVD10),0x00200000,0,3,CLNavX.ax,8.01.0000.3411
PP Video Decoder,0x00200000,2,3,ppGenericVSD.ax,6.00.4900.9516
CyberLink AudioCD Filter (PDVD10),0x00200000,0,1,CLAudioCD.ax,5.00.0000.7823
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7601.17528
PP Audio Resampler,0x00200000,1,1,CLAuRsmpl.ax,2.00.0000.4301
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
PP Dump Dispatch Filter,0x00200000,1,0,CLDumpDispatch.ax,1.02.0001.2412
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7601.17713
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
CyberLink Matroska Splitter(PDVD10),0x00200000,1,2,CLMKVSplter.ax,1.00.0000.1902
CyberLink TimeStretch Filter (PDVD10),0x00200000,1,1,clauts.ax,2.00.0000.3404
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7601.17514
CyberLink RealMedia Splitter(PDVD10),0x00600000,1,1,CLRMSplitter.ax,1.00.0000.1706
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7601.17528
PP File Reader (Async.),0x00200000,0,1,ppReader.ax,2.00.0000.0812
PP Snapshot Filter,0x00200000,1,0,ppSnapshot.ax,1.00.0000.0001
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7601.17514
SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7601.17528
PP Dump Filter,0x00200000,1,0,CLDump.ax,3.00.0000.10814
CyberLink MPEG-4 Splitter,0x00200000,1,2,SE_clm4splt.ax,1.01.0000.2709
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
PP DV Buffer,0x00200000,2,0,ppDVBuffer.ax,2.00.0000.1610
CyberLink DV Buffer,0x00200000,0,1,ppDVDump.ax,2.00.0001.0002
PP MOSnapShotTIP Filter,0x00200000,1,1,CLMOSShot.ax,1.00.0000.4022
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
CyberLink Video Regulator,0x00200000,1,1,P2GRGL.ax,2.00.0000.3328
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7601.17713
CyberLink MPEG Splitter,0x00200000,1,2,CLSplter.ax,3.04.0000.3408
CyberLink Mux Push Source,0x00200000,0,1,SE_CLMuxPushSrc.ax,1.00.0000.3509
PP DDR,0x00200000,1,0,ppRender.ax,2.00.0002.0026
DV Splitter,0x00600000,1,2,qdv.dll,6.06.7601.17514
CyberLink Audio Decoder (PDVD10),0x00201000,1,1,Claud.ax,8.04.0000.4528
CyberLink Video/SP Decoder (PDVD10),0x00602000,2,3,CLVsd.ax,8.04.0000.2505
CyberLink HD/BD Mixer (PDVD10),0x00200000,1,2,CLHBMixer.ax,2.00.0000.3407
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7601.17713
PP TL MPEG Splitter,0x00200000,1,2,CLTLMSplter.ax,3.03.0000.1917
PP M2V Writer,0x00200000,1,0,PPM2VWriter.ax,1.03.0000.2523
CyberLink Audio Commercial Cut Analyzer,0x00200000,1,1,CLAudCM.ax,1.00.0000.2019
PP DV TCR,0x00200000,1,1,ppDVTCR.ax,2.01.0000.6525
Cyberlink Sub-Picture Filter,0x00200000,1,1,CLSubPic.ax,3.00.0000.0728
CyberLink Audio Noise Reduction,0x00200000,1,1,P2GAuNRWrapper.ax,2.00.0000.1017
CyberLink Audio Effect (PDVD10),0x00200000,1,1,ClAudFx.ax,6.00.0000.7225
PP Audio Encoder,0x00200000,2,0,CLAudEnc.ax,2.01.0000.1926
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7601.17514
CyberLink Load Image Filter,0x00200000,0,1,CLImage.ax,3.01.0000.2928
CyberLink Audio VolumeBooster,0x00200000,1,1,P2GVB.ax,1.00.0000.1008
PP MPEG Muxer,0x00200000,2,1,MpgMux.ax,5.03.0000.1516
CyberLink Video Transcoder (Intel MSDK),0x00200000,1,1,CLVTrans.ax,1.00.0000.1509
ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7601.17713
CyberLink Frame Parser,0x00200000,2,0,CLFParser.ax,1.00.0000.3702
Video Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7601.17528
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.06.7601.17835
Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7601.17713
Video Renderer,0x00400000,1,0,quartz.dll,6.06.7601.17713
CyberLink MPEGV Analyzer,0x00200000,1,1,SE_CLMPEGVAnalyzer.ax,1.00.0000.5512
CyberLink Audio Resampler,0x00200000,1,1,P2GAuRsmpl.ax,1.00.0000.2625
CyberLink SBE Source Filter,0x00200000,0,0,CLSBESrc.ax,1.00.0000.3628
CyberLink AVCHD Navigator,0x00600000,0,3,CLAVCHDNav.ax,2.00.0000.4516
CyberLink Digest Filter (PDVD10),0x00200000,2,2,DigestFilter.dll,1.00.0000.4028
Cyberlink Dump Dispatch Filter,0x00200000,1,0,SE_CLDumpDispatch.ax,1.03.0000.3509
VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7601.17514
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7601.17514
CyberLink Stamp Effect,0x00200000,1,1,ppStampEffect.ax,1.00.0000.4125
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7601.17514
CyberLink Demultiplexer,0x00200000,1,0,cldemuxer.ax,1.00.0000.7830
File writer,0x00200000,1,0,qcap.dll,6.06.7601.17514
PP YUY2 Sub-Sampling,0x00200000,1,1,ppSubYUY2.ax,2.05.0000.2628
iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7601.17514
iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7601.17514
Cyberlink SubTitle Importor (PDVD10),0x00200000,2,1,CLSubTitle.ax,2.00.0000.1823
Cyberlink File Reader (Async.),0x00200000,0,1,P2GReader.ax,3.00.0000.3016
CyberLink TL MPEG Splitter,0x00200000,1,2,SE_CLTLMSplter.ax,3.04.0000.2701
PP Audio Effect,0x00200000,1,1,CLAudFx.ax,6.01.0000.2101
PP WAV Dest,0x00200000,0,0,PPWavDest.ax,1.00.0000.0002
CyberLink Audio Decoder,0x00200000,1,1,SE_claud.ax,8.03.0000.2407
PP Audio Decoder,0x00200000,1,1,CLAud.ax,8.04.0000.4528
CyberLink PCM Wrapper,0x00200000,1,1,P2GPCMEnc.ax,1.01.0000.0321
DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7601.17835
PP MPEG Splitter,0x00200000,1,2,CLSplter.ax,3.03.0000.1917
Cyberlink Scene Detect Filter,0x00200000,1,1,ppScnDt.ax,1.00.0000.0813
Overlay Mixer2,0x00200000,1,1,qdvd.dll,6.06.7601.17835
PP Audio Noise Reduction (CES),0x00200000,1,1,CLAuNRWrapper.ax,2.00.0000.3319
CyberLink Tzan Filter,0x00200000,1,1,CLTzan.ax,2.00.0000.1625
AVI Draw,0x00600064,9,1,quartz.dll,6.06.7601.17713
CyberLink H.264/AVC Decoder,0x00200000,1,2,cl264dec.ax,2.02.1470.4722
CyberLink HAM Decoder,0x00600000,0,1,CLCvd.ax,1.00.7820.3509
PP Gate Filter,0x00200000,1,1,ppGate.ax,1.00.0000.0001
RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7601.17514
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7601.17514
CyberLink Tzan Filter (PDVD10),0x00200000,1,1,CLTzan.ax,3.05.0000.4515
PP DV Dump Filter,0x00200000,1,0,ppDVDump.ax,2.00.0001.0002
SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7601.18175
Null Renderer,0x00200000,1,0,qedit.dll,6.06.7601.18175
CyberLink RealVideo Decoder(PDVD10),0x00600000,1,1,CLRMVD.ax,1.00.0000.1225
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7601.17514
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7601.17514
Cyberlink SubTitle Importor 2.0 (PDVD10),0x00200000,1,0,CLSubTitle.ax,2.00.0000.1823
CyberLink MPEGV Analyzer,0x00200000,1,1,CLMPEGVAnalyzer.ax,1.00.0000.3618
StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7601.17528
PowerProducer Double Tee,0x00200000,1,2,ppDoubleTee.ax,1.00.0000.1224
Smart Tee,0x00200000,1,2,qcap.dll,6.06.7601.17514
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.06.7601.17835
AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
CyberLink Video Decoder (PDVD10),0x00200000,1,2,CLCvd.ax,1.00.7820.3509
PP Video Regulator,0x00200000,1,1,CLRGL.ax,3.00.0000.1716
PP SnapShotTIP Filter,0x00200000,1,1,CLSShot.ax,1.00.0000.4712
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7601.17713
Wave Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
File stream renderer,0x00400000,1,1,quartz.dll,6.06.7601.17713
CyberLink SBE Filter,0x00200000,0,0,CLSBE.ax,1.00.0000.3628
CyberLink MPEG-4 Splitter (PDVD10),0x00600000,1,2,clm4splt.ax,1.01.0000.2906
CyberLink RealAudio Decoder(PDVD10),0x00600000,1,1,CLRMAud.ax,1.00.0000.1225
CyberLink MPEG Muxer,0x00200000,2,1,SE_MpgMux.ax,5.03.0000.1912
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7601.17528
AVI Mux,0x00200000,1,0,qcap.dll,6.06.7601.17514
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7601.17713
File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7601.17713
File Source (URL),0x00400000,0,1,quartz.dll,6.06.7601.17713
CyberLink MPEG-4 Muxer,0x00200000,1,1,SE_clm4muxer.ax,2.00.0000.2113
PP Byte Counter,0x00200000,1,1,ppByteCounter.ax,1.00.0000.1224
CyberLink AVI Audio Time Regulator,0x00200000,1,1,AVI_AudTR.ax,1.00.0000.1515
P2G Audio Encoder,0x00200000,2,0,P2GAudEnc.ax,2.00.0000.4815
PP MPEG Video Encoder,0x00200000,1,1,CLVidEnc.ax,7.00.0000.1509
CyberLink FLV Splitter(PDVD10),0x00800001,1,1,CLFLVSplitter.ax,1.00.0000.3327
Cyberlink Demuxer 2.0,0x00200000,1,1,CLDemuxer2.ax,2.00.0006.2518
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7601.17514
PP TimeStretch Filter (CES),0x00200000,1,1,clauts.ax,1.00.0000.4024
Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7601.17514
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7601.17669
MPEG Video Decoder,0x40000001,1,1,,
CyberLink MPEG-4 Splitter,0x00200000,1,2,clm4splt.ax,1.00.0000.6622
CyberLink MPEG-4 Muxer,0x00200000,1,1,clm4muxer.ax,1.00.0000.4724
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7601.17514
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7601.17713
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.06.7601.17514
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
Microsoft RLE,0x00200000,1,1,qcap.dll,6.06.7601.17514
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.06.7601.17514
RivaTuner Video Codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7601.17713
CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7601.17713
Audio Capture Sources:
Microphone (Realtek High Defini,0x00200000,0,0,qcap.dll,6.06.7601.17514
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7601.17528
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7601.17713
WDM Streaming Capture Devices:
Realtek HD Audio Line input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Realtek HD Audio Mic input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Realtek HD Audio Stereo input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
WDM Streaming Rendering Devices:
Realtek HD Audio output,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Realtek HDA SPDIF Out,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7601.17514
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7601.17669
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7601.17514
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7601.17708
Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7601.17708
PTFilter,0x00200000,0,0,EncDec.dll,6.06.7601.17708
XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7601.17708
WDM Streaming Communication Transforms:
Audio Renderers:
Speakers (Realtek High Definiti,0x00200000,1,0,quartz.dll,6.06.7601.17713
CyberLink Audio Renderer (PDVD10),0x00200000,1,0,cladr.ax,7.00.0000.4422
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7601.17713
DirectSound: Realtek Digital Output (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7601.17713
DirectSound: Speakers (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7601.17713
Realtek Digital Output (Realtek,0x00200000,1,0,quartz.dll,6.06.7601.17713
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
Quality Flags: 2576
Enabled:
Force throttling
Allow half deinterlace
Allow scaling
Decode Power Usage: 100
Balanced Flags: 1424
Enabled:
Force throttling
Allow batching
Force half deinterlace
Force scaling
Decode Power Usage: 50
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
Decode Power Usage: 0
Edited by nullPointer
Holy Wall of Text! Let's try some spoilers up in there ...
Vinthar - please post your pinballx.ini and log.txt files again after your upgrade to version 1.75. Your previous files were from 1.74. Thanks!
You do need 32 bit codecs for PinballX even though they play in windows did you install Shark 32 bit version?
Have you maybe got a device that has a key or button held down? Have you tried unplugging all gamepads etc?
I can tell you the keyboard code in PinballX does nothing low level it just uses standard windows api calls.
I also see you have a load of codecs installed that could be interfering, specifically cyberlink. I do not see shark codecs installed.
